Wrangler Magnum V8 Discussion - Page 11 - JeepForum.com
 230Likes
post #151 of 3032 Old 09-18-2012, 07:52 PM Thread Starter
JeepinGIJOE
I've put a ton of road miles on my swap and a lot of wheeling miles. It has been a great swap very glad I did it!..and FYI if anyone needs a 5spd 5.2 computer with skim removed ect pm me..
JeepinGIJOE is offline
post #152 of 3032 Old 09-18-2012, 09:06 PM
rockcrusher
JeepinGIJOE How has your mpg been since the swap
rockcrusher is offline
post #153 of 3032 Old 09-18-2012, 09:07 PM Thread Starter
JeepinGIJOE
Depending on how I drive it..if I baby it I get around 20-22
post #154 of 3032 Old 09-18-2012, 09:52 PM
rockcrusher
Thats better than I get now. I'm still not sure which I am going to do the 5.2 or the 5.9. I am worried that if I go 5.2 I will wish that I went 5.9 errrrrrrrrrrrrrr
post #155 of 3032 Old 09-19-2012, 01:06 AM
seabass2020
Evan at backwoods told me he has done both many times and he always likes the 5.2 better. He said they have a more aggressive cam and tend to rev up quicker and almost have the same Hp. Im taking his word for it, so I'm doing the 5.2
seabass2020 is offline
post #156 of 3032 Old 09-19-2012, 05:21 AM
tjsean0308
tjsean0308's Avatar
bought my 5.2 today. 950 for the engine from a Durango rear sump front dipstick, 92,000 miles looks to have been rebuilt at some point. AX-15 with the correct bell housing. 31 spline NP231, and all the accessories I could grab from a 96 5.2l ZJ including my second wiring harness and computer. Still need motor mounts, clutch kit, headers, radiator, I think that's it. The second computer and harness is from a 99 Dakota. Which harness should I use the Dakota or the ZJ to splice into my TJ harness? And is AlldataDIY the best source for the dakota/ZJ pin outs? I have the TJ FSM so I should be good on that front.
tjsean0308 is offline
post #157 of 3032 Old 09-19-2012, 07:30 AM
seabass2020
I think it's easiest to use the harness for the motor you have. You'll need 3 fsm manuals. Your jeep, the wiring harness, and the PCM. The PCM and wiring harness should be nearly identical, but mine had a few differences in colors and pinouts. I found the fsm in PDF on google
Wojoe likes this.
post #158 of 3032 Old 09-19-2012, 01:36 PM
tjsean0308
tjsean0308's Avatar
Google it is. Thanks.
Wojoe likes this.
post #159 of 3032 Old 09-19-2012, 03:27 PM
bleachcola
I used to build the 5.2 5.9 a long time ago, back when the RT dakota was "Fast" lol.
when you have the motor not installed yet, I would recommend changing out the stock intake manifold "keg" for a mopar m1 efi one. the stock one has a belly pan on the bottom and they always leak. you can get away with rtv or a new gasket every few yrs, but the m1 is all one piece and adds nice power. A ported TB and new rockers and pushrods would be a cheap and easy mod.
but on that note I would no longer put a 318 360 in anything, they were limited on power even with n2o or boost. with the price of 02-05 hemi's dropping, id consider that route for more power and better efficiency.
bleachcola is offline
post #160 of 3032 Old 09-19-2012, 03:54 PM
tjsean0308
tjsean0308's Avatar
Well the hemis are still a pretty penny out here. They are dropping in the northeast where the rest of the vehicle is rotting. But out here in the northwest the magnums are still mostly on the road. Good info on the keg I did notice a bit of oil in the bottom of the keg on mine. What input do you have for the intake bolts? Read somewhere the factory bolts are too long? Makes it leak or something. I'm not trying to make a ton of power the 250-260hp range is perfect for my needs that will be more than double my 2.5l which I find acceptable but lacking on the highway. Any suggestions for where to get these parts.
post #161 of 3032 Old 09-19-2012, 04:15 PM
seabass2020
I think the hemi would be awesome, but from everything I've read, the cheapest part of a hemi swap is buying the motor. All the parts to make it work are what add up
Wojoe likes this.
post #162 of 3032 Old 09-19-2012, 11:25 PM
slyder
I went with the Hughes Plenum, it's a lot thicker than the stock plenum. I think it's around $120 for the plenum, gskts and bolts.
Wojoe likes this.
slyder is offline
post #163 of 3032 Old 09-20-2012, 11:40 PM
seabass2020
Anyone have any ideas? I've got the wiring done, and when I try to start, nothing happens. It doesn't even crank.
The donor was an auto, I'm wondering if the trans wiring is preventing the start -- like a neutral safety...??
post #164 of 3032 Old 09-21-2012, 01:40 AM
seabass2020
That was exactly it. The donor was an auto. There is a park safety switch that needs to be grounded in the tranny harness.
She's alive!!!!! Fired up almost immediately
Now I need to put everything back together.
Only thing is, the gauges aren't working with the 5.9 computer, but the jeep computer works fine. Any thoughts here?
Wojoe likes this.
post #165 of 3032 Old 09-21-2012, 01:43 AM
seabass2020
Btw, it's an 02 wrangler, with a 00 Durango motor. I used an 02 ram PCM ( so its pci bus) and had bg flash it for the 5.2
5.3 or 5.9 magnum in TJ? mitch77 TJ Wrangler Technical Forum 35 11-16-2012 08:17 PM
magnum in my tj muddnajeep TJ Wrangler Technical Forum 9 11-12-2012 07:21 PM
5.2 magnum ??? mike78 TJ Wrangler Technical Forum 1 11-09-2012 08:05 PM
Swap a 3.9 magnum into the yj Russell_Goodall YJ Wrangler Technical Forum 18 10-28-2011 08:30 PM
Looking into 4.2 to 318 (5.2) Magnum Swap lt_liverdamage YJ Wrangler Technical Forum 6 01-11-2010 11:35 AM
