Bolt Size for Mopar JK trailer Hitch - JeepForum.com
post #1 of 14 Old 05-06-2008, 08:21 AM Thread Starter
Fish Slayer
Does anybody know the bolt size and thread size for the Mopar hitch?
I bought on on the internet that did not come with the bolts.
Tom
Fish Slayer is offline
post #2 of 14 Old 05-06-2008, 11:43 AM
BuzzHog
BuzzHog's Avatar
Did you get a recovery hook with your Jeep?? You can reuse those three bolts and will only need to add one more.
Don't forget the Jeep Wave!!
BuzzHog is offline
post #3 of 14 Old 05-06-2008, 12:16 PM
N2rock
N2rock's Avatar
if it's the same size bolts as the recovery hook
M12 - 1.50 x 110mm
BTW- I am having one hell of a time finding those
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #4 of 14 Old 05-06-2008, 12:51 PM
BuzzHog
BuzzHog's Avatar
M12 - 1.50 x 110mm
http://www.boltdepot.com/product.asp...&cm=19&cd=1246 ???
BuzzHog is offline
post #5 of 14 Old 05-06-2008, 01:06 PM
N2rock
N2rock's Avatar
close, but that is a 10mm, and need a 12mm.
its the pitch (1.50 pitch) that is the killer. I can't seem to locate a 12mm with a 1.50 pitch- they are all 1.75 or 1.25
N2rock is offline
post #6 of 14 Old 05-06-2008, 02:31 PM Thread Starter
Fish Slayer
M12 - 1.50 x 110mm
Thanks for the info, If you don't mind ordering online, McMaster Carr has them, Part # 91180A765 $11.34 for a pack of 5. Grade 8.8
post #7 of 14 Old 05-06-2008, 02:34 PM
N2rock
N2rock's Avatar
awesome! I'm gonna go look up now
Thanks!
N2rock is offline
post #8 of 14 Old 05-06-2008, 02:39 PM
N2rock
N2rock's Avatar
hmmm... that is only a 100mm. The stock bolts are 110mm. I wonder if that 10mm is going to make a big difference
N2rock is offline
post #9 of 14 Old 05-06-2008, 02:42 PM Thread Starter
Fish Slayer
I over looked that. The bold depot listed above has them in 120mm length if you look under the grade 8.8, fine thread slection. I guess I had better measure the hitch to figure out if 100 or 120mm would be the better fit.
post #10 of 14 Old 05-06-2008, 03:03 PM
N2rock
N2rock's Avatar
I'm having a terrible time navigating that site. DO you have a part number for the 120mm?
N2rock is offline
post #11 of 14 Old 05-06-2008, 04:21 PM Thread Starter
Fish Slayer
here is the page:http://www.boltdepot.com/product.asp...&cm=21&cd=1309
If the link does not work try the following:
Look at the list on the left, find Metric Machine screws and click on it
next find Metric Hex bolts click
Steel Grade 8.8 Fine Thread click
12mm X 1.5
The catalouge # for the 100 mm long bolt is 6345, the 120mm is 6346
post #12 of 14 Old 05-06-2008, 10:04 PM Thread Starter
Fish Slayer
12mm X 1.5
It looks like 100 mm will be too short, like it will engage only about half of the nut.
post #13 of 14 Old 05-07-2008, 12:35 PM
N2rock
N2rock's Avatar
12mm X 1.5
the link works perfectly! Thank you so much! I am going to order me a couple of those today.
N2rock is offline
post #14 of 14 Old 06-07-2008, 11:15 PM
[email protected]
is grade 8.8 ok for this application? i can't find a better grade as i've looked all over, but i'd like a stronger grade
1995 ZJ Limited
2008 JK X
Bolt on trailer hitch receiver? Scottsdale Jack TJ Wrangler Technical Forum 22 06-30-2010 07:25 PM
trailer hitch receiver bolt removal???? vosevichs TJ Wrangler Technical Forum 3 01-20-2010 06:01 AM
Mopar hitch size.. help? bpowa TJ Wrangler Technical Forum 3 03-11-2009 12:15 AM
MOPAR trailer hitch / stock tow hook conflict rissacher TJ Wrangler Technical Forum 14 06-05-2005 02:39 PM
Mopar trailer hitch ruckapitjeep TJ Wrangler Technical Forum 5 02-03-2004 07:17 AM
