what to do with the antenna - JeepForum.com
post #1 of 34 Old 12-29-2005, 05:50 PM Thread Starter
70sdiscotrike
Guest
for christmas santa got my some windshield lights and some cool fog lights- they look exactly like the Daylighters, but only cost 15 bucks a piece. anyhoo, the radio antenna is in the way of the lights. what are my solutions? im probably going to bend the antenna, but has anyone cut it? how does reception suffer? has anoyone replaced it with a stubby rubber antenna? all help will be appreciated-DAVE
70sdiscotrike is offline
post #2 of 34 Old 12-29-2005, 06:05 PM
Black Hills TJ
Black Hills TJ's Avatar
Hey. I have 100 watt daylighters on my windshield. I just zip-tied the antenna to the mount. It doesn't bend much at all. More like...curves.
Originally Posted by Allenwr
My mouth still has funky taste in it, so I am doin alright.
Originally Posted by ImSuck
damnit i wish i could get bigger quicker
Check out
Black Hills TJ is offline
post #3 of 34 Old 12-29-2005, 07:29 PM
Tinker
Guest
I don't have a pic but I have the same lights and I just put a dogleg in my antenna to kick it out past the light. works just fine
Tinker is offline
post #4 of 34 Old 12-29-2005, 07:32 PM
blk05tj
Guest
somebody bent mine one day so i just unscrewd it and the radio seems to work fine
blk05tj is offline
post #5 of 34 Old 12-29-2005, 07:51 PM
2005X
2005X's Avatar
my antenna fits just fine, might be hard to see with these pics, ill try to get a closer view
2005X is offline
post #6 of 34 Old 12-29-2005, 07:54 PM
Black Hills TJ
Thats exactly what mine looks like
Just zip tied it to the light bracket
Check out
post #7 of 34 Old 12-29-2005, 07:56 PM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
I don't have lights there yet... but in anticipation of getting them, I put on a stubby rubber antenna I got at PepBoys for about $5. I did loose a little reception, but I mostly use my mp3 player anyway.
Sorry for the huge pic, but it's the only one with a good shot of the antenna.
I'll be Savvy someday!
neZZr is offline
post #8 of 34 Old 12-29-2005, 07:57 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
i never had any probs, but i did do a stubby antenna and could only pick up like 5 stations, depends how close you live to the stations
RnEmOvr is offline
post #9 of 34 Old 01-01-2006, 11:02 PM
laddie
if the light mounts are grounded it might affect AM reception. See my post titled "03 wrangler radio problem". My antenna was contacting my Congo Cage mount and although it didn't affect FM reception it caused severe static on AM when the antenna would wiggle while touching the mount. It only seems to be a problem if the antenna is moving, you might try securing it to the mount but I solved my problem by just putting a small rubber sleeve on the antenna to insulate it from the mount.
laddie is offline
post #10 of 34 Old 01-02-2006, 10:26 AM
Windsor
Mobil 1, not Mobile 1
Windsor's Avatar
If the lights you got are indeed fog lights, you're much better off installing them on the bumper. With the wide beam pattern of fog lights, you will get glare off of your hood and not much performance. Generally speaking, fogs go on the bumper and pencil/spot lights go on the windshield.
2004 Wrangler Rocky Mountain Edition
BF Goodrich 31x10.50 Mud Terrain KM2
Rusty's 3" front springs and Skyjacker 2" rear spacers
Skyjacker Hydro 7000 shocks and steering stabilizer
JKS Quicker Disconnects
Tuffy glove box, full console
WARN D30 skid & Nth Degree Mobility oil pan skid
WARN front and rear Rock Crawler bumpers, winch plate and grill guard
WARN 9.5ti winch w/ Optima Blue Top D34M - X-Line rope & fairlead
KC Daylighter Slimlights on windshield
IPF H4 w/ FatBoy bulbs
Windsor is offline
post #11 of 34 Old 01-02-2006, 11:19 AM
EaglesSJ
EaglesSJ's Avatar
I have hella 500s which are way thinner and I just pulled the antenna behind the light and tried to bend it but no matter how much I tried it just flexed right back to its original position.
EaglesSJ is offline
post #12 of 34 Old 01-02-2006, 11:54 AM
06slvrrubi
06slvrrubi's Avatar
You took the antenna the whole way off and your radio still works fine?
Have had and sold 4 Jeeps,
just bought #5.
2004 Wrangler Columbia Edition
06slvrrubi is offline
post #13 of 34 Old 01-02-2006, 12:30 PM
TJ_with_Tusks
You can use a CB antenna as a FM antenna for the radio also. all you need is a CB antenna ($10-$20) and a splitter that takes the FM signal ($5) The splitter goes just behind the glove box. Take out the glove box, and you'll see the FM antenna wire. any place that sells CB stuff should have what you need
04' Columbia TJ
33" BFG AT's, OME HD lift, front airbag suspension, teralow 4:1 kit & supershort shaft kit, TW CV shaft, 4.10 gears, JKS body lift, track bars and quicker disconects, Warn 9.5ti, warn front bumper, garvin wilderness rack, and solid cast aluminum tusks,
TJ_with_Tusks is offline
post #14 of 34 Old 01-02-2006, 02:13 PM
EaglesSJ
EaglesSJ's Avatar
So I can use my regular CB antenna for my FM radio and my CB radio with just a splitter?
EaglesSJ is offline
post #15 of 34 Old 01-02-2006, 04:36 PM
btb601
Guest
I have KC Titaniums and the antenna wore the finish off the side.
btb601 is offline
Opinion on Antenna Mount / Antenna HammerG26 JK Wrangler Technical Forum 22 01-04-2011 06:49 PM
CB Antenna SoCalJK JK Wrangler Technical Forum 14 05-08-2009 11:53 AM
capping antenna mount when antenna is off Jeeper-4-Life TJ Wrangler Technical Forum 0 02-10-2007 08:57 PM
What do you do with the antenna??? ricker5 TJ Wrangler Technical Forum 8 05-18-2005 10:06 PM
CB Antenna Yoink YJ Wrangler Technical Forum 2 12-23-2004 05:27 PM
