ZDDP - JeepForum.com
 7Likes
  • 1 Post By 2jhanna
  • 3 Post By Jerry Bransford
  • 3 Post By Jo3Gee
post #1 of 11 Old 07-11-2020, 07:48 PM Thread Starter
dadsterd
ZDDP
Maybe opening a can of worms on this one...
Any thoughts about using a ZDDP additive in oil? Does the RPM warrant it? Rebuilding engine and cam is definitely worn. It's a 97, so is it age, age+lack of zinc? Any thoughts?
Thanks in advance for your thoughts.
dadsterd is offline
post #2 of 11 Old 07-11-2020, 07:57 PM
2jhanna
I believe some guys use Rotella that want more zinc.
BlueFl.Wrangler likes this.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #3 of 11 Old 07-11-2020, 08:07 PM
Jo3Gee
Jo3Gee's Avatar
ZDDP
Lol yeah, can of worms. In my experience with rebuilding motors, I use zink break in oil only for break in. After break in, I donít see the benefit to continued use in a standard build. That said, I built my stroker with high compression and no cats, and I use high zink race oil in it (valvoline vr-1).
You will get many other opinions though...
Jo3Gee is offline
post #4 of 11 Old 07-11-2020, 09:42 PM
downs
downs's Avatar
1995 XJ Cherokee
Currently (subject to future change) most diesel oils have old school levels of ZDDP. Nowadays they came in lighter weights as needed if you are looking for lighter than 15w40 weights.
1995 Jeep Cherokee Country 4X4 Stock
AW4/NP231/C8.25/D30/"UpCounty" suspension
downs is offline
post #5 of 11 Old 07-11-2020, 10:09 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Definitely not needed or beneficial on our old low performance and low compression engines. The usual engine oils we use in our engines have enough zinc. Zinc wasn't eliminated from our engine oils, its amount was just reduced enough to not wreck the catalytic converter. That there's still enough zinc remaining is backed up by how reliable and relatively reliable our engines are with no problems with cams, lifters, bearings, etc. Mean time to overhauls are usually never before 250k miles. If our engines weren't being properly protected with the usual Valvoline, Mobil, Castrol, NAPA, etc. engine oils, conventional or synthetic, that would not be the case.
Now if I had a high compression high performance engine with stiff valve springs etc. I'd definitely be running something with extra zinc. But in my 2.5 or 4.0 engines? Nah, it's just not needed or of benefit. The outstanding reliability of our Jeep engines backs that up.
bonza, jbrubi05 and jtec like this.
Jerry Bransford is online now
post #6 of 11 Old 07-11-2020, 10:46 PM
Russ Chung
Russ Chung's Avatar
X2.
I have 420,000 miles on my 2005 TJ. I've always used Mobil 1. Lately, I've been using Mobil 1 High Mileage, which has a bit more ZDDP than the regular or Extended Performance versions of Mobil 1. The compression is a bit low; I think I may need a ring job sometime soon, but no problems with the cam or lifters.
If you don't like the way I drive, stay off the sidewalk!
KI6MLU
Russ Chung is offline
post #7 of 11 Old 07-12-2020, 04:08 AM
Jonny Jeep
Jonny Jeep's Avatar
I don't have the link but I can across a website a while back where the guy had built up data from all the oils he'd been testing and in some cases higher zinc oils had more wear evident.
Jonny Jeep is offline
post #8 of 11 Old 07-12-2020, 08:39 AM
pwmac
The ZDDP craze first appeared when it was discovered that the then new API oils greatly reduced the stuff due to degrading the cat converters. Now days oils including diesel oils have very low to no amount of ZDDP. The latest oils have other chemicals to reduce wear and most all will be fine for your motor.
The first oils that had these modern additives were European ones certified to ACEA. Check your oil bottle label. Most versions of Mobil1 are certified to various levels of ACEA that are dependent on how the motor is used.
M1 Advanced Full Synthetic tested out to have high strength for resisting wear.
pwmac
Durango, CO
06 Rubicon, modified
pwmac is offline
post #9 of 11 Old 07-12-2020, 08:55 AM
Jo3Gee
Jo3Gee's Avatar
ZDDP
Iím a big fan of Mobile 1 full syn (after break in). This is a pic under my valve cover (standard build, not my stroker) after 150k miles using only M1.
Russ Chung, dadsterd and downs like this.
Jo3Gee is offline
post #10 of 11 Old 07-12-2020, 01:23 PM Thread Starter
dadsterd
Thanks for all the replies. Yes, I too have been liking Mobil1, but that pic is worth a thousand words!! Looks great. Ok, so I'll try some ZDDP only at break in and no more.
dadsterd is offline
post #11 of 11 Old 07-12-2020, 02:23 PM
Jerry Bransford
Administrator
It looks the same after 200k miles with Valvoline conventional.
