Wrangler TJ 2.5 lift help - JeepForum.com
post #1 of 4 Old 07-02-2020, 07:28 PM Thread Starter
Hookfoot
I need to do a2.5 lift not sure what all I need. Planning on doing it myself, Will just springs and shocks be sufficient not sure what else I might need or will have to have
Any help would be greatly appreciated.
Thanks in advance
Hookfoot
Hookfoot is offline
post #2 of 4 Old 07-07-2020, 08:39 AM
Tymeks
There are many different ways to lift the jeep 2.5 inches. You could do just spring spacers, you could do a body lift and smaller spring spacer combo. You could do just springs and shocks. A few different ways to go about. Do your research to find out what is right for you.
Tymeks is offline
post #3 of 4 Old 07-07-2020, 09:07 AM
Ironhead
Ironhead's Avatar
rear track bar bracket for 2.5" lift.
adj front track bar, drill a new hole for the OEM track bar, or live with the front axle being off center by ~.25".
bump stop extensions based off of cycling your suspension to remove the possibility of your shocks bottoming out or other bits making contact.
some sort of way to address driveline vibes, motor mount lift, tc drop, or adj control arms and cv driveshaft
Ironhead is offline
post #4 of 4 Old 07-07-2020, 06:11 PM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
H&R 1" springs and a 1.25" BL would be the easiest option.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
GOT IT BACK 6/17. 03' Rubicon/Zone 4.25" combo lift with 4" lift coils up front/Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
