Wiring pin outs help - JeepForum.com
post #1 of 9 Old 10-19-2015, 08:53 AM Thread Starter
Camron126
1983 CJ7
I swapped a 2003 4.0L engine complete with computer and wiring harness into my '82 CJ-7, and I'm having a lot of trouble finding all the pinouts and wiring diagrams of the wiring harness (with wire-colors). Can anyone help with this? I've only found 2 pinout diagrams so far for the model year body harness I have, and some of the wires seem to be different colors on it as well. Any help is appreciated!
Camron126 is offline
post #2 of 9 Old 10-19-2015, 08:55 AM Thread Starter
Camron126
1983 CJ7
Also, there are some connectors on the engine harness that I have no clue what they go to, so if there are any diagrams illustrating all the connectors of the wiring harness that would be amazing! Thanks
post #3 of 9 Old 10-19-2015, 10:02 AM
irnmadn88
Search here for the necessary pdf of the Factory Service Manual you need:
http://www.jeep4x4center.com/knowledge-base/index.htm
Colorado Jeep Club Member #667
irnmadn88 is offline
post #4 of 9 Old 10-19-2015, 10:49 AM Thread Starter
Camron126
1983 CJ7
Yessss I found the harness diagrams on this thank you! What about the wiring/pinout diagrams?
post #5 of 9 Old 10-19-2015, 11:29 AM
irnmadn88
It is in the pdf you found.
Look at the section labeled Wiring then look for the subsection Connector Pin-Outs.
post #6 of 9 Old 10-19-2015, 11:59 AM Thread Starter
Camron126
1983 CJ7
As far as I can see there isn't a subsection for connectors and pinouts in the wiring part. Am I looking at the wrong thing?
post #7 of 9 Old 10-19-2015, 12:48 PM
irnmadn88
I think you have found the Parts Catalog.
Try doing it from on a computer.
Go to the part of the page that says Online Repair Manuals, select Jeep Wrangler TJ and year 2003, then go to the subsection Wiring Connector Pinouts.
post #8 of 9 Old 10-19-2015, 12:58 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
That is not it. That looks like you may be in the parts manuals section. From the link above go to the middle of the page where to says online repair manuals. From the “select” drop down list pick Wrangler TJ then the year (2003) then in the next drop down list find Wiring-Connector PinOuts. The PCM connectors are on about pages 39-40.
There is also a connector & grounds locations section that may help too.
Edit, sorry, did not intend to step on you.
Rubi4MyMrs is offline
post #9 of 9 Old 10-19-2015, 02:38 PM Thread Starter
Camron126
1983 CJ7
Oh ok thanks so much for the help guys! Greatly appreciate it
4.0 swap , cj7 , tj , wiring diagram
