Wrangler Magnum V8 Discussion - JeepForum.com
 221Likes
post #1 of 3019 Old 05-06-2012, 10:18 PM Thread Starter
JeepinGIJOE
Just finished up the most recent swap..this was done in my 2003 TJ..I'm cuurently done with the swap, had it started up in 2 days then got busy with other stuff but only had small things to do to it..fluids and tidying up ect... This is more of a discussion thread instead of a build thread. I'll answer questions or whatever..and help if I can.
Here's the swap parts I used.
99 5.2 Magnum motor (bought a Durango as a donor)
Durango V8 Throttle Cable
Motor mount kit - (AA part# 713094)
Fuel line frame to engine (52127819AE) (If you don't have one)
Oconeeoffroad V8 Conversion Radiator (GM Syle)
Dodge 318 V8 Tj Headers (summitracing.com or Novak-adapt.com)
Electric Fan (I used the Fal Black magic 180, however you can also use part# CBG4F250 from summit..it will bolt into the wrangler 4.0 fan shroud)
94-99 Dodge 3.9 V6 Bellhousing (Bolts up to the V8 and AX15 or Nv3550)
If you use the 3.9 bellhousing and the jeep ax-15 or nv3550 you will need to do no modification to the drive shafts or shifter everything will remain in stock location on the Jeep..You simply have to move the AA motor mounts a littler further back when placing the engine..very easily done.
2001 Dodge Ram 1500 5spd Engine Harness
03 Dodge Ram 1500 5.9 ECU (56040491AB) I sent the ECM to Dave Kasper at BGChrysler so he could switch it to a manual transmission, get rid of the skim, and change it from a 5.9 timing/fuel map to a 5.2 timing/fuel map.
00-03 Injectors (since the motor was a 99 and the injector styles changed in 2000)
Zj Power steering bracket
2001 Ram 5spd CPS
7/16x20 flywheel bolts (these are needed for the difference between thickness of the flywheel and flexplate)
Zj power steering pump pulley
Zj Serpentine belt
2001 Ram 1500 flywheel
2001 Ram 1500 clutch
Wrangler 4.0 power steering pump
NV3550 Transmission with Transfer case
Anyway here's a few photos.. I dont have many as I'm too lazy to do work and spectate to take pics..
Getting her torn down..
That was easy...
Now lets remove those stock engine mounts..nothing a little grinder can't handle...
Ok..now lets bolt the engine and tranny all together...
All went together easily...
Finally getting this sucker in place....
I'm missing a few pics here..after I placed the engine the first time I bolted the tranny to the skid and put the driveshafts in..I checked the firewall for clearances then placed the motor mounts where they needed to be and tacked them in...afterwards I yanked everything back out and painted the frame.
And finally in it's final resting place...
I had already previous built the wiring harness before starting the swap so I would have very little down time..after I placed the engine for the final time I hurrily hooked everything up to see if all was good...
here's a short video of beast (as the wife calls it)
http://s1171.photobucket.com/albums/...wapstartup.mp4
It started up and ran fine but I had no gauges..so I siphered out some diagrams and tried a few things..it lead me to believe that although my dodge ecm was a 2003 it had to be a CCD bus system..it came from a 2003 ram van 3500 5.9..to make sure it wasn't my harness I plugged the old jeep ecm back in and turned the key..yep the gauges worked...My Ecm is a CCD and not PCI like a need...(I never doubted the harness I have built a few now but you can never be to sure)
Well after that fiasco I looked at the wiring diagrams for the Ram Vans and Ram 1500 in 2003..
I sourced a 2003 Ram 1500 5.9 ecm which is PCI so after that comes in I ship it back out to BGchrysler for them to convert it to manual ect ect. and all should be golden.
I know I'm going to get asked about wiring..all I can really say is get the wiring diagrams and get to work..it's actually pretty simple...but if need be and you want to have someone build it for you let me know..I'll build them for a fee..that is much less than others..
JeepinGIJOE is offline
post #2 of 3019 Old 05-06-2012, 10:45 PM
scot68
scot68's Avatar
Nice... I am thinking about doing a Magnum swap this winter. At first I was thinking of a GM LS but the Magnum motor seems the easiest way to go. My 4.0L runs fine but the idea of my Heep with a V8 =
Wojoe likes this.
scot68 is offline
post #3 of 3019 Old 05-06-2012, 10:56 PM Thread Starter
JeepinGIJOE
Honestly I'd probably go 4.0 stroker over the v8..while I love a v8 unless you buy a donor vehicle like I did it's just not economical when you already have a pretty good platform (4.0)..I only have around $500 in mine that's everything..I saved alot by parting out the donor..
