2014 wrangler unlimited ampd trim question - JeepForum.com
 1Likes
  • 1 Post By amped
post #1 of 11 Old 07-21-2021, 05:43 PM Thread Starter
amped
I'm having a hard time pulling out the rear axle. Removed the 4 nuts holding the retainer, moved abs sensor out of the way, put rotor back on inside out, put on 3 wheel nuts and gave it a few hard pull but couldn't get it out. From some of the youtube videos, they didn't have to pull it hard at all.
How hard should I pull? I'm afraid I might damage something if I really yank on it.
amped is offline
post #2 of 11 Old 07-22-2021, 06:21 AM
222Doc
222Doc's Avatar
well a axle puller puts more force on it. basically a big slide hammer. some go easy some not.
222Doc is offline
post #3 of 11 Old 07-22-2021, 08:25 AM
cranbiz
cranbiz's Avatar
Go to O'Reilly's, Advance, Auto Zone or your favorite Auto parts store and get the loaner axle puller. You will have the axle out in a couple bangs of the slide hammer.
Both of mine axles needed that additional help in pulling the axles.
02 WJ Laredo, heavily optioned but stock
12 JK, 3.5" Teraflex/Franken lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #4 of 11 Old 07-23-2021, 11:50 AM Thread Starter
amped
Sliding hammer did the trick. Nothing beats using the right tool for the job.
So... any jeep brothers/sisters out there that have a shop press in the madison, wi area that can help me out with installing the bearing?
amped is offline
post #5 of 11 Old 07-23-2021, 12:27 PM
222Doc
222Doc's Avatar
well HF has them rather low cost today. nice to have one. I have used mine many many time its paid for its self easy by now. Right tool for the job makes the job so much easier.... to that end i just by the tools. they tend to last a life time and save you lots of pain.
if no one is near you most shops will do this for not to much its rather easy with a press. Have you cut the old ones off yet? That is harder part really. cutting the collar then the bearing not all the way just enough so a chisel pops it off by breaking the last bit. Use 4" angle grinder and thin curf blade.
222Doc is offline
post #6 of 11 Old 07-23-2021, 12:50 PM Thread Starter
amped
Yea, I may have to get one from HF since most places I call want somewhere between 50-75. Might as well put them right into the tool .
222Doc likes this.
amped is offline
post #7 of 11 Old 07-23-2021, 02:09 PM
cranbiz
cranbiz's Avatar
Don't waste your time with the 5 ton bench press. go for the 12 ton or the 20 ton. Don't ask me how I know.
Agree with Doc, great tool to have around the shop. I use it frequently.
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #8 of 11 Old 07-23-2021, 03:01 PM
222Doc
222Doc's Avatar
the 12 ton at least on d44 axles is not quite tall enough. I had to raise mine off the floor about 2". It as well near maxed out pressing my axles bearings on. It did it just a 20 ton would have been the better choice. But over all its not bad for what it cost back then. bet they are much more today. BUT still worth it if you like to do stuff in the shop. save $$$ on labor.
222Doc is offline
post #9 of 11 Old 07-25-2021, 05:20 PM Thread Starter
amped
Bought the HF 20 ton shop press. Not a quality press but will do for the average usage at home.
Cut off old bearings and put new one in. Went to press it, a little over half way, heard a loud pop. Is this normal?
amped is offline
post #10 of 11 Old 07-26-2021, 10:41 AM
cranbiz
cranbiz's Avatar
Yes
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #11 of 11 Old 07-27-2021, 12:03 AM Thread Starter
amped
Originally Posted by cranbiz View Post
Yes
Awesome, good to know I didn't break anything. Thanks for all the help.
amped is offline
