Window washer fuse?? - JeepForum.com
 1Likes
  • 1 Post By mukluk
post #1 of 3 Old 01-31-2019, 05:08 PM Thread Starter
motovate
2003 Jeep Rubicon 6 cyl, auto. It's been awhile but I am finally down the list to do some work on my jeep. Awhile back the front window washer quit squirting - bottle was full and the rear washer continued to work. I as looking at the fuse listing in the hand book and on the lid cover and I could not find any listing for a fuse for the washer pump.
Wondering if anyone had a schematic or knows which fuse covers the washer motor(s)? I would guess both motors are on the same line /fuse but do wonder if they are on different fuses for some reason.
Any one have any issues with the washer motors???. I looked down the sides and it appears both motors are hooked up.
Thanks -
LBM
motovate is offline
post #2 of 3 Old 01-31-2019, 05:21 PM
mukluk
mukluk's Avatar
The front washer pump gets its power from fuse box fuse #17, which also is the source of power for the front wiper motor. If the wipers are working but the washer isn't, it's not the fuse. Pull the connector off the washer pump and check that you have a good ground at pin B (BK wire), and you're getting 12v to pin A (BR wire) when you activate the front washer.
FYI, the rear wiper motor and washer pump get power from fuse box fuse #6.
jtec likes this.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 3 Old 02-01-2019, 05:23 AM Thread Starter
motovate
Outstanding - thanks. Wipers work so I'll check the ground. LBM
QUOTE=mukluk;40504495]The front washer pump gets its power from fuse box fuse #17, which also is the source of power for the front wiper motor. If the wipers are working but the washer isn't, it's not the fuse. Pull the connector off the washer pump and check that you have a good ground at pin B (BK wire), and you're getting 12v to pin A (BR wire) when you activate the front washer.
FYI, the rear wiper motor and washer pump get power from fuse box fuse #6.[/QUOTE]
motovate is offline
Injector Fuse Blows Intermittently 4.0 WJ I-6 apropes WJ Grand Cherokee Forum 33 12-29-2020 09:45 AM
1995 Grand Cherokee ZJ drivers window regulator removal muddflow ZJ Grand Cherokee Forum 2 09-19-2018 12:13 AM
Fuse# for windshield washer pump JBTJ TJ Wrangler Technical Forum 15 09-18-2018 10:04 AM
'00 XJ Electric Window Switches Fuse RodB XJ Cherokee Technical Forum 7 08-06-2018 12:36 PM
Hoisting the hard top- solution to the window KLjeep99 TJ Wrangler Technical Forum 3 04-17-2018 09:44 PM
