What is the tallest tire I can run on stock 05 TJ - JeepForum.com
 7Likes
post #1 of 24 Old 04-15-2019, 09:00 PM Thread Starter
jkc252
Currently have 235/75-15 which are 28.6 overall height. Think I can run 265/65-17 which are around 30.4
Sent from my iPhone using Tapatalk
jkc252 is offline
post #2 of 24 Old 04-15-2019, 09:08 PM
Glang997
I bought mine a couple years ago and it came with 31s
jkc252 likes this.
Glang997 is offline
post #3 of 24 Old 04-16-2019, 08:07 AM
biffgnar
biffgnar's Avatar
OEM Rubicons came with 31s, although that was pushing things a bit.
biffgnar is offline
post #4 of 24 Old 04-16-2019, 09:17 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
X3, a 31x10.50 is absolutely the largest a stock TJ can run.
jkc252 likes this.
Jerry Bransford is offline
post #5 of 24 Old 04-16-2019, 01:21 PM
Dr. Internet
I own a stock 2006 LJ Rubi and it came with 245-75r16 tires, which equate to 30.468 inches in diameter.
If you are planning a change, many folks recommend replacing the 16" wheel with a 15" wheel, as the 16" tire selections are limited and, as most off road 16" tires have a load rating of "E", which is essentially for dump trucks. You can change to 15", get some nice wheels and put load rated "C" tires on your Jeep.
Jerry Bransford and jkc252 like this.
Steve
2012 Black GC Overland Summit 4x4 2006 Red LJ Rubi
USN Club Hull TJ-13 TX Jeep Club #29
Dr. Internet is offline
post #6 of 24 Old 04-16-2019, 05:45 PM
2jhanna
From the OPs post, it looks like he's maybe found some JK take offs, 17".
OP like stated above, a 31" tall tire will work, but hopefully you know to run JK take offs you need wheel adaptors, or 17" wheels with the proper lug pattern.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #7 of 24 Old 04-16-2019, 05:48 PM
biffgnar
biffgnar's Avatar
I thought JK takeoffs were a bit bigger than the size OP is talking about. Closer to 32.
biffgnar is offline
post #8 of 24 Old 04-16-2019, 05:54 PM
2jhanna
I'm not sure, but either way, just wanted the OP to consider wheel size/lug pattern.
jhanna
denton county, tx
2jhanna is offline
post #9 of 24 Old 04-18-2019, 04:52 AM
phatplat
I had steel 15's with 31" tires with the stock gearing and it was hell. Hell on acceleration, hell on my clutch. So whatever you do, make sure it matches with your future plans.
2001 TJ S
2012 WK2 O
2015 WK2 L
phatplat is offline
post #10 of 24 Old 04-22-2019, 09:10 AM
Rick_Fury
I have never driven or rode in a stock TJ Rubicon before. Does it really ride like a "dump truck?"
Rick_Fury is offline
post #11 of 24 Old 04-22-2019, 09:15 AM
jjvw
jjvw's Avatar
Not at all. But a load range C on a 15" can only help matters.
2003 Rubicon
jjvw is offline
post #12 of 24 Old 04-22-2019, 09:36 AM
Jerry Bransford
Administrator
Not like a dump truck but it rides stiffer than is needed which is caused by it not running Load Range C tires which is the appropriate rating for the Wrangler's weight.
Dr. Internet and underscore like this.
post #13 of 24 Old 04-22-2019, 10:15 AM
Rick_Fury
So why did Jeep equip the Rubicon with a 16" wheel?
post #14 of 24 Old 04-22-2019, 10:24 AM
jjvw
jjvw's Avatar
A way to create a perceived upgrade that was visible. These were the early days of larger rims on production vehicles. There also a couple minor details to the TJ Rubicon, especially the 2003, that suggest a rush to production and certain ideas left unrefined. The first Rubicon was a very odd vehicle in it's day.
2003 Rubicon
2003 Rubicon
jjvw is offline
post #15 of 24 Old 05-02-2019, 10:46 AM Thread Starter
jkc252
I went with 265/65-17 and they worked out perfectly.
jkc252 is offline
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3856 07-28-2019 09:18 AM
Solutions for a smoother ride? jvelez JK Wrangler Technical Forum 14 01-29-2019 07:42 AM
The Modified Superlift Thread USN_BlackWK WK Grand Cherokee & XK Commander Forum 93 01-20-2019 07:10 AM
There are many like it, but this tire size question is mine... Tremelune Jeep CJ Forum 7 01-08-2019 08:00 AM
Installed my XRC bumpers but not happy with tire carrier lacofdfireman JK Wrangler Technical Forum 3 06-14-2018 07:55 AM
