2008 JK Starting Problems - Page 5 - JeepForum.com
 1Likes
post #61 of 103 Old 08-24-2012, 05:44 AM
Callan74
I want try this fix to the "external circuit" today, so does anyone know where the TRS connector is located? Do I need to pull the tranny pan?
thanks..
Callan74 is offline
post #62 of 103 Old 08-24-2012, 07:21 AM
VEGASROBBI
VEGASROBBI's Avatar
thanks..
Bright green 10 pin connector on the side of the transmission, no need to pull the pan.
MoTech
LS Specialists
500 South Buffalo Drive, Las Vegas NV 89145 702-491-7710
www.LSWrangler.com
VEGASROBBI is offline
post #63 of 103 Old 08-24-2012, 08:57 AM
ronjenx
ronjenx's Avatar
For those whose engine will start by shaking the shift lever, moving to neutral, or pushing the lever more into Park, there is still the possibility it's only a matter of the linkage being out of adjustment.
Most of the time when that's the case, there will not be a click at all; not even a faint clicking of the starter relay in the TIPM.
ronjenx is offline
post #64 of 103 Old 08-24-2012, 09:31 AM
Callan74
Thanks!
Callan74 is offline
post #65 of 103 Old 08-24-2012, 11:49 AM
PlatinumOre
PlatinumOre's Avatar
I've been stuck in park and neutral a few times and having starter issues, when i have these issues i found that get out put my foot on the tire and give it a good rock.... or sit in it and look weird and try to rock it that way will work 80% of the time, the other times i mess with the shifter and it works.
Some one told me linkage or neutral sfatey switch? without reading all the posts in this 4page thread.
PlatinumOre is offline
post #66 of 103 Old 08-25-2012, 09:15 AM
Callan74
Cool..any idea's where yo ground this wire?
Callan74 is offline
post #67 of 103 Old 08-25-2012, 09:17 AM
ncb
ncb's Avatar
Clean bare metal.
ncb is offline
post #68 of 103 Old 08-25-2012, 09:31 AM
Callan74
Originally Posted by ncb View Post
Clean bare metal.
I deserved that. Under jeep now.
Callan74 is offline
post #69 of 103 Old 08-25-2012, 12:22 PM
Callan74
Works so far
Callan74 is offline
post #70 of 103 Old 08-26-2012, 07:07 AM
Callan74
So to follow up...jeep started all day no issues...(10-15 times ) Seems like grounding #10 pin on the green connector was a good fix...
FYI..I added the additional engine ground fix (from other posts) last weekend and it didn't seem to fix my starting issues
Callan74 is offline
post #71 of 103 Old 08-26-2012, 08:54 AM
ncb
ncb's Avatar
Grounding that pin bypasses the TRS so it will start.
ncb is offline
post #72 of 103 Old 08-26-2012, 11:28 AM
Callan74
Really??? This post was for the masses as a fix that seems to work.
List of what I did to find a remedy
New yellow top battery
New starter
New alternator
Added additional ground wire to battery and engine
Finally fixed problem--grounding #10 wire. (Thanks Vegas!)
C
Callan74 is offline
post #73 of 103 Old 08-26-2012, 03:31 PM
wbp
starter problem
I have a 2008 4dr wrangler and I have been having starter problems for about a yr. I got it almost 2 yrs ago. About once every few months, I go to start it and just here clicking sounds. I can't shift the car out of Park and need to jump start the car, which it usually does immed. with no problem. Now its happening every few days...any suggestions?
Thank you...also, I am brand new to the forum...sorry if I posted this improperly!
wbp is offline
post #74 of 103 Old 08-26-2012, 06:03 PM
ncb
ncb's Avatar
New starter
New alternator
C
I understand. It seems like a patch instead of a true fix since it will now start in any gear. Sorry to bother. Checking out.
ncb is offline
post #75 of 103 Old 08-26-2012, 06:05 PM
Callan74
Need to turn the key to the "on" position to shift out of park. After you do this..shift through the gears and it should start. I dealt with this for a few months until recently (like yesterday) I did the fix in my post above.
C
Callan74 is offline
JK Wrangler , starting issue , starting problem , starting trouble , wont start , wrangler
Having Problems Starting My 2008 Jeep - Please Help! Oceana JK Wrangler Technical Forum 4 09-12-2009 01:31 PM
starting problems wesleyrobbin YJ Wrangler Technical Forum 3 09-03-2009 05:27 PM
2.5L starting problems. bob082484 YJ Wrangler Technical Forum 3 04-09-2009 07:59 PM
89 2.5 starting problems..please help :( J13760 YJ Wrangler Technical Forum 2 03-02-2006 03:29 PM
Starting problems gray420 TJ Wrangler Technical Forum 8 05-03-2005 12:59 PM
