Your Opinion on my lift ideas? Please help - Page 17 - JeepForum.com
 1Likes
post #241 of 251 Old 07-24-2016, 11:01 AM Thread Starter
Trevlaw
Trevlaw's Avatar
Here are some pictures I took yesterday with the driver's side at full bump and the passenger side drooped a little over 2" of my 4" possible down travel right now.
IMG_20160723_191138.jpg   IMG_20160723_192758.jpg   IMG_20160723_192812.jpg   IMG_20160723_192834.jpg   IMG_20160723_192841.jpg
I want a J-Series
TJ Build:
Trevlaw is offline
post #242 of 251 Old 08-01-2016, 09:21 PM Thread Starter
Trevlaw
Trevlaw's Avatar
Originally Posted by jjvw View Post
Is the frame entirely elevated on jack stands? I only see one. Is opposite side hanging at full shock extension.
The shocks and BB aren't your limit. It's the 33" tires at full flex that will scrape the fenders.
Our front ends are too similar to be that different. My bumps are about as short as they can be.
For what you are planning, you need to make sure you can correctly identify your interferences. Again, something isn't adding up or I'm not seeing something on yours.
Well, jjvw I'd like to apologize for coming across as a jerk. You were right about the tires not clearing. When I had my front end torn apart today I did put the passenger side to full droop and try to stuff the drivers side tire again and it rubs the inner fender where the flare bolts to the body. I was too lazy to cut the extensions down, so I threw in my old 1.5" BS extensions from the BB kit and they now stuff with very minimal rubbing on the flares and won't damage anything. You were right about the clearances with tires, but I'm not gonna toy with it anymore, just leave it as is since hopefully I'll be changing a lot of it soon.
I did also pull both springs and tires and put it to complete factory bump before I put in the extensions and everything cleared, no interference with the steering or the new ZJ tie rod. With the 1.25" BL the 33's are pretty close to clearing the fenders at full factory bump, so I'm going to see if I could modify them at all or maybe see if just flat fenders, not highlines, could give me enough clearance or just allow them to rub a tiny bit without hurting anything.
Still planning on pushing forward with the shock mount ideas, I don't see why I can't fit 12" shocks underneath there or maybe even longer ones. Maybe some 14's or 15's
I want a J-Series
TJ Build:
Trevlaw is offline
post #243 of 251 Old 08-01-2016, 09:59 PM
jjvw
jjvw's Avatar
The important part is that you found it.
FWIW, I recently discovered that the drag link joint where it connects to the tie rod will hit the axle side passenger sway bar mount at full droop if you try to turn right. Took me two years to find that one.
Regarding your long shocks, how high up can you raise the upper mounts (front and rear) before the body gets in the way? That's a question I'm pondering right now. The answer you are comfortable with will help determine how much travel you can add.
2003 Rubicon
jjvw is offline
post #244 of 251 Old 08-01-2016, 10:13 PM Thread Starter
Trevlaw
Trevlaw's Avatar
I'll have to check that drag link joint sometime soon.
From looking at the inner fender with my 1.25" BL I feel pretty confident that I can hack off the top of the factory mount and weld in a ford mount with an eyelet mount about 4" higher than the factory one. I think the more rearward side of the inner fender may need to be hit with a hammer to clearance it to allow a bolt to be put through the ford mount, but that shouldn't be too hard. A lot of the threads I have found have broken links for pictures, but they say they were able to raise the upper mount about 4"
I have also thought about extending it through the fender under the hood. Wouldn't be too hard, but the factory air box is in the way
I want a J-Series
TJ Build:
Trevlaw is offline
post #245 of 251 Old 08-01-2016, 10:33 PM
jjvw
jjvw's Avatar
Who needs a factory air box?!
You know this, but at some extended shock length the shock body begins to hit things as the control arms walk under the frame and as the axle articulates to higher degrees. That is one reason why wider axles are useful in these endeavours. I know you are looking at longer arms to help reach those last couple inches.
2003 Rubicon
jjvw is offline
post #246 of 251 Old 08-01-2016, 10:37 PM Thread Starter
Trevlaw
Trevlaw's Avatar
You know this, but at some extended shock length the shock body begins to hit things as the control arms walk under the frame and as the axle articulates at higher degrees. That is one reason why wider axles are useful in these endeavours.
Yeah, hopefully I can lower the front mounts off to the side of the bar pin mount between it and the wheel. With the can mounted on top I don't think it'd be too hard to make the shaft clear stuff. The width of the upper mount is a concern for sure. I saw some absolutely awesome extended front upper shock mounts made by Mudb8 in a thread a while back that word work amazingly, but I PM'ed him once and he responded once, then I never heard back. He's local to me too, I'd love to get those mounts...
I'm planning on getting the mid arm kit assuming its not outrageously out of my budget, so that should help keep the axle from walking under the Jeep. Depending on what shocks I go with, I may have slightly more up travel than down, which would also help with this and spring unseating.
I want a J-Series
TJ Build:
Trevlaw is offline
post #247 of 251 Old 08-02-2016, 11:07 AM
Deacon
Deacon's Avatar
Originally Posted by Ben View Post
If suspension is your only concern, your plan seems sound, it's just a very expensive list that leaves you open/open on a D35.
Best comment/point in the whole thread.
Deacon is offline
post #248 of 251 Old 08-02-2016, 12:03 PM Thread Starter
Trevlaw
Trevlaw's Avatar
Hahahaha I guess you missed a little. I'm on 33s with an 8.8 with an artec truss in the rear with a very tight rebuilt Trac lok and just finished putting a true Trac in my Dana 30. Not planning on bigger than 33s so the rear should be fine and I'll probably put chromo shafts up front eventually. I built the axle to handle tires and eventually will go selectable in the rear.
Now I'm moving on to the suspension. I actually did listen to everyone's advice early on lol
Deacon likes this.
Trevlaw is offline
post #249 of 251 Old 08-02-2016, 12:08 PM
joe_jeep
for 33s, that set up should be golden.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #250 of 251 Old 08-02-2016, 12:26 PM Thread Starter
Trevlaw
Trevlaw's Avatar
My thoughts exactly. Just need to work on the suspension and a tummy tuck. Drivetrain should be good
Trevlaw is offline
post #251 of 251 Old 08-30-2016, 09:28 PM Thread Starter
Trevlaw
Trevlaw's Avatar
If anyone is curious as to how all my plans are playing out I started an actual build thread a little while ago.
https://www.jeepforum.com/forum/f22/w...build-3837569/
Thanks for everyone's help on working out most of the wrinkles in my plan and steering me towards the rear axle upgrade before the suspension
I want a J-Series
TJ Build:
Trevlaw is offline
8.8 swap , advice , metalcloak , savvy , suspension
