2017 jk - JeepForum.com
 2Likes
  • 1 Post By 222Doc
  • 1 Post By cranbiz
post #1 of 8 Old 11-27-2019, 08:10 PM Thread Starter
RossBoss
2017 jk
How much Body lift can I put in this 2017 without having much modification ?
RossBoss is offline
post #2 of 8 Old 12-03-2019, 09:12 AM
222Doc
222Doc's Avatar
Why? Considering the design of the JK compared to the TJ and all jeeps ever made before it. There is no good reason to raise the body up on a JK. You could do a Flat belly on a JK and not need a BL. Tj that is not possible. A jk only needs 2.5 lift to fit 35s. a Tj needed 3.5 + 1.5 of BL to roll 35s. Much of this is since it was the way before it must be now. A jk can 37+ and still not need BL. even 40s. though at 40s the whole jeep needs changes that are well super expensive and still no body lift needed.
This is one of those mods that though can, should you. Much like running twin steering stabilizer, you can but why. My thoughts on this anyway. I am sure someone will say how great it is. But a reason why? other then makes my taller then the next guy?
JoonHoss likes this.
222Doc is offline
post #3 of 8 Old 12-03-2019, 09:24 AM
cranbiz
cranbiz's Avatar
No need to add a body lift, a JK with a small lift ~3" clears 37's easily. If you do decide to add one, it leaves ugly gaps between bumpers, etc.
06 KJ
12 JK, 2.5" Teraflex lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #4 of 8 Old 12-06-2019, 11:27 AM
JTPhoto
JTPhoto's Avatar
2017 jk
I run a 1.25” TF body lift to give that little extra without affecting the suspension components. Also allows me to use less bumpstop for 37” tires.
And yes 37” Pitbulls require the extra room even with flat fenders.
Sent from my iPhone using Tapatalk
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #5 of 8 Old 12-08-2019, 10:10 PM
Geoskier9
Junior Member
Geoskier9's Avatar
Rough country’s 2.5” lift is inexpensive and gives more clearance with minimal modification, better than a BL... As said before you can squeeze 35’s
Geoskier9 is offline
post #6 of 8 Old 12-09-2019, 01:32 PM
cranbiz
cranbiz's Avatar
I would rather see the OP with a 1" body lift than recommend a Rough Country anything.
06 KJ
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #7 of 8 Old 12-11-2019, 12:07 PM
Geoskier9
Junior Member
Geoskier9's Avatar
Fair enough
post #8 of 8 Old 12-14-2019, 11:57 PM
Prot
Prot's Avatar
2014 JK Wrangler
What size tires do you want to run? What kind of budget are you on?
Body lifts on a JK don’t make much sense. They might make sense sometimes on old models. If the reason for wanting a body lift is because you are on a shoe string budget, then a budget boost also known as a spacer lift or hockey pucks are the way to go instead.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
