what size is the tool for door removal ? '06 tj... - JeepForum.com
post #1 of 24 Old 03-21-2007, 07:08 AM Thread Starter
d.mehrl
need to buy the tool for removing doors ! can ya tell me what size it is ? thanks !!
d.mehrl is offline
post #2 of 24 Old 03-21-2007, 07:15 AM
jeeptj19992001
channel locks?
vice grips?
adjstable wrench?
stupid tool they sell in 4wd?
there is no special tool.
if you are concerened about the paint, wrap it w/ duct tape and be careful
03 rubi....growing bigger and better every day...
jeeptj19992001 is offline
post #3 of 24 Old 03-21-2007, 07:19 AM
ChadCielencki
Guest
how big are your arms and hands?
ChadCielencki is offline
post #4 of 24 Old 03-21-2007, 07:19 AM
mdm
Farm Wheeler
13mm wrench.
mdm is offline
post #5 of 24 Old 03-21-2007, 07:27 AM
Cocoyofoo
i suggest you also buy a can of PB Blaster and some white lithium grease..
Spray the PB Blaster on before removal, let it sit for awhile then after the doors come off spray some WLG to make removing the doors 100 times easier
Cocoyofoo is offline
post #6 of 24 Old 03-21-2007, 12:42 PM
BlueFlame
BlueFlame's Avatar
Originally Posted by jeeptj19992001
channel locks?
vice grips?
adjstable wrench?
you left out hammer and crowbar....
BlueFlame is offline
post #7 of 24 Old 03-21-2007, 12:43 PM
ChicagoJeeper66
Guest
You need a metric crescent wrench.
ChicagoJeeper66 is offline
post #8 of 24 Old 03-21-2007, 01:05 PM
BobG80918
13mm wrench. Use adhesive tape or painting tape (basically adhesive tape). Duct tape isn't good for paint. Scotch tape would probably work in a pinch (with the extra thickness provided by the tape, I doubt your wrench is going to slip).
One half turn should loosen it enough that you can unloosen the nut the rest of the way with your fingers. If it isn't, then be sure to spray the threads with WD-40 before reinstalling the doors so it only takes one crank next time you take the doors off.
BobG80918 is offline
post #9 of 24 Old 03-21-2007, 01:39 PM
03jeeper78
03jeeper78's Avatar
It's an '06 - if he has to PB blaster it just to get the doors off, there's something seriously wrong. I'll second the motion to grease after removal, though.
'03 Bright Silver Metallic TJ Sport
BSMCCEP Club Member #45
Stock: 4.0L I6:5-speed:3.07 gears:D35 with Trac-Loc:15x7 Ecco wheels:Dual Top Group
Mods: 30x9.5 BFG A-T T/A KO's:JKS Quicker disconnects:Rock-It Man rocker guards:Jeep Medic oil pan/tranny skid:Kilby steering skid:Warn D30 diff guard:C4x4 D35 diff guard:Rusty's radiator guard:Skid Row LCA skids:SilverStar headlights and fogs:Hidden Hitch class III receiver:Old Realistic 40ch CB:2' Firestik II:Arizona Rocky Road tailgate antenna mount
Next : Jeeperman rear bumper
'06 Candy Orange Honda Shadow Spirit 750
03jeeper78 is offline
post #10 of 24 Old 03-21-2007, 01:41 PM Thread Starter
d.mehrl
Thanks for the replies guys.... It was a serious question...
d.mehrl is offline
post #11 of 24 Old 03-21-2007, 02:42 PM
Nick B
A 13mm will not work because of the paint thickness. Use tape and an adjustable wrench.
Nick B is offline
post #12 of 24 Old 03-21-2007, 02:57 PM
GroundAssault
GroundAssault's Avatar
thats all I use is a 13 mm wrench
2006 Jeep Wrangler---SOLD!
Nowhere at present is there such a measureless loathing of their country by educated people as in America. --Eric Hoffer
Originally Posted by rmb2485
cheap mods are like a drug dealer giving you your first few for free...they will only get you addicted and before you know it every paycheck goes into your new habit :rofl:
GroundAssault is offline
post #13 of 24 Old 03-21-2007, 02:59 PM
bairy
Some people have needed the hi-lift.
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #14 of 24 Old 03-21-2007, 03:46 PM
sparkeep
make sure you turn the right direction... the threads are easy to snap off if you get it wrong. People have posted that happening.
2005 Impact Orange Rubicon
6 speed standard 4.0L I6 engine
Mechanical Engineer behind the wheel
Toronto, ON, Canada
sparkeep is offline
post #15 of 24 Old 03-21-2007, 03:53 PM
XabuJr
XabuJr's Avatar
1992 XJ Cherokee
Dang it, that's what I should have done. Would have saved me the labor of cutting them off..
Current Garage:
1992 Cherokee | 1994 YJ | 2013 JK | 2014 WK2
XabuJr is offline
Hard Top Removal Tool Mafoo JK Wrangler Technical Forum 9 07-30-2009 08:25 AM
Ball joint removal tool. 04WranglerX TJ Wrangler Technical Forum 52 03-06-2009 04:38 PM
Balljoint removal tool... de6w6it TJ Wrangler Technical Forum 16 07-05-2006 04:40 PM
Quadratec Door Removal Tool T- Bone TJ Wrangler Technical Forum 42 07-08-2005 04:34 PM
