The whole radiator thing - Page 2 - JeepForum.com
 3Likes
post #16 of 22 Old 04-10-2018, 02:54 PM Thread Starter
FL 4.0L
FL 4.0L's Avatar
Yes. I started the screw in each hole, then backed them out, then installed the shroud.
'97 TJ Sport, 4.0L, AX-15, D30/35, BFG TA KO 183K
'12 F30, '03 E46, '06 Rabbit, '13 Jetta
FL 4.0L is offline
post #17 of 22 Old 04-10-2018, 02:56 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Originally Posted by FL 4.0L View Post
Read here how much better an all metal 3 row radiator would be.
That was very surprising to read, given the number of years I have actively participated here.
Not many here, and probably next to none with any experience, would recommend any aftermarket 3-row radiator. The single-row OE radiator from Mopar pretty much has better cooling traits than anything out there that we're aware of. The number of rows in a radiator core really has very little to do with how well it cools. In fact, the factory went from its initial 2-row radiator to a different 1-row radiator design sometime around 2001 which produced better cooling. All of the Mopar radiators used in our TJs use an all aluminum core.
Jerry Bransford is offline
post #18 of 22 Old 04-10-2018, 03:25 PM
SkylinesSuck
I will agree and disagree with Jerry. Number of cores means almost nothing. The more cores the worse possibly. Thickness matters a bunch though.
The OEM rad works fine as long as it's in good shape and all the other factory bits are in place. You need a fan shroud. Period. No exception. Electric fans almost never outflow OEM style mechanical fans. The OEM plastic end style is prone to leak though, so that's a downside. I've seen it too many times to count on not just Jeeps, but it's the OEM style for most cars now days so it can't be that bad.
That being said I have an all aluminum 4" thick rad and it cools my stroker with a shrouded e-fan just fine.
'98 Sahara w/AX15 & 4.6L stroker, 2.5" OME lift, 32" BFG M/T's, 8.8 w/Detroit Trutracs & 4.10's F&R
SkylinesSuck is offline
post #19 of 22 Old 04-10-2018, 05:35 PM
Jerry Bransford
Administrator
Just so there's no confusion, there's but one core... it can have 1, 2, 3, 4, etc. rows.
post #20 of 22 Old 04-10-2018, 07:10 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
Ding!...
Knuckelhead is offline
post #21 of 22 Old 04-10-2018, 08:55 PM
SkylinesSuck
Whoops.
PSA: don't drink and type folks 😉
Jerry Bransford likes this.
post #22 of 22 Old 04-12-2018, 02:29 PM Thread Starter
FL 4.0L
FL 4.0L's Avatar
Yes. You, and several others, have been steadfast in your recommendation of the factory rad, and I should have listened! There were plenty of recommendations for the cheaper aftermarket rads, though, at the time.
FL 4.0L is offline
