Wrench size for pitman arm - JeepForum.com
 4Likes
post #1 of 17 Old 05-09-2017, 06:56 AM Thread Starter
rondenzer
My 02 TJ has a leak from the steering gearbox where the pitman arm attaches. A 11/4 inch socket is slightly to small for the nut, but the largest I have. Is this a metric nut? Does anyone know the size I need to buy?
rondenzer is offline
post #2 of 17 Old 05-09-2017, 07:06 AM
JEK3
JEK3's Avatar
I've always just used my 24" crescent wrench from Harbor Freight.
rondenzer likes this.
JEK3 is offline
post #3 of 17 Old 05-09-2017, 07:41 AM
NotURMailman
NotURMailman's Avatar
According to the first of many JF threads that popped up by doing a quick Google search it is a 33mm (or a 1 5/16" will work in a pinch, slightly (.0130") bigger).
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #4 of 17 Old 05-09-2017, 08:45 AM
biffgnar
biffgnar's Avatar
Recently used 1-5/16s on mine
biffgnar is offline
post #5 of 17 Old 05-09-2017, 09:03 AM
LJ Dave
Chiming in just to confirm the above: it's a 33mm nut, but 1 5/16ths will also work. The best way to get the pitman arm off is to use a conical pitman arm puller. Have never been able to get one off with one of those cheap two arm pullers.
2005 Rubicon LJ 4.5 inches of lift, 35's
LJ Dave is offline
post #6 of 17 Old 05-09-2017, 10:28 AM
JEK3
JEK3's Avatar
I can usually get it off with the two-arm one, but the one time I couldn't the conical one also didn't work (that arm is still attached to the box, I make an attempt at it every now and then).
JEK3 is offline
post #7 of 17 Old 05-09-2017, 10:44 AM
NotURMailman
Cut into the arm almost to the splines with a grinder. Then split it with a chisel.
BTW - do you just have a TJ steering box laying around? Saginaw or ZF?
post #8 of 17 Old 05-09-2017, 10:58 AM
JEK3
JEK3's Avatar
I was actually trying to reuse the arm. Had to buy a new one.
Yes, I have a ZF box laying around. Has a little loose spot in the center, but it can probably be adjusted out. No leaks. Comes with a free Pitman arm.
JEK3 is offline
post #9 of 17 Old 05-09-2017, 11:05 AM
NotURMailman
Check your PMs.
post #10 of 17 Old 05-09-2017, 02:16 PM
UnlimtedRubi06
Heat and a BFH. The pitman arm will pop right off.
Sent from my SM-G950U using Tapatalk
UnlimtedRubi06 is offline
post #11 of 17 Old 05-09-2017, 03:38 PM
JEK3
JEK3's Avatar
Tried all that. Penetrating oil, blowtorch, Pitman arm puller, crowbar, and Mjolnir (my trusty 3# sledge), all in various combinations.
JEK3 is offline
post #12 of 17 Old 05-09-2017, 03:40 PM
UnlimtedRubi06
Dang. At that point I would be getting out the cutoff wheel.
post #13 of 17 Old 05-09-2017, 04:15 PM
biffgnar
biffgnar's Avatar
Is this with box attached to frame or removed? Are you saving the box or fully replacing it?
biffgnar is offline
post #14 of 17 Old 05-09-2017, 04:21 PM
JEK3
JEK3's Avatar
I was replacing the box, trying to reuse the pitman arm.
Box on vehicle, in the last year since I replaced it, I have tried a few times with it off.
JEK3 is offline
post #15 of 17 Old 05-09-2017, 04:52 PM
biffgnar
biffgnar's Avatar
On my recent steering project I also wanted to re-use the pitman arm, but didn't care about the box. Advice from Blaine after I could not get the pitman arm off with the box attached was to remove the box from the jeep, put a puller on the pitman arm to create tension and then with the box lying in the driveway hit the pitman arm good and hard with a sledge toward it coming off. Couple whacks and it came right off for me. I think you have to be cautious with the box if you care about it. The shock being potentially sent in to the box I don't think is particularly good for it. In fact, I think you have to be careful of that even when doing things like trying to get the TRE at the pitman arm to pop off.
biffgnar is offline
