2010 misfiring. Dealership suggesting new engine - JeepForum.com
post #1 of 4 Old 10-17-2021, 09:56 AM Thread Starter
Bobbyc60
Help! 2010 wrangler 100k miles nothing wrong with jeep,, but took to shop and had them do tune-up. Spark plugs, wires, oil all changed. Ran great for 2 week, now running rough and misfire. Took to dealership
Here what they saying
Bobbyc60 is offline
post #2 of 4 Old 10-17-2021, 10:03 AM Thread Starter
Bobbyc60
Found injector 4 and 6 flooding and replaced them. Still misfiring . Check compression on 2 4 6 psi 150. However when run cylinder 4 psi 35. Dealership wants to replace engine .
Bobbyc60 is offline
post #3 of 4 Old 10-18-2021, 11:27 AM
cranbiz
cranbiz's Avatar
If Cyl 4 is showing a 35 PSI compression, that's not good. It may need rings, it may have bad valve guides, valve seals or a leaking valve. If it's a head, that's a much cheaper option than an engine. If it was me, I would push them to determine if it's just a head or if it's something more serious.
02 WJ Laredo, heavily optioned but stock
12 JK, 3.5" Teraflex/Franken lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #4 of 4 Old 10-18-2021, 12:04 PM
222Doc
222Doc's Avatar
leak down test number 4. air will tell you if its valve or ring issue.
222Doc is online now
