BEST CB location! - JeepForum.com
post #1 of 31 Old 03-21-2012, 01:32 PM Thread Starter
Tanimal
Tanimal's Avatar
BEST CB location!
Hello all! Just though I'd share my idea. I mounted and wired my Uniden PRO520XL CB radio in the center console! Pretty easy to do and the install came out clean.
Yes....it is in there
Peak-a-boo
As you can see I removed the lock mechanism...mine was broken anyway. (Aren't they all?)
Wires go into the side of the center console and down toward the passengar side firewall and out a rubber gromet onto the battery. The coax goes down and out the back gate gromet.
Don't buy a $30 dollar mount...go buy a stud mount ($8.99) and a L bracket ( $2.79) and make your own like I did. I drilled the L bracket holes bigger for the tire carrier bolt and the stud mount.
How the antenna stands..
All in all this was a fairly easy install and I am very happy how it came out. You can still hear the CB radio fairly well even with the center console closed. I will be mounting an external speaker just above the drivers side seat to make it even easier to hear. Any questions let me know.
Thanks
Learning as I go and it's worth every penny!
Tanimal is offline
post #2 of 31 Old 03-21-2012, 01:52 PM
foolsonparade
foolsonparade's Avatar
Nice Although, it seems like it would be hard to change channels. Other than that, looks good.
foolsonparade is offline
post #3 of 31 Old 03-21-2012, 02:28 PM Thread Starter
Tanimal
Tanimal's Avatar
Nope, just reach under from the top and I have the knobs memorized so I don't even have to open the box
Tanimal is offline
post #4 of 31 Old 03-21-2012, 02:38 PM
4LCKDRUBIUNLTD
2010 JK Wrangler
Nice job. I have the exact same cb & was trying to come up with an idea like that. I ended up just mounting it on the dash.
4LCKDRUBIUNLTD is offline
post #5 of 31 Old 03-21-2012, 03:19 PM
blobo
2010 JK Wrangler
Did you just get rid of the plastic notch on the armrest (right behind where the lock was) to make sure the cb would lie flush in there?
95 ZJ on 33's and 3.5" of lift- Sold
10 JK Wrangler- 2.5" RK Max Travel, 35" NTG's, 17" KMC Enduros, PSC Brawler Lite, PSC BFH Rear, Genright Tire Carrier, JCR Stage II Sliders, RockHard Skids, PSC Tramp Stamp, Line-xd Tub, Cobra CB
blobo is offline
post #6 of 31 Old 03-21-2012, 04:17 PM Thread Starter
Tanimal
Tanimal's Avatar
Yes exactly and if worse came to worse I could take the cb out and put the locking mechanism back in and it still appears to be stock.
Tanimal is offline
post #7 of 31 Old 03-21-2012, 04:41 PM
blobo
2010 JK Wrangler
Very cool! Also sort of dumb but how did you attach the cb to the top of the armrest??
blobo is offline
post #8 of 31 Old 03-21-2012, 05:17 PM
SirWinston
SirWinston's Avatar
That looks awesome! but I feel like it might be kind of hard to hear it since the speaker is facing down into the center console, or is it still pretty loud?
Colorado Jeep Club Member #265
SirWinston is offline
post #9 of 31 Old 03-21-2012, 05:37 PM Thread Starter
Tanimal
Tanimal's Avatar
Haha no its a really good question since it just looks like its floating in there. The sides of the center console lid comes off and then I actually drilled screws into that part of the plastic and then put the side caps back on. Does that make sense?
It is actually pretty loud and if worse comes to worse you could flip the lid open. But that little Uniden BOOMS out noise. I also bought an external speaker just incase and I still havent installed it.
Tanimal is offline
post #10 of 31 Old 03-22-2012, 01:05 PM
blobo
2010 JK Wrangler
I get the part where the console lid comes apart, but how did you get the screws to attach the cb, I think I am just not grasping what teh screws attach to on the cb itself??
blobo is offline
post #11 of 31 Old 03-22-2012, 03:10 PM Thread Starter
Tanimal
Tanimal's Avatar
I get the part where the console lid comes apart, but how did you get the screws to attach the cb, I think I am just not grasping what teh screws attach to on the cb itself??[/QUOTE]
The side of the cb radio has holes for screws for the actual mounting bracket so I drilled the screws and lined them up with those holes in the side of the CB.
Tanimal is offline
post #12 of 31 Old 03-22-2012, 03:18 PM
goldenglory18
****ing brilliant.
Too bad this wont work with a 2011+. I really like sneaky installs....
Gone and I dont miss it at all - 2011 JKU
goldenglory18 is offline
post #13 of 31 Old 03-22-2012, 03:21 PM
GunDude
2011 JK Wrangler
I like above the rear view mirror!
GunDude is offline
post #14 of 31 Old 03-22-2012, 03:26 PM
smcutter
smcutter's Avatar
That is what I am planning to do this weekend. GunDude, how did you run the wires behind the CB unit down to the floor?
For the record, I'm probably judging you for your bad grammar or spelling.
smcutter is offline
post #15 of 31 Old 03-22-2012, 03:27 PM
blobo
2010 JK Wrangler
The side of the cb radio has holes for screws for the actual mounting bracket so I drilled the screws and lined them up with those holes in the side of the CB.[/QUOTE
Ah of course! Thanks for the help!
blobo is offline
VIN Location on frame? Is there more than one location isaacson YJ Wrangler Technical Forum 12 04-21-2011 07:54 AM
06 TCM location roadkill TJ Wrangler Technical Forum 6 05-01-2010 12:12 PM
O2 location rtingley YJ Wrangler Technical Forum 10 04-17-2007 06:43 PM
AMP location? REDPILL TJ Wrangler Technical Forum 13 07-05-2006 09:13 PM
Ecm location YJtittle YJ Wrangler Technical Forum 7 09-04-2005 09:38 AM
