07 JKU Sahara power windows problem - JeepForum.com
post #1 of 15 Old 03-31-2020, 03:29 PM Thread Starter
phil1031
I can't figure out what is going on with my windows. All four of them will not go down and it just makes a buzzing sound when I push the button. I thought that maybe it was the switch module, so I replaced it. It still did the same thing. Here is a clip of what it does. Any ideas?
Thanks,
Phil
phil1031 is offline
post #2 of 15 Old 03-31-2020, 03:31 PM
Moezer
2015 JK Wrangler
Is that buzzing from the switch it self or the door motor
Sent from my SM-N950W using Tapatalk
Moezer is offline
post #3 of 15 Old 03-31-2020, 03:33 PM Thread Starter
phil1031
It's coming from the switch itself
phil1031 is offline
post #4 of 15 Old 03-31-2020, 03:44 PM
Moezer
2015 JK Wrangler
Have u tried to reconnecting it then reconnecting
Moezer is offline
post #5 of 15 Old 03-31-2020, 03:53 PM Thread Starter
phil1031
Yeah, I have tried that....I also tried the hard reset thing with the battery.
phil1031 is offline
post #6 of 15 Old 03-31-2020, 03:55 PM Thread Starter
phil1031
Any chance it could be the fuse? I took the fuse out to see what happens and that just kills it completely.
phil1031 is offline
post #7 of 15 Old 03-31-2020, 03:56 PM
Moezer
2015 JK Wrangler
Take it apart unplug it then bypass the switch with a wire to roll down the windows that way if that works then its ur switch or check ur relay if it has one
Moezer is offline
post #8 of 15 Old 03-31-2020, 04:16 PM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
Did it always have this problem?
Other words, did the windows roll down for you, then stop working one day?
Hoss
Good judgement comes from experience; experience comes from bad judgement
JoonHoss is offline
post #9 of 15 Old 03-31-2020, 04:18 PM Thread Starter
phil1031
Hoss
They use to work fine. Then at one point, it would do the buzz thing, and not work off and on....now its all buzz.
phil1031 is offline
post #10 of 15 Old 03-31-2020, 05:16 PM
ronjenx
ronjenx's Avatar
The "fuse" for the windows isn't a fuse. It's a mechanical circuit breaker.
Have someone actuate the window switch briefly while you see if the circuit breaker buzzes or vibrates.
2008 JKU Rubicon
42RLE Auto
ronjenx is offline
post #11 of 15 Old 03-31-2020, 05:35 PM Thread Starter
phil1031
Ok, so I did hear a faint "electrical" sound coming from the fuse box. I pulled out the circuit breaker and I could still hear that sound, BUT after pulling it out , the switches are completely dead. They don't do anything. I'm assuming that is because there is now no power going to the switch at all. Should I replace the circuit breaker? Could there be something wrong with it?
phil1031 is offline
post #12 of 15 Old 03-31-2020, 05:44 PM
ronjenx
ronjenx's Avatar
Did you listen to and feel the breaker while someone actuated the switch?
2008 JKU Rubicon
42RLE Auto
ronjenx is offline
post #13 of 15 Old 03-31-2020, 05:52 PM Thread Starter
phil1031
Yes, they couldn't feel anything or hear anything specifically from the breaker. Now, I thought it was all four switches that did this, but it is actually the front window switches that do the buzzing thing. The rear windows do absolutely nothing.
phil1031 is offline
post #14 of 15 Old 03-31-2020, 08:10 PM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
...I thought it was all four switches that did this, but it is actually the front window switches that do the buzzing thing. The rear windows do absolutely nothing.
What about the switches on the rear of the console for the rear windows; do they do anything?
Hoss
JoonHoss is offline
post #15 of 15 Old 03-31-2020, 08:37 PM Thread Starter
phil1031
Hoss
No, they don't do anything at all
phil1031 is offline
