Why did my sway bar shift? - JeepForum.com
 2Likes
post #1 of 59 Old 02-16-2010, 09:31 PM Thread Starter
mystangt
Hello hello hello everyone
i was driving back from class earlier and i noticed an unusual rubbing/popping noise in the front right. So i pulled over and went under to see whats up...seems like my sway bar shifted towards the drivers side.
I read up on how to recenter it and will do so tomorrow. The real question is why did this happen?
Here are a few things that i did in the last few days that i have never done previosly. Did a few donuts in the snow but nothing rough...matbe 3 donuts on pure snow so it glided easily. I also flexed it for the very first time in its life. I climbed on a large snow pile. Never have i off roaded or flexed this TJ at all, this little snow bank is the only flex it has EVER seen. Looked pretty cool, although its very puny since its all stock suspension. Lastly, the roads are around me are pretty bad. Bumps, potholes.... Thats NYC for ya...
I am just curious what caused the swaybar to shift and how do i know that i need to replace my swat bar link bushings?
Thank you!!!
mystangt is offline
post #2 of 59 Old 02-16-2010, 10:13 PM
DezertTJ
DezertTJ's Avatar
that exact same thing happened to my jeep. It still hasn't been fixed because i broke a bolt in the frame trying to fix the shifting. Maybe replace the bushings? if its not that, then check the geometry of your suspension
DezertTJ is offline
post #3 of 59 Old 02-16-2010, 10:17 PM
Imped
Imped's Avatar
Guys, just remove the plastic "jeep" cover to take a look at how the sway bar is held in place. It can move, there's nothing wrong with your sway bars. If you don't want it to move, get a couple clamps to lock it into place.
OlllllllO
IndyORV
Imped is offline
post #4 of 59 Old 02-16-2010, 10:22 PM
DezertTJ
DezertTJ's Avatar
my cover is gone. i put the bar back into place and drive it around for a little bit and it moves back to one side hitting the frame. now my frame has some digs in it and the sway bar nut is rubbing and about to break off
DezertTJ is offline
post #5 of 59 Old 02-16-2010, 10:28 PM
Imped
Imped's Avatar
Hammer it back over and lock it into place.......paint the frame so it doesn't rust.
What's the big deal here?
OlllllllO
IndyORV
Imped is offline
post #6 of 59 Old 02-16-2010, 10:49 PM
chadsmeltzer
chadsmeltzer's Avatar
Jeep Swaybar Shifting Over Fix
It happens to a lot of Jeeps. Mine actually rubbed into the frame quite a bit before I noticed. I bought the clamps posted above and it has worked great.
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
post #7 of 59 Old 02-16-2010, 11:09 PM
DezertTJ
DezertTJ's Avatar
^^^ thats perfect!
DezertTJ is offline
post #8 of 59 Old 02-17-2010, 02:48 AM
gebirgziege
just leave it disconnected shoot. mines been disconnected for a year!
gebirgziege is offline
post #9 of 59 Old 02-17-2010, 02:58 AM
jeep2008
jeep2008's Avatar
I've installed these Sway Bar Clamp System by Fabtech and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware cheap-cool mode,problem fixed!
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #10 of 59 Old 02-17-2010, 08:39 AM Thread Starter
mystangt
Does anyone know of the diameter of the sway bar? I need to make a trip to home depot tonight and buy 2 clamps of some sort. Would something as simple as hose clamps work do you think?
Now that i know how to fix it, my real question still remains...why did this occur? Flexing? Potholes?
Thanks everyone for the help so far and thank you chadsmeltzer, the link is VERY helpful!
mystangt is offline
post #11 of 59 Old 02-17-2010, 08:59 AM
littledevilTJ
littledevilTJ's Avatar
just use some hose clamps, trial and error. it shifted because when you "flexed" it, it tried pulling the sway bar over. put a hose clamp on each inner side of the sway bar frame mounts.
My OLD build thread:
Florida Specific Forum
littledevilTJ is offline
post #12 of 59 Old 02-17-2010, 09:25 AM
Alex74012
that dd rubi on 37's
Alex74012 is offline
post #13 of 59 Old 02-17-2010, 09:36 AM
chadsmeltzer
Yeah, excellent advice for a daily driver.
post #14 of 59 Old 02-17-2010, 09:46 AM Thread Starter
mystangt
Im gonna have mine connected for sure. I fell like there would be extra wobble and the braking might not be as good when it comes to making sudden or hard stops.
The sway bar will technically keep the tires planted a bit better on the ground.
mystangt is offline
post #15 of 59 Old 02-17-2010, 10:44 AM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Because some of us like a little less body roll and a little more control when on the road maybe?
GOLENJEEPTJ is offline
Auto wont shift out of park, BRAKE TRANSMISSION SHIFT INTERLOCK MECHANISM seems stuck Rivka TJ Wrangler Technical Forum 23 02-22-2019 12:02 AM
Electronic-disconnecting front sway bar or Active Sway Bar System vgullotta JK Wrangler Technical Forum 16 08-30-2010 06:39 AM
What holds the shift lever onto the transmission shift stub? venturad YJ Wrangler Technical Forum 10 01-19-2010 07:31 AM
Stock sway bar diameters.. can I run a smaller front sway bar? jondotcom TJ Wrangler Technical Forum 5 09-23-2009 02:24 PM
Sway Bar and Sway Bar Links -- MOOG? mmitsch TJ Wrangler Technical Forum 9 08-09-2009 11:21 PM
