Will my cooling system "burp" itself? - JeepForum.com
 10Likes
  • 1 Post By Newtons3
  • 2 Post By TJTurbo
  • 1 Post By Shark_13
  • 2 Post By TheBoogieman
  • 2 Post By 222Doc
  • 2 Post By joeyroe
post #1 of 8 Old 08-09-2019, 08:39 AM Thread Starter
joeyroe
I just changed my thermostat & water pump and don't know whether there's any air in the system. Should I still try to "burp" the system just in case, or will it eventually do it on its own if there's any air?
Thanks in advance.
joeyroe is offline
post #2 of 8 Old 08-09-2019, 08:56 AM
Newtons3
Newtons3's Avatar
Properly functioning, it will do it itself. However, if there is considerable air behind the thermostat, it can result in some less than desirable effects initially. I always cycle the cooling system through the initial opening of the thermostat and then set the fluid level hot (while running) to make sure there are no issues while operating on the road. If you have a bleed hole in your thermostat, a few minutes of running will usually purge most of the air.
joeyroe likes this.
Newtons3 is offline
post #3 of 8 Old 08-09-2019, 02:02 PM
TJTurbo
I've always parked mine nose up while everything is still cold with the radiator cap removed. Once the thermostat opens and you see the coolant moving, give the upper rad hose a few squeezes until you see no more bubbles. Carefully add coolant until the radiator is full. Be mindful of the fan and don't squeeze it so hard hot coolant splashes out on you. Put the rad cap back on, top up the overflow container and your done.
Sent from my LG-TP450 using Tapatalk
Jeepsr4me and joeyroe like this.
TJTurbo is offline
post #4 of 8 Old 08-10-2019, 09:20 AM Thread Starter
joeyroe
One more related question...
Ever since replacing my thermostat & pump, I noticed the levels in my reservoir tank no longer fluctuate. Before, levels were always lower at cold, higher at hot....but now it seems to always stay the same (cold or hot).
Is this normal since my engine isn't overheating, or should I try replacing my radiator cap?
joeyroe is offline
post #5 of 8 Old 08-10-2019, 10:00 AM
Shark_13
Best to squeeze the upper rad hose a few times and you'll see the bubbles come out.
Fluid should be going in and out of the tank depending on the temperature of the coolant.
joeyroe likes this.
Get out and explore.
Shark_13 is offline
post #6 of 8 Old 08-11-2019, 03:00 PM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
It's self burping, like an adult baby.
Newtons3 and joeyroe like this.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/BM brakes
99' XJ /4.0L-AW4/ 5.5" lift / Rancho shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
post #7 of 8 Old 08-11-2019, 03:12 PM
222Doc
222Doc's Avatar
i would replace the cap when replacing what you did as well. bad cap will make it so it cant bring coolant back in when it cools down. thats the self burping baby part, need to try that on the grand kid.
TheBoogieman and joeyroe like this.
222Doc is offline
post #8 of 8 Old 08-13-2019, 08:01 AM Thread Starter
joeyroe
Update:
After burping my system and trying 3 different 18psi caps, I tried a 16psi cap and my reservoir levels are fluctuating again. Go figure (my jeep is weird).
TheBoogieman and WSS like this.
joeyroe is offline
