Will 2002 Gas cap work on 2004? - JeepForum.com
post #1 of 9 Old 09-16-2003, 02:11 PM Thread Starter
Tmsnake1
Just wondering if anyone knows off hand. They have changed the gas cap 3 times in the last few years. I know that a 2001 Gascap will not work with the 2002's. So i was just wondering if my old 2002 gascap will work with my current 2004. THanks for any help
2002 Wrangler Sport - destroyed by drunk!
2004 Wrangler Rubicon -Yellow, 5spd
I
Tmsnake1 is offline
post #2 of 9 Old 09-16-2003, 03:40 PM
Whybu1
Lets go Penguins!!!!
Whybu1's Avatar
Have you tried putting it on?
Sorry couldn't resist.
Whybu1 is offline
post #3 of 9 Old 09-16-2003, 06:19 PM
Pinebarrensboy
Not Sure
Not too sure, however I was going to mention thinking about getting an aftermarket locking gas cap. You can get them from JC whitney and similar catalogs.
Brandon
2003 Rubicon
2.25" Budget Boost / Skyjacker 7000 Hydros
265/75/R16 Goodyear Wrangler MT/R's
JKS Quicker Disconnects
Pinebarrensboy is offline
post #4 of 9 Old 09-16-2003, 06:34 PM Thread Starter
Tmsnake1
I figured someone would ask me why I havent tried it. Actualy the reason I cant try it is because the lock is already keyed to my 02 wrangler. I dont have the keys to the old wrangler so if I put it on it will be locked. If I find out that it will work I will just take it to get re-keyed. I just dont want to spend the $$ to re-key it if its not going to work.
I
Tmsnake1 is offline
post #5 of 9 Old 09-16-2003, 10:07 PM
Dee Cue
Dee Cue's Avatar
Ahhhh, So you have one of the locking gas caps... Well you might have to buy a new one anyhow since they just redesigned them early part of this year. This was done to address the leaking channel problem they had in the initial design, which caused the check engine light to come on. I've had mine on since March '03 and no problems yet (knock on wood).
Blk, '05 LJ, 6-spd, 3" Zone SL, 33" BFG AT on Soft 8's
Dee Cue is offline
post #6 of 9 Old 09-17-2003, 07:45 AM
Jeepin_Jeffster
Guest
I'd be careful with the aftermarket locking caps. I bought one for my '01 and it resulted in making the check engine light come on. Even though it felt tight, it didn't seal well enough and I ended up sending it back...
Jeepin_Jeffster is offline
post #7 of 9 Old 09-17-2003, 12:35 PM Thread Starter
Tmsnake1
The cap I have is a Mopar locking gas cap and it worked fine on my 02. So as long as there were no changes it SHOULD work fine, but i still need to find out for sure before I go spend $30 to have it re-keyed
I
Tmsnake1 is offline
post #8 of 9 Old 05-14-2004, 03:28 PM
Skick
Guest
A question on your locking gas cap
I just bought a locking gas cap, from my local jeep dealer, for my 2003 wrangler. Does your lock cylinder come out of the gas cap when you unlock it?
Skick is offline
post #9 of 9 Old 05-14-2004, 04:02 PM Thread Starter
Tmsnake1
No, it shouldnt. Its possible the cylinder was put it backwards. I put mine in the wrong way and it would fall out.
BUt to answer your question, No it should not come out.
I
Tmsnake1 is offline
2002 + 2004 Steering columns - are they the same? Berndog TJ Wrangler Technical Forum 4 02-04-2010 08:48 PM
2002 Hard Top -> 2004 Soft Top Question on a 2002 TJ bryanphaas TJ Wrangler Technical Forum 2 03-05-2009 10:51 AM
Difference between 2002 & 2004 exhaust? TanTJ04 TJ Wrangler Technical Forum 2 05-27-2008 06:32 PM
1997-2002 tc skid on a 2004 redneckjeepr TJ Wrangler Technical Forum 3 04-19-2005 12:55 PM
2003-2004 Soft Top On 1997-2002 TJ AjRagno TJ Wrangler Technical Forum 0 03-31-2004 11:47 PM
