Window Crank - JeepForum.com
post #1 of 4 Old 12-29-2006, 08:02 PM Thread Starter
TWrangler
Window Crank
Know this sounds dumb, but I am trying to get the interior door panels of my '02 Wrangler & I can't get the window crank off. I've try pryin pretty hard, and I don't see any clip (maybe I'm missin something). How's this thing come off? Thanks all.
TWrangler is offline
post #2 of 4 Old 12-29-2006, 08:10 PM
Rocky529
Rocky529's Avatar
Push in the plastic panel, and you will see a C clip holding it on. You can get a C clip removal tool from AutoZone, or you can get it with a small flathead.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 4 Old 12-29-2006, 08:11 PM
dyna
Guest
Unless its different than my 98 there is a clip behind the handle, very small but there. Push the panel in as best you can around the handle and smash your face against the panel and have a looky, Ive used a small bent tipped blade driver to pop the clip out and the handle will fall off. To install put the clip back on and gently push back on and it will snap into place.
dyna is offline
post #4 of 4 Old 12-29-2006, 08:51 PM Thread Starter
TWrangler
Thanks guys, got er. Kind of a pain, but its off, wish they would have just put a screw in the center like my Peterbilt.
window crank stripped olsont YJ Wrangler Technical Forum 5 09-29-2009 07:51 PM
window crank brundz YJ Wrangler Technical Forum 1 09-03-2006 05:59 AM
My window crank wont come off?!?! noselfcontrol TJ Wrangler Technical Forum 11 06-28-2006 06:47 PM
Window Crank Orientation?? Dragonmaster TJ Wrangler Technical Forum 6 07-21-2004 09:04 AM
Reposition Window Crank? TestDummy TJ Wrangler Technical Forum 6 12-05-2003 10:16 AM
