Wheelbase Question? - JeepForum.com
post #1 of 87 Old 08-05-2011, 11:22 PM Thread Starter
mrblaine
Wizard of Brakes
mrblaine's Avatar
Wheelbase Question?
How much wheelbase do you figure you can wind up with under the following constraints?
TJ tub, stock length
Steering gear in the stock location with flat TJ Pitman arm
JK axles front and rear, slightly modified
Pure Jeep stretch tank under the rear of the rig.
Front axle pushed about as far as you can get it and still get a trackbar to clear the pitman.
Flat to the frame skid
Metal Cloak aluminum fronts to help the 37's clear the back of the front fender at the wheel well under the battery.
Any ideas?
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #2 of 87 Old 08-05-2011, 11:37 PM
MayRoll
MayRoll's Avatar
7" rear, 5" front. So about 106-7". Am I close?
First of the Breed
03 Khaki Rubi
JF short arm champ
MayRoll is offline
post #3 of 87 Old 08-05-2011, 11:43 PM Thread Starter
mrblaine
Wizard of Brakes
mrblaine's Avatar
5" in the front? Are you high? You do know that the trackbar and the pitman live in the same front to back plane, right?
I am Savvy
mrblaine is offline
post #4 of 87 Old 08-05-2011, 11:47 PM Thread Starter
mrblaine
Wizard of Brakes
mrblaine's Avatar
Here, this is 104 in the stock TJ tub with the fuel tank behind the seat.
I am Savvy
mrblaine is offline
post #5 of 87 Old 08-05-2011, 11:52 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
is there trimming of the rear fenderwell?
if so, I'd guess in the 97-99" range.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 87 Old 08-05-2011, 11:58 PM
red88MJ
2" out the front and 5.5" out the rear if you use something like a genright fuel cell in the factory location, if a stock tank then a little bit less the that i would say
This must be a low range beer because it makes everything slower...
MY LJ BUILD...
red88MJ is offline
post #7 of 87 Old 08-06-2011, 12:18 AM
dcope17
dcope17's Avatar
Wow... that jeep looks twice the size of mine.
Oh wait... it just looks that way cause you have Gerald in the drivers seat
Just like all the car commercials... they have a 5' tall adult in the ad so that the car looks bigger.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #8 of 87 Old 08-06-2011, 12:22 AM
MayRoll
MayRoll's Avatar
Alright, I'm slow tonight.... Thanks for waking me up.
101-102", closer?
First of the Breed
03 Khaki Rubi
JF short arm champ
MayRoll is offline
post #9 of 87 Old 08-06-2011, 06:30 AM
RubiconRazorbac
RubiconRazorbac's Avatar
X2. I was thinking around 97"
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #10 of 87 Old 08-06-2011, 11:04 AM
MayRoll
MayRoll's Avatar
Doesn't Genright allow you to go back 7" with a 15gal. tank using a D44 rear? The sheet metal will definately need to be cut.
First of the Breed
03 Khaki Rubi
JF short arm champ
MayRoll is offline
post #11 of 87 Old 08-06-2011, 12:16 PM
Unlimited04
on the PolyPerformance website, the PureJeep tank is advertised to allow you to move back up to 5"...but I'm guessing thats a bit inflated. Blaine also didn't mention fender trimming or evap system relocation either...so I'm guessing 5" stretch in the rear isn't practical...he'll most likely throw some curveball thats not mentioned either...like a Riddler diff cover that hits everything .
Useful Write-Ups:
Funny:
post #12 of 87 Old 08-06-2011, 03:09 PM Thread Starter
mrblaine
Wizard of Brakes
mrblaine's Avatar
That's what I'm trying to get my head around. I've got it mocked up with a 22.5" rear driveshaft, the front axle is 1" forward of stock at ride height with 4" of lift.
Fender well trimming is very allowed and no relocation of the evap due to it already living under the hood where it belongs.
I'm also guessing so far that the adverstised amount of stretch you get is not at full bump. Or if so, it's not actually the wheelbase at ride height which seems odd.
I am Savvy
mrblaine is offline
post #13 of 87 Old 08-06-2011, 03:27 PM
Unlimited04
I'd assume with 4" of lift and much stretch at all would require spring perch relocation to line the bumps back up. Heck, with 4" of lift they don't line up great after pinion angle changes with stock length lowers (reminded of Humbolt's rear spring relocation thread with Currie bumps)
Useful Write-Ups:
Funny:
post #14 of 87 Old 08-06-2011, 03:33 PM Thread Starter
mrblaine
Wizard of Brakes
mrblaine's Avatar
I'd assume with 4" of lift and any stretch would require spring perch relocation to line the bumps back up. Heck, with 4" of lift they don't line up great after pinion angle changes with stock length lowers (reminded of Humbolt's rear spring relocation thread with Currie bumps)
I'm beginning to believe that anyone that's doing this or has done this isn't measuring at ride height. I've got a slightly longer pitman, it's just about rubbing paint on the trackbar which is moved forward several inches, and the only way I was able to sneak the axle forward an inch at ride height was to center the spring perches.
If you aren't moving the spring perches, what are your springs looking like if you try for an additional 3 inches in the front?
I am Savvy
mrblaine is offline
post #15 of 87 Old 08-06-2011, 04:20 PM
wushaw
Rockin jeep
wushaw's Avatar
I got 100" out of mine, I had to use Gen Right comp tank due to the d60.
wushaw is offline
Wheelbase LimeGreen TJ Wrangler Technical Forum 1 03-11-2009 06:02 AM
Wheelbase question jedeason TJ Wrangler Technical Forum 4 05-21-2006 08:31 PM
Wheelbase Wiggy TJ Wrangler Technical Forum 2 05-11-2006 06:17 PM
Question about extending wheelbase with adj. control arms rhinoss TJ Wrangler Technical Forum 6 04-26-2005 08:11 AM
