What skid plates are essential for offroading? And HID headlights? - Page 2 - JeepForum.com
post #16 of 23 Old 12-22-2004, 08:06 PM
thejafe
thejafe's Avatar
Wait for Oman to get here... he'll tell you all about the HID's
thejafe is offline
post #17 of 23 Old 12-22-2004, 08:42 PM
rubi-soho
rubi-soho's Avatar
Originally Posted by atxtj
I wonder what's taking him so long?
rubi-soho is offline
post #18 of 23 Old 12-22-2004, 09:54 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
Originally Posted by djab
don't a lot of the gas tank skids require a body lift?
If one were to do... say a 3.5 RE SF lift and did an SYE at the same time would they have to have another SYE built down the road if they wanted to do a belly up?
a lot of the gas tank skids will gain you 1" of clearance...and do need a 1" BL...
I installed the Skid Row, which actually bolts over the stock skid (most other replace the stock unit)...and it does not gain you any clearance or need a BL...
you've got the terminology a little off on the SYE...you don't "build" another SYE...however, you will probably need a longer driveshaft, and you can have yours redone locally for $100 or so...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #19 of 23 Old 12-22-2004, 10:01 PM
madmax
madmax's Avatar
I can't believe Oman hasn't come yet!!! When I saw this thread title, I knew Oman would post in that thread, but...
Hey Oman, where have you been?????
-madmax
2000 WJ 4.0L
2004 TJ Sport 4.0L - SOLD :(
2018 Chrysler 300S 3.6L
madmax is offline
post #20 of 23 Old 12-22-2004, 10:45 PM
djab
Greg
Ah, thanks for the correction/enlightening
djab is offline
post #21 of 23 Old 12-22-2004, 10:55 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The two most important skidplates to have are for the gas tank and oil pan. This is based on the high level of vulnerability of both items and guaranteed likelihood that they will be regularly impacted by rocks, etc. on the trail. The gas tank is usually the item most often hit when offroading and thus really should be protected first. My gas tank's skid plate has been hit so hard so many times that it has paid for itself probably a hundred times by now.
On the other hand, my oil pan skidplate has never been touched by the rocks in eight years of rock crawling. But even so, it needs a skidplate from the first day since it only takes one rock in the right place at the wrong time to puncture your oil pan and likely ruin your engine.
Skidplates for other things like the steering box, control arms, etc. are great but should be installed only after installing the gas tank and oil pan skidplates. Yes the gas tank looks like it already has a skidplate but trust me, that sheet metal that serves primarily just to support the tank provides nowhere near the protection a true skidplate does.
Jerry Bransford is offline
post #22 of 23 Old 12-23-2004, 12:14 AM
dllbert
Guest
hid?
What is an HID bulb?
dllbert is offline
post #23 of 23 Old 12-23-2004, 07:40 AM
BigWaylon
tubework is cool...
BigWaylon's Avatar
High Intensity Discharge...
they're the lights like Lexus, BMW, etc...
not a filament to light up, but it lights by igniting an electrical discharge between two electrodes in a capsule filled with xenon gas...
aftermarket kits are $500+...and most aren't DOT approved...
HID-like bulbs are just normal bulbs that are white/blue/purple...and go for as little as $5/each...
Greg
skid row skid plates these things are tough barry1me TJ Wrangler Technical Forum 26 05-29-2008 06:17 AM
bad vibes after offroading/ could use advice on skid plate and SYE thelazerviking TJ Wrangler Technical Forum 2 03-28-2007 09:20 PM
Skid plates mean90yj YJ Wrangler Technical Forum 1 01-13-2007 07:59 AM
skid plates iamabert TJ Wrangler Technical Forum 14 01-09-2007 05:08 PM
Essential basic armor/skid protection thread. SMOKE Dog TJ Wrangler Technical Forum 23 03-23-2005 09:22 PM
