What is involved in a ring and pinion swap / re gearing - JeepForum.com
post #1 of 6 Old 10-06-2009, 08:17 PM Thread Starter
drummerchukb1
What is involved in re gearing? To have someone else to the work will cost way more than i want to pay. My dad and i are pretty mechanicaly savy, but are new in the gear world. Can regearing be done in the drive way? Specialty tools needed? Could it be done in a day by two people new to this area of work? And any other thoughts / first hand experience would be nice!
(If i missed a thread in my searching - a link would be awsome)
~Chuck
drummerchukb1 is offline
post #2 of 6 Old 10-06-2009, 08:47 PM
Max-Q
1983 CJ7
It can be done if you research and read as much as possible before you do it. Then pay close attention to how everything came apart. One big help is to make a set of "set up" bearings. Basically these are new bearings where you grind down the inside so that it slides on and off easily. Then you can install and remove the carrier and pinion easier to adjust the shims and backlash.
It is a tedious job and I would say allow two days at least per axle. The front Dana 30 is a royal pain in the *** and took us two days to finally get it perfect.
Good luck.
1997 Jeep TJ
1983 Jeep CJ7
2011 JK Unlimited Rubicon
Max-Q is offline
post #3 of 6 Old 10-06-2009, 08:49 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
don't try gears for the first time yourself. just don't. its well worth the $1200 to pay a professional to do it, they have the proper tools and training. it ain't like putting on a lift.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 6 Old 10-06-2009, 08:53 PM
Max-Q
1983 CJ7
I'd honestly have to agree with you. I would never have attempted to do it IF it wasn't for my friend. He was a mechanic and he has done them in the past. Even after watching/helping him I'm not sure I would tackle it by myself.
1997 Jeep TJ
1983 Jeep CJ7
Max-Q is offline
post #5 of 6 Old 10-06-2009, 09:26 PM
BlueFlame
BlueFlame's Avatar
I've changed gear ratios/added traction aids in several vehicles over the years.
It's really easy, just call around for estimates, deliver the vehicle to the shop, and when it's done write the check.
BlueFlame is offline
post #6 of 6 Old 10-06-2009, 09:34 PM
mobyjeep
mobyjeep's Avatar
I've set up several r&p sets now and it really is not technically difficult. You just need to take your time. With the money you save you can afford to buy good tools. Check out this link for a list of tools - Randy's Ring & Pinion.
Here is a good set of instructions - http://www.ringpinion.com/Content/Ho...structions.pdf
mobyjeep is offline
D35 Help needed, ring and pinion swap/gearing question. snb73 YJ Wrangler Technical Forum 9 09-25-2008 05:58 PM
Ring & Pinion swap?? Droptine YJ Wrangler Technical Forum 1 08-28-2008 02:34 PM
Ring & pinion swap?'s DesertTJ TJ Wrangler Technical Forum 2 10-20-2006 03:57 PM
ring and pinion swap muszallkr TJ Wrangler Technical Forum 3 06-21-2006 12:17 PM
Best ring & pinion gearing for my rig? jeepinit YJ Wrangler Technical Forum 9 06-16-2004 05:18 PM
