2010 Jeep Jk Rubi Electrical issue - JeepForum.com
post #1 of 6 Old 03-09-2019, 08:12 PM Thread Starter
Yousef Maqousi
Yousef Maqousi's Avatar
Pardon me if I’m posting this in the wrong place. If so let me know and I’ll move it. I’ve got a 2010 Rubicon and recently it’s doing some crazy stuff. I’ve worked on cars my entire life but electrical has never been my strong suit.
So about a month ago my Jeep started randomly not starting. It acted like the battery was dead but it wasn’t. Headlight switches, dash lights, radio, ignition switch, power locks, key fob, windshield wipers, turn signals and hazards stopped working. Put the key in and literally nothing happens. Checked all the grounds, battery and alternator and everything’s working as it should be. Here’s where things get wired. It will randomly come back to life. Sometimes it cranks and everything’s fine and after sitting an hour or so it becomes a paperweight. Only to wake up when it feels appropriate. For awhile I could pull the ground off the battery or pull the WCM fuse to reset it and it would work. But that proved fruitless the last time it acted up. I’ve done some research and I’ve narrowed it down to either the Wireless Control Module, ECM or TIPM. I just need some help diagnosing the issue. I’m strapped for cash at the moment and would like to avoid the dealership ghost hunt. Any advice is greatly appreciated. I have videos of what it’s doing if that helps.
Yousef Maqousi is offline
post #2 of 6 Old 03-10-2019, 10:09 AM
jtec
2014 JK Wrangler
This is basic trouble shoot for a technician, with a test light and a wiring diagram go thru the starting circuit when issue arises.
WCM and ECM are low on my suspect list.
jtec is offline
post #3 of 6 Old 03-11-2019, 06:52 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
You can't move it so I'll move it for you.
Joe Dillard is offline
post #4 of 6 Old 03-19-2019, 10:47 AM Thread Starter
Yousef Maqousi
Thanks, I’ll pull a wiring diagram and get started.
post #5 of 6 Old 03-20-2019, 03:25 PM
propped1
propped1's Avatar
MIne did this... when I needed an alternator. My Jeep stopped running on city street... when I needed a battery. Youd think it was the other way around.
Basically, the JK computer is super sensitve to voltages and wont let it start. If you pull the batt fuse or disconnect the red wire, and reattach, it is like a reset and itll pop off. Trying to diagnose batt/alt in a JK is not intuitive. The advance auto parts tool is not accurate. Isolate and test. Do a real diagnosis. When I needed an alternator, they scanned and told me I needed a battery. Bought new Optima. week later doing same thing.... Batt dead. Alternator was what was wrong.
My current set up is an Optima Yellow and a mean green 220 with XS big 3 0 guage and a NOCO batt tender connected when parked. Havent had a problem since 2014. Hard wheeling with lots of winching.
4" lift, PR 44, PR 60, 5.13, 37 Toyo MT, ATX Slabs, Skids, PSC Big Bore, 2Way
propped1 is offline
post #6 of 6 Old 03-20-2019, 08:41 PM
JTPhoto
JTPhoto's Avatar
The older (3.8L) version JK requires a good engine block ground for both the neutral safety switch and the starter. Try running a 4 gauge ground cable from the battery negative terminal to the alternator bracket.
You can do a quick check with a jumper cable from negative battery to alternator bracket to see if it solves your problems. All 3 of our pre 2012 JKs required the extra ground cable.
Sent from my iPhone using Tapatalk
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3853 02-12-2019 09:15 AM
Jeep YJ power issue from mid to full accelerator when warmed up.. YJZA YJ Wrangler Technical Forum 6 02-03-2019 05:53 AM
5 Jeep Wrangler JK Factory Wheels Like New: $500 kcall333 Tires & Wheels 0 08-23-2018 05:04 PM
Door electrical issue Aero540t WJ Grand Cherokee Forum 0 07-21-2018 08:55 PM
How to install an RB1 navigation unit in a 1997-2001 Jeep Cherokee Country Jeep XJ Cherokee Technical Forum 14 01-21-2018 04:43 PM
