Air conditioning staying on !!!! Please help - JeepForum.com
post #1 of 9 Old 09-22-2020, 01:46 PM Thread Starter
verrelli
hey guys, i have a 2011 jk wrangler and air con stays on all the time , switch ac switch on and off works, if switch is off ac compressor is still powered from tipm module wire Lbu/yl, if i disconnect hvac module im still getting an earth input from the powertain module on pin 6 of tipm module, i cant find what inputs powertain module for ac ??
has anyone had this issue before ?
verrelli is offline
post #2 of 9 Old 09-22-2020, 02:27 PM
jtec
jtec's Avatar
2014 JK Wrangler
does this only happen with a remote start?
jtec is offline
post #3 of 9 Old 09-22-2020, 02:41 PM Thread Starter
verrelli
its key start
verrelli is offline
post #4 of 9 Old 09-22-2020, 04:59 PM Thread Starter
verrelli
i take it nobody has had this problem ?
verrelli is offline
post #5 of 9 Old 09-22-2020, 06:55 PM
ronjenx
ronjenx's Avatar
Past threads about the AC staying on were related to having the selector in the defrost position. Your issue appears to be more complicated than that.
2008 JKU Rubicon
42RLE Auto
ronjenx is offline
post #6 of 9 Old 09-23-2020, 07:41 PM Thread Starter
verrelli
getting a p0645 code open compressor control circuit on live readout status is false. sw operating perfect so it has to be one of modules tipm or powertrain
verrelli is offline
post #7 of 9 Old 09-24-2020, 02:45 AM Thread Starter
verrelli
ok i have disconnected every sensor and module for ac and as soon as i plug 50 pin plug in i have power out to clutch coil, have alsop tried a new tipm module with no luck.
note i have had dash cluster and hvac module disconnecteed along with every other sensor
pulling my hair out with this one bloody jeeps!!
verrelli is offline
post #8 of 9 Old 09-24-2020, 05:21 AM
jtec
jtec's Avatar
2014 JK Wrangler
P0645 seams to be the issue, did you chase the CIRCUITS and follow trouble tree?
I hate doing this -- check attachments 'trouble tree' they are often to advanced for the average DIYer.
Anyway hope it helps...
FYI I asked about remote starting because there was a TSB for that...
jtec is offline
post #9 of 9 Old 09-24-2020, 07:06 AM Thread Starter
verrelli
only getting live ac control circuit open code when engine running only, with igntion on nothing, even though it says open and live switch staus is turning on and off with my command ac clutch plug still has power at it, its a weird one.
verrelli is offline
jk , wrangler
