16s vs 17s on lifted Jk - JeepForum.com
post #1 of 8 Old 02-15-2015, 07:02 PM Thread Starter
JASJ
I am pondering the decision for wheels and tires. I've got a Rockrawler2.5 stock mod with other suspension additions, raised about 3" from stock and flat fenders. Running 33s now, good winter set up in Park City(when it behaves like winter!) on Duratracs.
With tire sizes cheaper in 16" and with some good options on alloys even with Goodyear MTRs I can get in on five with 35" tires for $400 cheaper than 17".
I expect a bit less connection to the pavement with 16s but really noticeable? Off-road? What are the advantages or disadvantages there? I assume more tire and less rim are an advantage there, I'm a novice off road.
JASJ is offline
post #2 of 8 Old 02-15-2015, 07:14 PM
christensent
2014 JK Wrangler
17's better on-road because less rubber. 16's better off road if aired down because there is more rubber that can adjust to the terrain. If you don't air down, it doesn't really matter offroad. Regardless of the scenario, an inch isn't going to make or break anything.
christensent is offline
post #3 of 8 Old 02-15-2015, 07:19 PM
Duh
The only real big difference is that you tend to have more tire options at 17. Its kind of the new De facto standard nowadays where it used to he 15. That one inch of rubber doesn't make a huge difference in the ride, but some rockcrawlers would still prefer the 15s to get as much rubber as they can.
Duh is offline
post #4 of 8 Old 02-16-2015, 02:54 PM
duneslider
duneslider's Avatar
There are fewer tire options for 16's that 17's. If you are fine with that, the only other real draw back is you can't do the big brake kits on with 16" wheels, that may not matter for you either.
I am running 15" wheels but the tire options are not great.
duneslider is offline
post #5 of 8 Old 02-16-2015, 06:26 PM Thread Starter
JASJ
Tire options seem good with 34-35" range on tire rack. I'm even considering the Kuhmo MTs and $75 less per tire than GY MTRs. Ratings on Tirerack similar or better for the Kuhmos
JASJ is offline
post #6 of 8 Old 02-17-2015, 11:32 AM
Z-OR
I am struggling with this as well for a 35" tire.
The 16" package is going to be lighter. The 16" seems cheaper as well.
16" MAY be better offroad, but if it is, I would never notice.
I also see 17" gaining popularity, but not seeing 16" going away and am seeing plenty of choices.
Keep the opinions and pics coming...
Z-OR is offline
post #7 of 8 Old 02-17-2015, 02:54 PM
BlueBabySound
2018 JK Wrangler
If you plan on brake/rotor upgrades you'll need at least a 17"
BlueBabySound is offline
post #8 of 8 Old 02-19-2015, 03:56 PM
AJKJK
I say 17".
AJKJK is offline
