What did you do to your TJ today? - Page 7768 - JeepForum.com
 3579Likes
post #116506 of 116648 Old 06-10-2019, 11:12 AM
mukluk
mukluk's Avatar
Originally Posted by gsindela View Post
By the way, I did the ZJ part upgrade to mine with Moog parts that rusted quite a bit almost immediately, which I found to be extremely annoying. I live in the salt belt, and wash often in the winter, and I never had that rust issue with the original steering parts.
If your new Moog parts were anything like the ones I recently installed on my TJ, they come unpainted with only a bit of protective oil coating. If you want them to not rust, you must clean the oil off and paint them like the original components were.
gsindela likes this.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #116507 of 116648 Old 06-10-2019, 09:23 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
Took the top off for the first time in a while, forgot to put on sunscreen. Took it to a drive in safari.
Sent from my SM-N960U using Tapatalk
May TJ of the Month 2015
TexasTJ is offline
post #116508 of 116648 Old 06-12-2019, 02:49 PM
gsindela
Used paint stripper to remove the remaining paint/power coat on my after market stainless windshield hinges. I wash it a ton in the winter because of the road salt. The car wash began to strip the paint off, so I finished the job. Now have stainless steel hinges, and they look pretty great. (No idea why the pic is rotated 90 degrees .)
gsindela is offline
post #116509 of 116648 Old 06-14-2019, 11:46 PM
armyRN
armyRN's Avatar
Location: Longview, WA (one hour north of Portland, OR)
Installed a hand throttle from Tera-flex. I'm liking it so far.
You can teach manners, but you can't teach class.
Trailer build:
armyRN is offline
post #116510 of 116648 Old 06-16-2019, 08:40 AM
Jonny Jeep
Jonny Jeep's Avatar
Swapped in some new Spicer ball joints yesterday and noticed one of the brake piston rubbers didn't look right. It's not sat evenly and the pads are wearing slightly unevenly on that side but getting near end of life anyway. I'll swap the pads when I get replacement seals from rockauto as I already have new BM pads, ordered as an extra set to have spare to save shipping/import costs.
Just when I was leaving work where I'd been doing the ball joints, I pulled my outer door handle and it went clunk and wouldn't close. Luckily the window was down so could open the door from the inside. Today I've removed the outer handle, bent the parts that were slipping past each other, and refitted it. I now know how difficult the wedges are to get out/refit as I've seen mentioned many times on the forum. The handle works like new again with everything lubed up too.
Jonny Jeep is offline
post #116511 of 116648 Old 06-17-2019, 11:14 PM
WSS
Graduate U-Tube Univ.
WSS's Avatar
Re worked our swingout. added top rack and rotopax mounts
The family TJ build:
non stock CJ's:
My CJ5 Build:
WSS is offline
post #116512 of 116648 Old 06-22-2019, 05:48 PM
wkbear
wkbear's Avatar
Replaced both of the hubs. In doing so I found the u-joint on the driver side in this condition. The passenger side is old (probably original, like this one, 158K miles), but is still functioning. Was going to change it, but while assembling the driver side I screwed up the new u-joint meant for that side, smh. I'll take care of it soon, but had to get it on the road today.
1995 Grand Cherokee Ltd., 5.2, 249, stock (for now)
wkbear is offline
post #116513 of 116648 Old 06-23-2019, 11:12 AM
Hbromberg
Hbromberg's Avatar
Replaced all 6 plugs with new Autolite XP985's. So I guess i never have to do that again 201,411 miles! Changed the oil with Pennzoil High Mileage and a new PureOne filter. Added a switch and USB ports with a dash air vent kit from Quadratec. Oh, and replaced a snap on the strap that holds the rolled up rear window.
2001 Wrangler Sport - Patriot Blue
Hbromberg is offline
post #116514 of 116648 Old 06-23-2019, 01:51 PM
RDaniel2405
RDaniel2405's Avatar
Nice day in Florida, very low chance for rain. Decided to throw the factory half doors on.
OEF Veteran & owner of a 2006 TJ
Instagram @theorangejeep
Pirate 4x4 @theorangejeep
RDaniel2405 is offline
post #116515 of 116648 Old 06-29-2019, 10:20 AM
carbert
Used her to get some wood/fire starter branches
dcoop and gsindela like this.
carbert is offline
post #116516 of 116648 Old 06-29-2019, 10:21 AM
carbert
Whoops sorry about the upside down images
carbert is offline
post #116517 of 116648 Old 06-30-2019, 06:52 PM
Vinniered
Vinniered's Avatar
Was hoping to get rid of the long crank, hard to start issue by replacing the Crank Position Sensor but apparently, that wasn’t the problem! Starts up the same way as before. Anyone have any good suggestions? 98 4.0 auto usually doesn’t start on first attempt but starts right up on second attempt .
Vinniered is offline
post #116518 of 116648 Old 06-30-2019, 09:36 PM
mukluk
mukluk's Avatar
Classic symptom of a failing fuel pump check valve designed to hold the line pressure after the engine is shut down. A trick that often works to alleviate the problem is to switch the ignition on but do not start the Jeep, pause a few seconds, then turn it to start -- if the check valve is pretty bad, you may need to cycle the switch on a couple times before starting to help prime the fuel rail pressure.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #116519 of 116648 Old 07-01-2019, 12:48 AM
Michael_K
Michael_K's Avatar
http://dailydriventj.com/fuel_pump.shtml
DailyDrivenTJ.com
JUST For Jeep TJ Owners Around the World!
Michael_K is offline
post #116520 of 116648 Old 07-01-2019, 10:56 AM
gsindela
Don't like to sound like a fan boy, but your TJ is BAD A$$!
gsindela is offline
modifications , tj
Not a good day today. :( CHRRRIS TJ Wrangler Technical Forum 42 10-09-2018 03:27 AM
