Window Crank removal 2002 TJ - JeepForum.com
post #1 of 4 Old 02-21-2004, 01:42 PM Thread Starter
Dragonmaster
Guest
When the dealer did my last warranty work they put my window crank on opposite of the driver side. How is the crank removed?
Dragonmaster is offline
post #2 of 4 Old 02-21-2004, 10:59 PM
Silver yj
There should be either a bolt in the center of it to take out or a clip kinda shaped like a " C " behind the handle that you have to remove.
Silver yj is offline
post #3 of 4 Old 02-22-2004, 02:20 AM
AudioGuru
Guest
You need a window crank removal tool. It slides between the handle and the foam gasket that separates the handle from the doorpanel. Push the tool in between these directly in line with the handle. There's a metal c clip that secures it. This tool spreads the c clip so the handle can come off its splined post. The clip can shoot off during removal, be careful.
Push it straight on in the position you desire.
AudioGuru is offline
post #4 of 4 Old 02-22-2004, 05:46 PM Thread Starter
Dragonmaster
Guest
Thanks, so a custom modified fork will work just as on others with the c-clip holding the handle on (can't really see in as well as you can with most other vehicles with c-clips and didn't want to wreck anything).
YJ Hardtop Window Crank Jam jeeper88 YJ Wrangler Technical Forum 3 05-16-2009 07:56 AM
Removing Window Crank Emtee TJ Wrangler Technical Forum 3 07-18-2007 05:39 PM
Window Crank TWrangler TJ Wrangler Technical Forum 3 12-29-2006 08:51 PM
window crank brundz YJ Wrangler Technical Forum 1 09-03-2006 05:59 AM
Window Crank Removal!! DaJeepMan9 YJ Wrangler Technical Forum 4 02-06-2005 08:04 AM
