what type of hydraulic lifters in the 4.0 - JeepForum.com
post #1 of 7 Old 11-18-2004, 09:46 AM Thread Starter
wrangler2002
Does anyone know what type of lifters the 4.0 engine have? I know they are hydraulic but are they flat-tappet hydraulic or roller hydraulic?
wrangler2002 is offline
post #2 of 7 Old 11-18-2004, 10:24 AM
FlexyTJ
Guest
If 90% sure they are flat tappet design, hence our noisy valvetrains!
someone plaese confirm....
I sure hope so anyway, If thats a roller cam/lifters in there making all that racket that's pretty awful Both hot rods run roller cams, and the valve train is silky smooth silent on em'.
FlexyTJ is offline
post #3 of 7 Old 11-18-2004, 05:36 PM
dirtgrip
dirtgrip's Avatar
Just as Flexy TJ guessed the service manual shows as flat tappets in pictures-doesn,t really say in print but the cost difference is probably a deciding factor.
Large vacuum leak sucking all the dead presidents out of my wallet.
dirtgrip is offline
post #4 of 7 Old 01-23-2017, 04:35 PM
ColoradoChuck
The 4.0L has flat tappet lifters. I just did my lifter replacement job last month (Dec 2016).
Colorado Chuck
"Happy Trails"
2001 TJ 2-door Softop 4.0L
ColoradoChuck is offline
post #5 of 7 Old 01-29-2017, 09:12 PM
Davidgoodman
Colorado chuck, did this quiet the engine?
Davidgoodman is offline
post #6 of 7 Old 01-30-2017, 09:15 AM
vosevichs
Flat tappet lifters. While rebuilding my 4.0 last year I noticed a couple of lobes on the cam were going flat. That definantly would cause my ticking.
01 4.0l with 150k
Scott Vosevich
vosevichs is offline
post #7 of 7 Old 03-04-2020, 05:47 PM
ColoradoChuck
Sorry for the long delay. Re: quieting the engine, replacing the lifters (I used a stock replacement I bought from NAPA) didn't really change the sound of the engine. The stock lifters tend to create a slight (very quiet and steady) rattle in the engine. I would equate to the sound of a gently agitated can of peanuts shaken by hand. And I will caveat that with I hear most of the engine noise in my stock 4.0L valvetrain is from the timing chain -- you can confirm this with an automotive stethoscope pressed on the timing cover while the engine is running. (Do this VERY CAREFULLY - You don't want to get bitten by the fan!!)
I haven't seen the stethoscopes in NAPA lately; I have seen them on the ((well known nation-wide discount dealer)) for around $10. I find them to be very useful in locating where engine noise is loudest, and that CAN help you locate the general origin of engine noises.
Colorado Chuck
"Happy Trails"
DO I need to remove the head to change the hydraulic lifters (4.2L I6) No_Return YJ Wrangler Technical Forum 10 01-23-2017 04:23 PM
Hydraulic lifters removal SDGBASSE YJ Wrangler Technical Forum 16 12-26-2011 04:27 PM
Where do I buy Lifters for a 95 YJ noturaveragehak YJ Wrangler Technical Forum 1 11-04-2007 08:18 AM
whats better "spacer" type t-case drop or the bar type ? 87wranglersport YJ Wrangler Technical Forum 4 10-05-2007 07:02 AM
04 4.0L Cam Kit with lifters 92blazn TJ Wrangler Technical Forum 2 01-11-2006 10:08 AM
