Will removing tie rod for painting require me to align it again once it's put back in - JeepForum.com
post #1 of 15 Old 04-16-2009, 12:30 PM Thread Starter
BWFBezerk
BWFBezerk's Avatar
title, I did not rotate the adjusting sleeve at all, just took off castle bolts, hammered out with rubber mallet, painted, put back in.
BWFBezerk is offline
post #2 of 15 Old 04-16-2009, 12:35 PM
Apex
Recon death squad
Apex's Avatar
It shouldn't make a difference, I'd assume as long as everything is the same length that it wouldn't affect the alignment...but don't quote me on it
Apex is offline
post #3 of 15 Old 04-16-2009, 12:37 PM
ryan2022
If you mark the exact location of the tie rod ends, you might be okay. If your unsure at all once you reinstall them, itd be good to get one done.
I think there are some DIY alignment threads kicking around, and since you have a good baseline you can take measurements before you yank them out.
ryan2022 is offline
post #4 of 15 Old 04-16-2009, 12:37 PM
sliseno
Not really. Before you take the tie rod out, either measure or count the exposed threads. If you keep it the same, you should be really darn close to where it was.
Roads? Where were going, we don't need...roads!
sliseno is offline
post #5 of 15 Old 04-16-2009, 12:37 PM
CoolContractor
CoolContractor's Avatar
You should be fine. You can check and adjust the alighnment yourself in 15 minutes. Do a search on the subject here.
2006 TJ Rubicon
CoolContractor is offline
post #6 of 15 Old 04-16-2009, 12:38 PM
cjlyell2112
I think you should be ok.
cjlyell2112 is offline
post #7 of 15 Old 04-16-2009, 12:49 PM Thread Starter
BWFBezerk
BWFBezerk's Avatar
Ok, thank you for the replies but I don't think I was clear. I have the ZJ tie road and removed it as a whole piece from my Jeep from end to end. I did not disassemble the tie rod, adjusting sleeve, other tie rod end. I left them intact and in place with the adjusting sleeve, I did not screw/unscrew it at all. I was just wondering if there was anyway other than that that would throw it off.
post #8 of 15 Old 04-16-2009, 12:52 PM
CoolContractor
It will tighten back up exactly where you took it off. The holes are not slotted so it will be fine.
2006 TJ Rubicon
post #9 of 15 Old 04-16-2009, 12:52 PM Thread Starter
BWFBezerk
BWFBezerk's Avatar
K, Thank You
post #10 of 15 Old 04-16-2009, 12:54 PM
Apex
Recon death squad
Apex's Avatar
Disco'd your ZJ tie-rod from the driverside wheel to the draglink? If so then I am in total understanding.
I have the ZJ rod as well...I painted it on the jeep, but had I taken it off I wouldn't think it would throw off your alignment as long as you don't adjust the sleeve at all.
But just to be safe, I would measure your toe-in upon reinstallation just to be safe.
Apex is offline
post #11 of 15 Old 04-16-2009, 02:24 PM
Muratus
Muratus's Avatar
Not to thread jack.... but what's the bennifit of running a ZJ tie-rod?
Muratus is offline
post #12 of 15 Old 04-16-2009, 02:43 PM
Apex
Recon death squad
Apex's Avatar
the thickness of the tie-rod...I don't have the measurements on hand and I am too lazy to look them up.
But the TJ tie-rod is thin and weak, and likes to bend under very little stress. The ZJ tie-rod is much beefier and stronger
Apex is offline
post #13 of 15 Old 04-16-2009, 03:06 PM Thread Starter
BWFBezerk
BWFBezerk's Avatar
TJ tie rod is thin and hollow, ZJ tie rod is thicker and solid:
http://www.stu-offroad.com/steering/zjtie/tierod-1.htm
and $12.80 for me from local U-PullIt
post #14 of 15 Old 04-16-2009, 07:20 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
Why remove it to paint it?...
Gone but not forgotten.
Knuckelhead is offline
post #15 of 15 Old 04-16-2009, 08:08 PM
thejafe
thejafe's Avatar
If you remove the entire tie rod assembly at the ball joints and leave the TRE's attached to the tie rod then your toe shouldn't be effected. It will only be effected if you rotate the adjustor sleeve.
thejafe is offline
removing back seat in tj, but what to do with the dog bogiemj TJ Wrangler Technical Forum 11 12-15-2009 01:28 PM
Removing and painting bolts?? Jeeper19 JK Wrangler Technical Forum 2 02-03-2009 05:59 PM
HELP HELP HELP Removing the back seat dfaircloth88 TJ Wrangler Technical Forum 6 09-13-2008 12:42 PM
Removing and painting coil springs cyberpunk TJ Wrangler Technical Forum 8 08-22-2007 12:49 PM
removing back bumper? toyotasupra TJ Wrangler Technical Forum 2 09-13-2003 01:28 PM
