What skid plates are essential for offroading? And HID headlights? - JeepForum.com
post #1 of 23 Old 12-22-2004, 07:49 AM Thread Starter
diveguy
Hey all,
Can anyone tell me what skid plates are essential for offroading? I already have a steering column skid. And my 2004 X already comes with an oil pan skid. Anything else? And does anyone know where I can get HID headlights?
diveguy is offline
post #2 of 23 Old 12-22-2004, 08:23 AM
BigWaylon
tubework is cool...
BigWaylon's Avatar
are you looking for true HIDs? (like $500+) or just HID-appearance bulbs?
not sure about "essential"...
but I would recommend a couple:
1. front diff guard
2. engine/oil pan skid
3. rock sliders
other items:
1. rear diff guard
2. steering skid
3. stonger gas tank skid
4. belly-up t-case skid (also gains ground clearance)
5. front LCA skids
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #3 of 23 Old 12-22-2004, 08:33 AM
got4-Lo
Guest
1. front diff guard
3. rock sliders
Greg
mainly front diff. it will take a lot of abuse. and i mean a lot
got4-Lo is offline
post #4 of 23 Old 12-22-2004, 10:27 AM
dakuda
I used to be someone
dakuda's Avatar
THe skids you need/want should depend on where and what kind of wheeling you do.
Generally though, the front diff, oil pan/engine and rockers are a good idea.
You can do things the right way or the wrong way.
Or you can do it MY way...which is like the wrong way, only faster.
dakuda is offline
post #5 of 23 Old 12-22-2004, 11:46 AM
STW
So, the front diff takes the abuse head on. I haven't hit my diffs on anything, but I know I'm choosing lines to avoid a diff hit and often not doing a line because it might come close--so I think I'm being too careful and missing out. Diff skid would give me a better margin, at least in my head.
What about the back side of the diff? Do I only need to protect the front from a head on hit, or should I look for a diff skid that will protect it in reverse, or when getting pulled out backward? A lot of the rear diff skids I see cover the rear of the pumpkin--is that because they need protection in reverse or is it because it looks good
2000 2.5 TJ, 5spd, 33s, 8274
STW is offline
post #6 of 23 Old 12-22-2004, 12:05 PM
AZSahara
AZSahara's Avatar
The gas tank is mounted low on a TJ. Unless you have a lot of lift you need to put something like a Skidrow, Kilby or TBT armor on it. If you drive on a lot of rocks or rock shelves you'll slam the gas tank coming off rocks even if you're careful.
I would also invest in a good set of rock sliders. I personally like the design that covers the sides and has side bars extending out to protect the fenders in the event of a flop. There are plenty of well designed units out there. I have Shrockbars but TBT, A-Z and several others are basically similar designs. Mine paid off when I tipped my jeep over on its right side several months ago. No damage, just some impressive rash on the sliders.
Agree with armored diffs--either plate steel covers like Crane or Blue Torch Fab, or high quality bolt on armor. I have Blue Torch covers but I really like the TBT "cage" type diff armor and may be going that route soon.
As has been stated, the type of armor you need depends on where and how you wheel. I consider the above the minimum for the wheeling on rocks here in AZ.
John
L92/6L80 98 TJ
From the wilds of Northern Arizona
AZSahara is offline
post #7 of 23 Old 12-22-2004, 12:10 PM
C2U5H
C2U5H's Avatar
i don't have any aftermarket skids right now, but i'm planning on a front/rear diff and steering box as of right now.
as for the HIDs, I think I can hear Oman comin' along now...he'll tell 'ya what's up...
~J
2012 Crush JK Rubicon on 2.5" and 37s
- see sidebar
C2U5H is offline
post #8 of 23 Old 12-22-2004, 03:28 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
are you asking about the back side of the front diff? or where the rear diff cover goes?
the diff housing itself is VERY sturdy, and I wouldn't be worried about it...
the rear diff cover can also be replaced, but most people don't hit it near as often...
my armor is a "safety net"...I try to dodge rocks by picking the right lines, but the armor allows me to screw that theory up and just bounce off of one...
Greg
post #9 of 23 Old 12-22-2004, 04:42 PM
Lud04X
Front Lower Control Arm Skids
I've now come across quite a few Jeeps with busted up lower control arms...It pretty much sucks to repair one I've heard
Khaki 2004 Wrangler X
OME HD Kit,JKS BMML,1.25 JKS BL, adj. control arms
RE Generation II Quick Discos
35x12.5x15 Goodyear MTR's w/ Kevlar, MT Classic II's
D44 rear axle w/ ARB, alloy shafts, 4.56 gears
Dana 30 with ARB, 4.56 gears, alloy shafts and ujoints
Lud04X is offline
post #10 of 23 Old 12-22-2004, 05:03 PM
MPowerM3
I thought you needed a SYE kit to do a belly up skid plate??? And I can vouch for a oil pan skid saw in use the other day
MPowerM3 is offline
post #11 of 23 Old 12-22-2004, 05:12 PM
CreightonRea07
Guest
definetly get an oil pan skid, Especially if you have a stock TJ, i hit mine this weekend pretty hard and wish i would have had the skid
CreightonRea07 is offline
post #12 of 23 Old 12-22-2004, 05:30 PM
opiv
opiv's Avatar
It seems like the first skids to buy should be the front diff skid and the gas tank skid. Then you should get armor for everything else.
There's the batsignal - there will be boobie lights in here soon.
opiv is offline
post #13 of 23 Old 12-22-2004, 06:35 PM
atxtj
Guest
I wonder what's taking him so long?
atxtj is offline
post #14 of 23 Old 12-22-2004, 07:27 PM
djab
don't a lot of the gas tank skids require a body lift?
If one were to do... say a 3.5 RE SF lift and did an SYE at the same time would they have to have another SYE built down the road if they wanted to do a belly up?
djab is offline
post #15 of 23 Old 12-22-2004, 07:31 PM
djab
djab is offline
skid row skid plates these things are tough barry1me TJ Wrangler Technical Forum 26 05-29-2008 06:17 AM
bad vibes after offroading/ could use advice on skid plate and SYE thelazerviking TJ Wrangler Technical Forum 2 03-28-2007 09:20 PM
Skid plates mean90yj YJ Wrangler Technical Forum 1 01-13-2007 07:59 AM
skid plates iamabert TJ Wrangler Technical Forum 14 01-09-2007 05:08 PM
Essential basic armor/skid protection thread. SMOKE Dog TJ Wrangler Technical Forum 23 03-23-2005 09:22 PM
