Worn sway bar link causing shimmy? - JeepForum.com
post #1 of 2 Old 07-08-2010, 11:22 AM Thread Starter
sthomp
I recently replaced my sway bar links with some JKS quicker disconnects. One of the old links I replaced had a bad ball joint that had a lot of play in it when I would shake the jeep back and forth. Anyway, after replacing them with the JKS discos it fixed my shimmy at 50mph. I was surprised that a sway bar link would do this as I hear of people running without sway bars all the time. What I want to know is if I am covering up the true cause for the shimmy, as I still have some driveline hum that sounds like a bearing or u-joint (all seem tight tho). Any thoughts?
sthomp is offline
post #2 of 2 Old 07-08-2010, 02:24 PM
redo4x
I would not think that was the problem. I have run without the swaybar hooked up plenty of times wth no shaking. Your new disco's are adjustable and the different length might have made a difference.
redo4x is offline
sway bar , tj , wrangler , shimmy , shaking
Need a bolt for sway bar link, can't find PN or specs in OEM link from FAQ djfuzzy TJ Wrangler Technical Forum 11 02-13-2015 04:47 PM
4 wheel disc brakes causing shimmy in steering? Rubicon_Rob04 TJ Wrangler Technical Forum 6 03-29-2010 04:41 PM
Worn out center link Prot JK Wrangler Technical Forum 4 03-31-2009 07:10 PM
Can a worn front axle pinion bearing cause poor steering/front end shimmy? golficon TJ Wrangler Technical Forum 2 02-28-2009 11:27 AM
Drag Link worn out? Prot JK Wrangler Technical Forum 4 01-18-2008 01:26 AM
