JeepForum.com (https://www.jeepforum.com/forum/)
-   TJ Wrangler Technical Forum (https://www.jeepforum.com/forum/f9/)
-   -   Window crank removal (https://www.jeepforum.com/forum/f9/window-crank-removal-1009858/)
olucier 04-10-2010 08:49 AM
How do I get the manual window crank off? Just pry it or am i missing something?
98 Sahara manual windows passenger side
Hesher420 04-10-2010 08:58 AM
There is a clip that has to be pulled off first. push the door panel in and look around the base of the crank to see it.
http://z.about.com/d/autorepair/1/0/..._clip_260c.gif
Wloch248 04-10-2010 09:16 AM
That is a great picture. The easiest way I have found to get it off is a long thin flat head screwdriver. Push one end of it and it comes right off.
Tip for putting it back on. Put the retaining clip back into the grooves and just press the crank back on. It would be really hard to line it up if you put the crank back on THEN tried to put the clip in.
Good luck!
olucier 04-10-2010 09:26 AM
Found it! Thanks
Eyes are not what they use to be- getting old.
olucier 04-10-2010 09:29 AM
Trying to figure out why outside handle will not release latch- appears to be moving the rods, just not enough... I need more rod movement, seems that the outside latch is sticky/not moving as freely as i would expect. Nothing is broken or disconnected?????????.
olucier 04-10-2010 10:03 AM
Little PB Blaster work it back and forth- seems to be loosening up and actually opens the door now- let it sit for a few hours and I am sure it will be fine
Wish all fixes were this easy
texas-hooligan 03-15-2012 09:13 PM
Great pic! I'll try this tomorrow as I remove the interior door panel to swap out the outside door handles with some new ones.
TNJeeeper 03-16-2012 05:23 AM
Is the open end of the clip always pointed toward the handle?? Or does it remain fixed in whatever position you install it?? I took mine off a while back, no problem. I went to take it off again a few weeks ago and could not get it off for nothing. Can't seem to figure out which way the clip is pointed.
G Beasley 03-16-2012 05:36 AM
Harbor freight doesnt have many tools I care for , but they do have a nice set of nylon trim tools for removing various panels in a car . It works great for all the christmas tree fasteners and the window crank .
Miller97 11-02-2014 03:40 PM
Does anyone know if you need to have the gasket behind it for it to stay on? Somehow mine walked away when I was regreasing the lock rod.. Just want to know if I need to go and buy a whole new window crank..
cmdrpiffle 03-11-2018 06:18 PM
Zombie Thread, I know
I didn't want to make a new thread, as the search function pulls up this one just fine.
I had to fix my pax side door handle today, and of course had to take off the crank handle. There are many, many suggestions out there but here's one that works in about 10 seconds...and this includes putting it BACK ON !
Use a pick ( I used a dental pick, but any strong steel, tapered metal would worrk. A large paper clip will work. Bend a hook with needle nosed pliers on one end of the pick, or paper clip. Hook the 'loop' side of the C Clip holding the crank on. You'll have to use another tool *I used a screwdriver, to push the panel away from the base of the crank. A flat head screw driver really is going to be a pain in the *** because there is an angle you have to reach to grab the C Clip. So, again, just use a dental pick or a paper clip, both bent into a small hook.
Next after you've 'hooked' the C Clip, use pliers to grab the dental pick or paper clip and pull straight up. Fingers are going to be touchy on the dental pick, and won't work at all using a paper clip. You won't be able to grip it tightly enought to pull up.
It'll pop right out. Pull off the crank. Viola !
Dental pick set:
https://www.pjtool.com/4-pc-dental-p...CABEgKEBfD_BwE
PUTTING IT BACK ON IS EVEN EASIER. Most folks try to slide on the crank then manhandle the clip into position, etc. Don't bother.
Put the C Clip into the crank handle first, before putting the crank handle on the crank post. Notice the ends of the slotted crank post are beveled? All you need to do is push the crank handle onto the post. The bevels will spread the C Clip. You may have to pop the center of the handle with your palm to seat it into the slot for the C Clip.
Seriously, taking it off and putting it on.... 10 seconds.
Hope this helps. Cheers :grin2:
Edit: I wrote the above becaue I DID spend 45 mins trying to grab the stoopid C Clip with- Needle nosed pliers, A screwdriver to try to push down on one of the ends of the clip, A bicycle spoke, also to try to push down, A butter knife blade to 'wrangle it out', etc. ad. nauseaum.
Because of the indent in the door panel around the crank handle, you're never going to get leverage to get anything straight in there to pull or push out the clip. I realize I had a few metal dental picks around. They are surgical steel and bend without breaking. I used needle nosed pliers to make a little hook on one of the pointed ends.
I also wasted time trying to push on the crank and then attach the C Clip. After much frustration I looked at the crank stud and realized it was beveled at the tip. I put the C Clip on the plastic handle and just pushed it on the crank stud until it went 'click'.
Hi pulled de tligger unteel heet went...click... Jesus! Exactly Pendejo....Nobody ****s with dee Jesus. Shut the **** up Donny ! :grin2:
Knuckelhead 03-11-2018 07:47 PM
An easy way to get the clip off is to drag a shop rag behind the handle, it will snag the clip and pop it right off...
hokahay 03-12-2018 04:42 AM
3 in one clip remover
https://www.harborfreight.com/4-piec...set-38386.html
cmdrpiffle 03-12-2018 11:16 PM
My experience = so so with the rag method.
Worked one time as I had a falling apart cotton rag that snagged the ends of the C Clip.
Tried it again on the other side...not so much. Never could catch it. Ended up using the pick.
ThisJustin 03-14-2018 11:58 AM
This trick never fails me. I use a tool to push the panel back a little so I can see the clip. Find a piece of solid wire, stripped solid copper, bailing wire, etc. Cut about a 4-5" piece and use needle nose pliers to create a small hook on one end. Fish the hook back there and grab the clip and pry or pull it off. But warning, the clip usually goes on the ground somewhere, Dorman makes replacements in the parts stores help section!
The time now is 10:13 PM.
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
