When clutch is depressed, there is a horribly loud squeal. - JeepForum.com
post #1 of 4 Old 09-24-2018, 01:54 PM Thread Starter
firewife88
My son has a 1998 Jeep Wrangler Sport 4.0L/I6. Just about a week ago, his clutch (when depressed) makes a horribly loud squeal. The sound is worse upon start up and lessens a bit while driving. Any ideas where to start. Was told maybe a throw out bearing gone bad. The transmission was rebuilt one year ago and at that time the clutch was replaced.
firewife88 is offline
post #2 of 4 Old 09-24-2018, 02:03 PM
mukluk
mukluk's Avatar
Most likely it is a bad throwout bearing. There's a possibility it could be a bad pilot bearing or something jammed in with the clutch disc, but it's pretty much a guarantee the transmission will need to be dropped and the clutch looked over. If the clutch was replaced by a shop and is still under warranty, you might want to talk to them.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 4 Old 09-24-2018, 02:18 PM
TJnBC
Sounds like throwout bearing to me. Make sure if its replaced , it is you replace it with a METAL throw out bearing not a plastic one
2006 LJR...the madness begins again
TJnBC is offline
post #4 of 4 Old 09-24-2018, 02:18 PM
jwhutch
I had a similar problem recently. Mine went away when the clutch was depressed. Also went away completely when i turned the Jeep off and restarted it. Mine sounded like the starter trying to engage while the engine was running. Let me know how it turns out.
'00 Sport, Solar Yellow, 2" REBB, OME Shocks, 31 x 10.5 AT. N4SSE
jwhutch is offline
