The whole radiator thing - JeepForum.com
 3Likes
post #1 of 22 Old 04-03-2018, 08:08 PM Thread Starter
FL 4.0L
FL 4.0L's Avatar
So my rig (97 Wrangler Sport 4.0L stick) has 190K. I bought it at 108 in 2004. In 2005 at 111K the radiator started leaking at the top crimp. Read here how much better an all metal 3 row radiator would be. Fast forward 79K to yesterday. I see an area at the top of the all metal Radiator Barn radiator that the paint has eroded away around a crack in the metal. I come back to the forum to find that the 2 piece OEM radiator lasts longer and cools as well as anything else out there. I have an OEM rad on the way.
As an aside, I still go to the hardware store and come back with the wrong stuff! I went out to replace the radiator mounting bolts, washers, and extruded nuts. A nice guy on this forum said to make sure to get the short extruded nuts. Damned if I didn't come back with 2 longs ones!
'97 TJ Sport, 4.0L, AX-15, D30/35, BFG TA KO 183K
'12 F30, '03 E46, '06 Rabbit, '13 Jetta
FL 4.0L is offline
post #2 of 22 Old 04-04-2018, 11:30 AM
bobjp
That's how internet forums work. We assume something is a bad design because it breaks and then say another design is better because it looks better without any data proving that it is actually better.
I too bought a radiator barn radiator for the same reasons. It lasted 108,000 miles while the OEM lasted 150,000 miles.
IMO, 108,000 miles is poor for an OEM radiator, but I would be happy with that as a second radiator. Hopefully your OEM radiator is actually OEM.
Nice how radiator barn was "bought out" and won't honor their lifetime warranties, huh?
97 TJ sport.
bobjp is online now
post #3 of 22 Old 04-04-2018, 03:02 PM
imstillatwork
The same thing, but with spark plugs happens all the time... "These new spark plugs are the BEST! So much better than the 150k mile OEM ones I never changed in the past!"
imstillatwork is offline
post #4 of 22 Old 04-04-2018, 04:45 PM
Varnish
Varnish's Avatar
How much more are the OEM radiators compared to the radiator barn ones? Weren't the barn ones like $130.
79k miles but you got 13 years out of it, seems reasonable.
'06 LJ, '05 LJ
Varnish is offline
post #5 of 22 Old 04-04-2018, 06:59 PM Thread Starter
FL 4.0L
FL 4.0L's Avatar
Yeah, if you look at it time wise, the all metal lasted nearly twice as long! I think you are right about the price.
As far as who makes this radiator, I'll have to check when it arrives. The image looks like the original radiator. It's coming from a Myrtle Beach Jeep dealer who does online parts sales.
FL 4.0L is offline
post #6 of 22 Old 04-04-2018, 07:45 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
OEM radiators have/had upper and lower plastic tanks.
And just for the record radiator barn products suck!... IMO
Freeagent27 likes this.
Knuckelhead is offline
post #7 of 22 Old 04-09-2018, 03:53 PM Thread Starter
FL 4.0L
FL 4.0L's Avatar
Got the rad. Obviously not OEM as I can't get the shroud bolted to the radiator. The radiator barn had a nut welded on the backside to catch the bolt. Headed to the hardware store...
FL 4.0L is offline
post #8 of 22 Old 04-09-2018, 04:51 PM
Knuckelhead
R.I.P. Knuckelhead
IIRC Radiator Barn is out of business...
post #9 of 22 Old 04-09-2018, 05:11 PM Thread Starter
FL 4.0L
FL 4.0L's Avatar
You're right. At least I could bolt it right up. Any suggestions on how to get the fan shroud mounted since this radiator won't accept the old hex head mounting bolts? Sheet metal screws?
FL 4.0L is offline
post #10 of 22 Old 04-09-2018, 06:36 PM
mukluk
mukluk's Avatar
Could you post up pics of what you're dealing with? It might help to figure out a solution for your shroud mounting dilemma.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #11 of 22 Old 04-10-2018, 01:20 AM Thread Starter
FL 4.0L
FL 4.0L's Avatar
Well, I went out there and took a photo, but I'm not going to have to post it. I got it mounted. They just stamped 4 holes for the fan mounting screws, and it was a bear to get them started and turn 'em down. Would have been nice to have a threaded hole or a nut tacked to the backside. Just after 2 am, so I hooked up the hoses, put the new coolant reservoir in, filled as much coolant as it would take without running it, and I'll finish in daylight. Thanks for looking!
FL 4.0L is offline
post #12 of 22 Old 04-10-2018, 10:59 AM
ThisJustin
I paid $90 from a company called 1-800-radiator. 2 year warranty.
oem style.
1958 Willys Wagon, 1988 Jeep Wrangler YJ,
2000 Jeep Wrangler TJ
2014 Jeep Grand Cherokee WK2
ThisJustin is offline
post #13 of 22 Old 04-10-2018, 12:58 PM Thread Starter
FL 4.0L
FL 4.0L's Avatar
All done. It is warm in SW FL today, so it is running a smidge above the 210 mark as it always does on a warm day. Thinking I'm good to go, hopefully for at least 100K!
FL 4.0L is offline
post #14 of 22 Old 04-10-2018, 01:24 PM Thread Starter
FL 4.0L
FL 4.0L's Avatar
Here is the photo of the issue. I don't have the shroud in the frame. I was able to eventually get the screw started...
FL 4.0L is offline
post #15 of 22 Old 04-10-2018, 02:22 PM
Knuckelhead
R.I.P. Knuckelhead
If you haven't installed the shroud you do understand that you need it?...
