Wipers not working - JeepForum.com
 7Likes
  • 1 Post By CGrugger
  • 2 Post By CGrugger
  • 1 Post By jtec
  • 1 Post By Rubi4MyMrs
  • 1 Post By jtec
  • 1 Post By mukluk
post #1 of 14 Old 07-02-2020, 09:49 AM Thread Starter
BlueFl.Wrangler
Supporting Member
BlueFl.Wrangler's Avatar
Wipers not working
Can the board here give me some suggestions on troubleshooting my wipers all of a sudden not working?
I am 99% sure the switch / lever is good- it was replaced last year & the washer still squirts.
Thanks fellas
Diplomacy is the art of telling people to go to hell in such a way that they ask for directions
Winston Churchill
BlueFl.Wrangler is offline
post #2 of 14 Old 07-02-2020, 09:52 AM
CGrugger
CGrugger's Avatar
I am 99% the switch / lever is good- it was replace last year & the washer still squirts.
Thanks fellas
Did you check the fuse behind the glove box and the relay under the hood?
Sent from my Pixel 2 XL using Tapatalk
BlueFl.Wrangler likes this.
2005 TJ X: MC 3.5" lift, 33"x12.5" tires, 1.25" Zone body lift, Curry Antirock sway bar.
CGrugger is offline
post #3 of 14 Old 07-02-2020, 10:18 AM Thread Starter
BlueFl.Wrangler
Supporting Member
Not yet
I will check the fuse first
Unsure how to check the relay though- I do have V.O.M. though
Winston Churchill
post #4 of 14 Old 07-02-2020, 10:23 AM
CGrugger
CGrugger's Avatar
Not yet
I think it is 13 (accessories) in the power distribution box under the hood.
When mine went out, I lost sprayer too, it was the connector came undone.
Another cause could be a bad wiper motor, you have to remove the cowl to test that.
If you google a bit, there are a few write ups on what to check
beepinJ and BlueFl.Wrangler like this.
CGrugger is offline
post #5 of 14 Old 07-02-2020, 10:35 AM Thread Starter
BlueFl.Wrangler
Supporting Member
Thanks for chiming in to help
Winston Churchill
post #6 of 14 Old 07-02-2020, 10:51 AM
jtec
jtec's Avatar
2014 JK Wrangler
2002 TJ - attachment
jtec is offline
post #7 of 14 Old 07-02-2020, 11:18 AM Thread Starter
BlueFl.Wrangler
Supporting Member
Thanks for posting that jtec
I just have no clue how to use it
Is that from the FSM?
Winston Churchill
post #8 of 14 Old 07-02-2020, 11:42 AM
Rubi4MyMrs
Rubi4MyMrs's Avatar
It is not the fuse if the washer pump works.
There is no relay under the hood.
If you want to check the switch & have an ohm meter it is not too hard & if good itís likely the motor is bad. Iíve seen a few that are completely rusted out from exposure to weather.
From the FSM
DIAGNOSIS AND TESTING - RIGHT MULTIFUNCTION
SWITCH
Be certain to perform the diagnosis for the front
wiper system and/or front washer system before testing
the right multi-function switch. (Refer to 8 -
ELECTRICAL/FRONT WIPERS/WASHERS - DIAGNOSIS
AND TESTING). Refer to the appropriate
wiring information. The wiring information includes
wiring diagrams, proper wire and connector repair
procedures, details of wire harness routing and
retention, connector pin-out information and location
views for the various wire harness connectors, splices
and grounds.
WARNING: ON VEHICLES EQUIPPED WITH AIRBAGS,
DISABLE THE AIRBAG SYSTEM BEFORE
ATTEMPTING ANY STEERING WHEEL, STEERING
COLUMN, OR INSTRUMENT PANEL COMPONENT
DIAGNOSIS OR SERVICE. DISCONNECT AND ISOLATE
THE BATTERY NEGATIVE (GROUND) CABLE,
THEN WAIT TWO MINUTES FOR THE AIRBAG SYSTEM
CAPACITOR TO DISCHARGE BEFORE PERFORMING
FURTHER DIAGNOSIS OR SERVICE. THIS
IS THE ONLY SURE WAY TO DISABLE THE AIRBAG
SYSTEM. FAILURE TO TAKE THE PROPER PRECAUTIONS
COULD RESULT IN ACCIDENTAL AIRBAG
DEPLOYMENT AND POSSIBLE PERSONAL
INJURY.
(1) Disconnect and isolate the battery negative
cable.
(2) Remove the right multi-function switch from
the steering column and disconnect the cross body
wire harness connector for the switch from the
switch connector receptacle.
(3) Using an ohmmeter, check the right multi-function
switch continuity at the switch terminals (Fig.
17).
(4) If the switch fails any of the continuity checks,
replace the faulty right multi-function switch. If the
switch is OK, repair the open or shorted front wiper
and washer system circuits between the right multifunction
switch and the front wiper motor or the
front washer pump/motor as required.
Rubi4MyMrs is offline
post #9 of 14 Old 07-02-2020, 02:25 PM Thread Starter
BlueFl.Wrangler
Supporting Member
Thanks for all the help fellas- though most of it was WAY past my pay-grade- I am no electrician.
So I went back to a thread I found the other day using the search function and saw where a fella completely dissembled the entire motor drive unit. His was basically froze up from corrosion, he took it all apart cleaned and lubed everything and that was the fyx. So I attempted the same thing- mine has water intrusion and was rusting inside- but when it came time for re-assembly I lost 2 of the TINY springs that keep the carbon "bushings" on the armature ( unsure of all the technical nomenclature ) and also one of those carbon bushings crumbled apart. So I am just getting a replacement motor drive unit from my local NAPA dealer
Winston Churchill
post #10 of 14 Old 07-02-2020, 03:22 PM
jtec
jtec's Avatar
2014 JK Wrangler
let us know after R&R wiper motor.
good luck - think positive
jtec is offline
post #11 of 14 Old 07-02-2020, 04:00 PM Thread Starter
BlueFl.Wrangler
Supporting Member
For sure!!!!!
Winston Churchill
post #12 of 14 Old 07-02-2020, 04:44 PM
mukluk
mukluk's Avatar
Those carbon bits are called carbon brushes. They're the electrical contact between the commutator and the motor circuit wiring. If you find yourself bored or adventurous, replacements can be purchased to replace the bad ones (McMaster-Carr is one such source).
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #13 of 14 Old 07-10-2020, 10:52 AM Thread Starter
BlueFl.Wrangler
Supporting Member
Here is the final update
So last Thursday I went to NAPA to get a replacement motor / drive assy. Of course they didnt have one in stock, so they ordered one that came in the next morning. Went to get it and it was a totally different assy. Come to find out my jeep is a '02 but apparently came with a '03 assy. so it would not fit / work. So they had to order another one that had to come from TEXAS--and it took exactly 7 days so I got it this morning-- installed it and all works well
Winston Churchill
post #14 of 14 Old 07-12-2020, 09:07 PM
beepinJ
2011 JK Wrangler
Reminds me to work on aunt's TJ as the wiper has been acting up recently. Will just finish installing the brake kit, tire and wheel packages on the current Ram project. The sprayer was replaced before by the previous owner. Guess the wiper motor needs a replacement.
beepinJ is offline
