2015 jk coolant smell - JeepForum.com
post #1 of 12 Old 01-04-2020, 11:01 PM Thread Starter
Rekcedevets
Rekcedevets's Avatar
Iíve had my JK for a bit now, and I keep getting a coolant smell no matter what time of the year. No visible leaks, even swapped the radiator, and cap.. even did the plastic baggie under the overflow cap trick.. still smells from time to time. Any of you got a clue?
Thanks
Rekcedevets is offline
post #2 of 12 Old 01-04-2020, 11:07 PM
Brianscj5
You might have a leak on the left side radiator tank. I had to get under mine and looked up to even see it.
Sent from my ONEPLUS A6013 using Tapatalk
Brianscj5 is offline
post #3 of 12 Old 01-04-2020, 11:21 PM Thread Starter
Rekcedevets
I put a new radiator in, and it still smells. ..
post #4 of 12 Old 01-05-2020, 02:57 AM
olmoggy1
olmoggy1's Avatar
1937 CJ2A
My 15jk has 20,000 miles it smells and there are no leaks
Sent from my iPhone using Tapatalk
olmoggy1 is offline
post #5 of 12 Old 01-05-2020, 09:25 AM
222Doc
222Doc's Avatar
rads in these are junk really. mine has the smell 37k. im thinking toss the fiat pill in it call it good until i can see it leak. might be a water pump? loose hose?
222Doc is offline
post #6 of 12 Old 01-05-2020, 04:12 PM
JCWrangler
I got lucky on our ‘14. Chased the smell forever. Lost little coolant. But when crawling it started dripping on the differential. I kept laying under it at every stop and finally found the drips coming off the overflow/recovery tank. New bottle and we’re good. Never could see anything after a highway run but crawling it didn’t blow away.
JCWrangler is offline
post #7 of 12 Old 01-05-2020, 10:50 PM Thread Starter
Rekcedevets
Iíll have to look at the tank.. I did put a line on the tank a bit ago and it does seem to be losing a little bit. bugs the crap out of me. Everything appears to be dry around the pump.. and the hoses are all good too.
Iíll crawl under it tomorrow after my drive home.
Thanks guys!
Steve
post #8 of 12 Old 01-06-2020, 07:17 PM
219Jeep
2015 JK Wrangler
My 2015 has the same smell, replaced radiator & thermostat assembly ( housing was cracked) still slightly smells. I also loose a small amount of coolant, but no leak, and no sign of water in oil.
219Jeep is offline
post #9 of 12 Old 01-07-2020, 06:57 AM
pismo61
pismo61's Avatar
Ok. whats the fiat pill?
2013 Red 2 Door Auto.
pismo61 is offline
post #10 of 12 Old 01-12-2020, 10:44 AM
pete1182
2016 JK Wrangler
2016 here. Have same smell. No leakage observed. Or loss of coolant level.
pete1182 is offline
post #11 of 12 Old 01-12-2020, 02:54 PM
RedRubiconLJ
RedRubiconLJ's Avatar
2015 JK Wrangler
Mine cracked about 3 inches below the top on the driver side tank. Just enough to keep the over flow tank empty. It was covered by everything, couldnt see it. I could see dried residue but never a drip or steady leak because it would burn off dry up before it hit the ground. I replaced mine at 48k miles when my temp guage went up higher than normal.
2015 Red JKU Rubicon RK X-factor, Adams, Rockhard4x4, PSC, LoD, BFG, WARN
SOLD 2013 JKUR
Sold 2005 Rubi Unlimited
2004 TJ sold
1993 YJ sold
RedRubiconLJ is offline
post #12 of 12 Old 01-12-2020, 03:35 PM
Pine_Cat
Pine_Cat's Avatar
This may be what he had in mind :
2017 JK
2016 MK- Murchison springs, ~1" BL, skinny 30s
2011 KK- H&R lift springs, OldManEmu shocks/struts, skinny 31s
2009 Sorento- H&R springs, ToyTec strut spacers, OldManEmu shocks/struts, 31s
2006 TJ budget LCG prerunner- see profile
2006 Trailblazer- EXT lift, Nth LJ 4.5" springs + Monroe rear coilovers, skinny 32s
1998 Durango- SuspMax & Roadmaster lifts, rear Truetrac, skinny 32s
Pine_Cat is offline
