What would you do to a junk yard axle? - JeepForum.com
post #1 of 13 Old 06-20-2012, 05:13 PM Thread Starter
mmm0042
mmm0042's Avatar
What would you do before installing a junk yard (D44) axle under your TJ?
The list so far:
- New diff fluid (feel free to suggest type and brands)
- Redo the brakes (can't afford the disc upgrade currently, but again, feel free to suggest brands for the drum brakes)
Anything else?
Not on the list:
- Locker (already has an ARB)
- Gearing (at 3.73, which is not preferred, but same as front)
- Chrome axles (already has them)
Thanks!
mmm0042 is offline
post #2 of 13 Old 06-20-2012, 05:51 PM
FFjeepguy
make sure the axle assembly and axle shafts are not bent
FFjeepguy is offline
post #3 of 13 Old 06-20-2012, 05:54 PM
Necko2529
Necko2529's Avatar
Is it a TJ take-off or?
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #4 of 13 Old 06-20-2012, 06:53 PM
Profit42
If you have to replace the entire brake system, wait until you can afford the discs and do it right from the start.
New seals are definitely the way to go as well. I'd also tear it all down and check the bearings and races for damage. Since you're thinking of regearing, go ahead and order a master install kit as well, which replaces all that stuff anyway.
Profit42 is offline
post #5 of 13 Old 06-21-2012, 08:21 AM Thread Starter
mmm0042
mmm0042's Avatar
That is a concern I have, but how do I do that? Eye balling it they look to be straight.
mmm0042 is offline
post #6 of 13 Old 06-21-2012, 08:22 AM Thread Starter
mmm0042
mmm0042's Avatar
It is off a 2005 Sport, so TJ take-off, but not a Rubi so no disc brakes.
mmm0042 is offline
post #7 of 13 Old 06-21-2012, 08:32 AM Thread Starter
mmm0042
mmm0042's Avatar
I don't have to replace the entire brake system, just figured I would while it was sitting on stands. Plus, I have a lot of other areas that could use the $500+ (unless I am missing something) it would probably take for the conversion.
Going to do some searching and read up on the tearing it down, but will probably take your advice and order a master install kit. Looking at ECGS they have it for $100. Good deal? Good product?
Thanks!
mmm0042 is offline
post #8 of 13 Old 06-21-2012, 09:00 AM
SlackJaw
baby jeep
SlackJaw's Avatar
weird dude, my '04 Sport came with a 44, and it has discs...maybe that was additional option
SlackJaw is offline
post #9 of 13 Old 06-21-2012, 09:10 AM
--chris--
--chris--'s Avatar
Must be an option, ive been searching JY's for some cheap 44's and every now and then i see one pop up with disks that was a non rubi.
--chris-- is offline
post #10 of 13 Old 06-21-2012, 09:25 AM
SlackJaw
baby jeep
SlackJaw's Avatar
cool, was unaware, thought all 44s were disc regardless of model, thanks!
Couldn't tell how to read my build sheet, but it does show 4 wheel disc brakes on a line separate from the rear axle D44 detail. Thanks again!
SlackJaw is offline
post #11 of 13 Old 06-21-2012, 11:14 AM
wushaw
Rockin jeep
wushaw's Avatar
Pull the drums and see how much lining you still have, if good then adjust them and install the axle, replace diff fluid and bleed brakes and go.
wushaw is offline
post #12 of 13 Old 06-21-2012, 11:21 AM
venum67
i've seen a cpl post that suggest swapping out drum to disc in the rear isn't a significant difference. Probably since most of your stopping power comes from the front...
venum67 is offline
post #13 of 13 Old 06-21-2012, 12:21 PM
Profit42
Thanks!
Look for ZJ disc brakes...they should bolt on and be much less than $500. And when it comes to braking systems, I'd rather spend the time and money to do it right. Drums just don't work for me, not where I wheel.
Brakes aren't only used to stop you from going forward, and they aren't only used in a completely dry clean environment, either. I'd much rather have discs that are self-cleaning than drums that can and will fill up with mud. Not to mention that disc brakes weigh a great deal less than drums.
Profit42 is offline
junk yard fan boomerjeep TJ Wrangler Technical Forum 5 02-01-2012 10:52 PM
Project Junk Yard Junk Dog Hashbrown YJ Wrangler Technical Forum 8 11-09-2010 06:32 PM
Project Junk Yard red87yj YJ Wrangler Technical Forum 30 10-26-2009 07:45 AM
What was that PDC from the Junk Yard? Reverb YJ Wrangler Technical Forum 2 10-21-2009 06:53 AM
DIY Junk yard TBI Ratmeat YJ Wrangler Technical Forum 6 11-30-2008 01:53 AM
