Whistle sound only when cold! - JeepForum.com
post #1 of 30 Old 12-30-2008, 03:53 AM Thread Starter
jeep2008
jeep2008's Avatar
well this is the situation nly when i start the jeep in the morning and now that we have cold days in the first 5-10 minutes of driving it starts to whistle(high pitch)(not loud) when i let of the gas while driving.today it even whistled when i stopped and let the jeep to idle for a while.it stops when the engine reaches normal temp of operation.i think it is coming somewhere from the rear driver side of the engine bay and on the bottom of the bay but don't stay on this and give me please your advise on what can it be????
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #2 of 30 Old 12-30-2008, 06:17 AM
letsgomuddin
Sounds like a vacuum leak to me. Hard to tell where it's coming from but you could always start it and spray all of your vacuum connections with something like brake cleaner or WD40 and if you hit the leaking area, the engine speed will change because it's sucking in the spray. Also try spraying around the throttle body and the intake where it meets the head. Good luck!
letsgomuddin is offline
post #3 of 30 Old 12-30-2008, 03:40 PM Thread Starter
jeep2008
jeep2008's Avatar
if it was from vacuum shouldn't it have caused the engine to idle strange when it happened?as far as i remember the idle was ok when it happened and i was stopped and hearing it.also the fact that i could have heard it today allthough i stopped and idled does it mean that it has nothing to do with the trans or the front drive shaft?also i'm almost sure that the whistle wasn't coming from the pulleys or serpentine belt.any ideas guys??
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #4 of 30 Old 12-30-2008, 03:58 PM
scottman
scottman's Avatar
2010 JK Wrangler
I've noticed the same thing recently, and only when it's cold outside. Will be investigating over new years and let you know if I find anything...
scottman is offline
post #5 of 30 Old 12-30-2008, 04:05 PM Thread Starter
jeep2008
jeep2008's Avatar
great!!any other info or same experience out there?
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #6 of 30 Old 12-31-2008, 08:32 AM Thread Starter
jeep2008
jeep2008's Avatar
bump for info and a HAPPY NEW YEAR !!!!!
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #7 of 30 Old 12-31-2008, 08:47 AM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
Mine has been whistling today because it's happy about going out for new years.
TheBoogieman is offline
post #8 of 30 Old 01-19-2009, 04:04 PM
red04cavy
Has anyone actually figured out what this is yet? I'm having this problem on my 2004 Grand Cherokee Laredo and I would like to find out what it is since this is my daily vehicle.
red04cavy is offline
post #9 of 30 Old 01-20-2009, 01:13 AM
Ferret
I am curious what the deal is with this too. When it gets really cold (basically anything below zero) my Jeep makes all sorts of wierd noises. It makes a whistleing sound, it idles rough, and the engine itself sounds louder out of the exhaust. But it only does this when it is cold. As soon as it warms up the jeep drives normally again. I have taken it to the dealership twice in the past two years for this kind of stuff and they just keep telling me that it is normal.
Ferret is offline
post #10 of 30 Old 01-20-2009, 04:34 AM Thread Starter
jeep2008
jeep2008's Avatar
Well nothing yet from me!What i can tell you though is that if i don't give it too much gas and i drive slowly until it heats up well it doesn't make that whistling sound.What worries me though is that the last time i heard this whistling sounds from my engine bay was when i changed my driving belt 9 months ago and after a while the pulley exploded and i was lucky that no more damage happened to the engine cause i was just starting the jeep when it happend.After i changed my pulley with a new one i had no sounds but after the first cold days they begane again!I don't believe they are related though...PS:talking about strange sounds, the door buzzer comes on sometimes without a reason for a couple minutes and then just goes away!!
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #11 of 30 Old 01-20-2009, 11:50 AM
bhazzard
I Had The Same Issue And Found It To Be The Bearing Failing In Power Sterring Unit. Had To Replace The Whole Unit To Fix- $450- Yikes, But Sound Is Now Gone.
bhazzard is offline
post #12 of 30 Old 01-20-2009, 12:17 PM
chadsmeltzer
chadsmeltzer's Avatar
I have a whistle too, almost sounds like a turbo spooling. I THINK it might be an exhaust leak. It usually goes away within 2-3 minutes.
I wish it were a turbo, between that and my throttle body spacer whistling, I feel like I should be really fast.
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
post #13 of 30 Old 01-20-2009, 01:53 PM
red04cavy
This whistle only seems to happen when I let off the gas and when I park in my garage (engine at idle speed). Once I give it gas, it goes away, but when it returns to idle, it whistles. Appears to be coming from the rear of the engine bay down low (tranny area).
post #14 of 30 Old 01-20-2009, 02:25 PM Thread Starter
jeep2008
jeep2008's Avatar
that is exactly where mine comes from,rear of the engine bay,drivers side down low!!
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #15 of 30 Old 01-21-2009, 10:14 PM
TylerMidthassel
well, there isn't much i can tell you until i know where it is coming from. the best way i found to figure out where a noise is coming from is to unscrew an old wooden rod from a broom. while the engine is on and making the noise put one end of the pole on a spot of the motor then your ear up to the other end. keep moving it around until you hear it the loudest. then you should be able to pinpoint the problem.
PS. allot of the time in the cold your belt makes allot of noise. if it is your belt the sound will become higher as the engine revs. Good Luck, and be careful with the pole
TylerMidthassel is offline
Tea Pot Whistle Sound?!!! From Throttle? StevieO40oz TJ Wrangler Technical Forum 20 03-17-2010 03:12 PM
Annoying Whistle Sound bendoon JK Wrangler Technical Forum 1 12-17-2009 12:36 PM
High pitched whistle when cold bsbllyan TJ Wrangler Technical Forum 2 01-21-2009 10:11 PM
Developing a strange whistle sound Davey Sproket YJ Wrangler Technical Forum 2 04-27-2008 03:07 PM
Whistle Sound In Parking Garage Dan808 TJ Wrangler Technical Forum 4 05-21-2006 10:17 AM
