bad shaking during hard breaking - JeepForum.com
post #1 of 23 Old 11-29-2011, 08:54 AM Thread Starter
beachrusso
beachrusso's Avatar
2010 JK Wrangler
Ok here is my issue when I get on the breaks hard on the highway on a secton of damaged or unlevel pavment my jeep will almost jump out of the lane i also get a bad shacking in the break pedal and it feels like the abs is kicking in. What are your thoughts???
Here is my set-up 2010 Rubicon Unlimited 4 inch Rough Country Lift kit and new RC shocks, and 1.25 RC body lift. I also have the dual RC front strearing stabalizers. I am rolling on 20x10 XD wheels with 325x60x20 Nitto dune graplers
BEACHRUSSO
_________
l__l__\____\
l/-\l-_l_/ --*OllllllO*-
\__/ - \____H ___H
(O)__) (O)__)---o-)__)
beachrusso is offline
post #2 of 23 Old 11-29-2011, 09:13 AM
Millermagic
How many miles are on the Jeep and on the rotors? With those big tires (especially if you have an auto), you probably heated up the rotors a few too many times and warped them.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #3 of 23 Old 11-29-2011, 09:18 AM Thread Starter
beachrusso
beachrusso's Avatar
2010 JK Wrangler
8213 miles and it is an auto, pulled rotors last week and had chacked there good
BEACHRUSSO
_________
l__l__\____\
\__/ - \____H ___H
post #4 of 23 Old 11-29-2011, 09:24 AM
GPV
Sounds like warped rotors to me as well. But your tire size has nothing to do with it. Odds are one of the calipers hung up and over heated the rotor, you ride your brakes, or you tried driving around with the emergency brake on. Does the vibration exist in the steering wheel or your seat? If it is the steering wheel then look at your front brakes, if it feels like it is in your seat check your rear brakes (I'm 92.435% sure that is where you will find the problem the rear brakes are crap and get used way to much by the computer for its ESP stuff).
While your larger tires do tax the brakes more they shouldn't warp them for normal driving. It would require something more like this:
Sean
2008 Jeep JK Rubicon Unlimited (Bought for Wife)
2007 GMC 2500HD Duramax (Work Horse)
1982 Honda CB 900F Supersport
2001 Honda RC51
GPV is offline
post #5 of 23 Old 11-29-2011, 09:31 AM Thread Starter
beachrusso
beachrusso's Avatar
2010 JK Wrangler
thanks for the feed back, I just pulled the rotors last week and had them checked at the machine shop they are good no warp. As for the parking break i never use it, as for riding the break i dont as we all know with a lifted jeep and big tires you better leave a little more room to stop. Its a 2010 with less than 8300 miles i think there has got to be something im over looking. I have no pull no vibration in the seat or the wheel it only shackes the break pedal when i stand on the breaks
BEACHRUSSO
_________
l__l__\____\
\__/ - \____H ___H
post #6 of 23 Old 11-29-2011, 11:15 AM
rasbutan
rasbutan's Avatar
2016 JK Wrangler
shake:
1. To cause to move to and fro with jerky movements.
2. To cause to quiver, tremble, vibrate, or rock.
3. To cause to lose stability or waver:
shack:
rasbutan is offline
post #7 of 23 Old 11-29-2011, 11:47 AM
jstrubberg
2009 JK Wrangler
Brake!
jstrubberg is offline
post #8 of 23 Old 11-29-2011, 11:55 AM Thread Starter
beachrusso
beachrusso's Avatar
2010 JK Wrangler
jstrubberg brake?
BEACHRUSSO
_________
l__l__\____\
\__/ - \____H ___H
post #9 of 23 Old 11-29-2011, 12:34 PM
jstrubberg
2009 JK Wrangler
You break a stick in half, you brake in your vehicle when you want to slow down.
post #10 of 23 Old 11-29-2011, 12:34 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
Originally Posted by rasbutan View Post
shake:
shack:
Thank you...I was going crazy. Thought it was just a typo in the title until I saw it several more times
OP - Is the shake ONLY when braking? Or does it happen other times? Do you notice the ESP light kicking on, or the traction light?
Mol is offline
post #11 of 23 Old 11-29-2011, 12:45 PM Thread Starter
beachrusso
beachrusso's Avatar
2010 JK Wrangler
sorry guys its been a long night and day!
only when hard very hard braking, and no esp light or any light at all
BEACHRUSSO
_________
l__l__\____\
\__/ - \____H ___H
post #12 of 23 Old 11-29-2011, 12:46 PM
Mol
Mol's Avatar
Hmmm...sounds like the others are spot on - warped rotors is all I can come up with
Mol is offline
post #13 of 23 Old 11-29-2011, 12:53 PM
ronjenx
ronjenx's Avatar
Does this happen only on damaged or unlevel pavement?
How does it behave on a smooth, level road?
ronjenx is offline
post #14 of 23 Old 11-29-2011, 12:54 PM Thread Starter
beachrusso
beachrusso's Avatar
2010 JK Wrangler
only on damaged or uneven pavement, good roads or normal braking its all good
BEACHRUSSO
_________
l__l__\____\
\__/ - \____H ___H
post #15 of 23 Old 11-29-2011, 12:58 PM
ronjenx
ronjenx's Avatar
That would eliminate any problem with the rotors.
I think you are on the right track when you say it feels like the ABS is kicking in. I would suspect the vehicle erroneously thinks it's entering a skid, and is applying individual brakes, causing the Jeep to dart one way and the other.
The usual cause for this type of sensitivity is a steering wheel out of center.
It could be as simple as a wheel skidding when you brake hard on the damaged and uneven roads. The ABS would kick in then, too.
ronjenx is offline
Engine shaking my JK & shifter shaking Zak77 JK Wrangler Technical Forum 3 06-28-2011 06:19 PM
Have 35's Want 37's. Anyone breaking axles wheelin' hard? hifiguy7 JK Wrangler Technical Forum 13 04-06-2009 12:33 AM
Shaking in 06 sport when accelerating hard 2006_Sport TJ Wrangler Technical Forum 11 03-12-2009 09:11 PM
Hard Breaking Causes Swerve! Why? Manezinho TJ Wrangler Technical Forum 4 10-01-2008 10:51 AM
Clicking Noise When Breaking Hard tennisjon2002 YJ Wrangler Technical Forum 8 02-20-2005 10:26 AM