Wojoe likes this.
post #4 of 3019 Old 08-15-2012, 10:51 PM
seabass2020
Why did you use the wiring harness from a 2001 truck instead of from the 99 durango? Also, did you get the block hugger headers?
seabass2020 is offline
post #5 of 3019 Old 08-16-2012, 10:37 AM
jpin86
jpin86's Avatar
It's good to know that the automatic, pci data bus computer can be reflashed to use in a manual. I want to do a 360 swap in a 2003-2004 rubicon with the nv3550 transmission. I couldn't get a clear answer if the auto to manual reflash would work. What did they charge you to do the flash? Did you cut and splice the harness or repin it?
I have been gathering parts to do a magnum 360 swap. So far I have the 3.9 bell housing, 2002 360 with 80,000 miles, engine harness, 2002 dodge ram computer.
jpin86 is offline
post #6 of 3019 Old 08-16-2012, 11:59 AM
seabass2020
I was also looking at doing the 360, but after talking to Evan at backwoods, I think he convinced me to go with the 318. How do you think the nv3550 will hold up to the V8? I'm trying to decide which manual transmission to use.
post #7 of 3019 Old 08-16-2012, 12:10 PM
seabass2020
I can't tell if there is a difference in strength between the nv3500 (dodge truck) and the nv3550 (2000-2005 wrangler). The only difference I can tell is the nv3550 has a removable bellhousing. If that's the case i'm wondering if that would be a better choice for my swap because I'm hoping I don't have to cut a new hole in the floor and modify the transmission mount.
post #8 of 3019 Old 08-16-2012, 12:12 PM
joeksjeep
dude this is an awesome swap #1 cuz its a Mopar motor, and #2 cuz its pretty much direct fit.... My question is, and im sure you do, but any Check engine light??? And if so are you tryin to get rid of them?? Im in cleveland ohio and we have emissions.. it would be cool to do that swap w/ a built 318 and not have any check engine codes so it can pass emissions
92 Xj 190,XXX miles needs love, and a TURBO HA!
150RwHp, 186 Lbs torque Rw, and all at 175XXX miles in my Xj
DD 98 wrangler sport 5spd 4.0 106,XXX miles
Chrysler Factory Trained Jeep technician, and A.S.E. Certified Master Tech
joeksjeep is offline
post #9 of 3019 Old 08-16-2012, 12:42 PM
jpin86
jpin86's Avatar
+2 on the check engine light. I need to pass smog.
jpin86 is offline
post #10 of 3019 Old 08-16-2012, 12:44 PM
jpin86
jpin86's Avatar
What are you going to do about a/c?
jpin86 is offline
post #11 of 3019 Old 08-16-2012, 12:45 PM
joeksjeep
A/c????? dude its a jeep lmao with a V8 its nice to have but not necessary haha
tbuck74 likes this.
post #12 of 3019 Old 08-16-2012, 01:24 PM
jpin86
jpin86's Avatar
My Jeep is a daily driver, so a/c is nice when it's close to 100 degrees and your stuck in traffic. The a/c compressor also runs when the defroster is on, helping to defrost the windows and remove moisture.
jpin86 is offline
post #13 of 3019 Old 08-16-2012, 01:30 PM
joeksjeep
yes i know that but if it was me i would say screw it ha.... im sure he can get some lines made to fit to the stock setup if he wants..... If hes even using the stock radiator and condensor
post #14 of 3019 Old 08-16-2012, 04:13 PM
dan33051
If you use a 5.2 and auto out of a 2000 or newer durango for a 2003 rubi can you use all the donor stuff from the durango? THey do have a 46RE don't they? Want ot stay with an auto.
dan33051 is offline
post #15 of 3019 Old 08-16-2012, 04:55 PM
2006_Sport
2006_Sport's Avatar
I would love to find a durango with the v8 in decent condition with an auto. I'd swap it in a heartbeat.
2006_Sport is offline
5.3 or 5.9 magnum in TJ? mitch77 TJ Wrangler Technical Forum 35 11-16-2012 07:17 PM
magnum in my tj muddnajeep TJ Wrangler Technical Forum 9 11-12-2012 06:21 PM
5.2 magnum ??? mike78 TJ Wrangler Technical Forum 1 11-09-2012 07:05 PM
Swap a 3.9 magnum into the yj Russell_Goodall YJ Wrangler Technical Forum 18 10-28-2011 07:30 PM
Looking into 4.2 to 318 (5.2) Magnum Swap lt_liverdamage YJ Wrangler Technical Forum 6 01-11-2010 10:35 AM
