will 33x10.5 bfg's fit on stock ecco wheels w/o rub? - JeepForum.com
post #1 of 5 Old 11-07-2009, 03:05 PM Thread Starter
DirtDiver
just wondering if the 33x10.50's will fit on the stock ecco's without rubbing? i found threads on the 31's just wondering about the 33's.thanks.
DirtDiver is offline
post #2 of 5 Old 11-07-2009, 03:06 PM
robncar
robncar's Avatar
Without rubbing what? Wheel wells, control arms, etc.?
https://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #3 of 5 Old 11-07-2009, 04:10 PM Thread Starter
DirtDiver
i have a 3 inch lift so i'm not worried about the wheelwells. i guess any of the suspension components, control arms, anything under there while turning the wheel.
post #4 of 5 Old 11-07-2009, 06:03 PM
dogbluedrummer
Trust me....
dogbluedrummer's Avatar
They will fit fine. you might need to add a washer or two behind the steering stops, so the front tires don't rub the sway bar at full turn.
Patriot Blue 2001 TJ
Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires.
My build thread
dogbluedrummer is offline
post #5 of 5 Old 11-07-2009, 07:01 PM
J03_TJ
J03_TJ's Avatar
Yep, they will fit fine, I ran 33-10.50 BFG A/Ts on my Ecco's until they wore out.
J03_TJ is offline
31X10.5 Goodyear Duratracs on stock ecco wheels flip01 TJ Wrangler Technical Forum 2 11-26-2009 11:16 PM
3.73 gears and 33x10.5 bfg's yes/no or SOLIDJP44 TJ Wrangler Technical Forum 51 10-01-2008 02:31 AM
33x10.5 on stock 5.25" BS wheels? jeffwight TJ Wrangler Technical Forum 3 04-25-2008 11:44 PM
1.75" BB - safe for 31x10.5's on stock (ecco) wheels? mike06X TJ Wrangler Technical Forum 10 11-13-2005 05:56 PM
ANYBODY RUN 33X10.50 SWAMPERS OR BFG'S GREGDOG95YJ YJ Wrangler Technical Forum 13 09-13-2001 04:46 PM
