What did you do to your TJ today? - Page 7716 - JeepForum.com
 3599Likes
post #115726 of 116664 Old 08-11-2018, 10:55 AM
SuzanneBeMe
I had nothing but problems with the ORO LED's. They replaced them twice under warranty and when the 3rd set started to fair the denied my warranty request.
Originally Posted by rpapp1 View Post
Installed brand new ORO LED taillights then this happened. They imploded; weird thing is the leds still work.
Sent from my iPhone using Tapatalk
SuzanneBeMe is offline
post #115727 of 116664 Old 08-11-2018, 01:27 PM
Ghostrydr
I only use a wheel lock on my spare. I've had similar problems when taking my Jeeps to tire shops.
Ditto!
Ghostrydr is offline
post #115728 of 116664 Old 08-11-2018, 01:36 PM
Ghostrydr
Lost my upper radiator hose while poking around in the woods. Tried to secure it and add fluid but it just shot out everywhere. After a tow, replaced the upper and lower hoses plus the thermostat. Before I add the coolant and head off again, I thought I'd reach out to the Jeep Yodas and see if I should check something else.
Thx!
post #115729 of 116664 Old 08-11-2018, 09:55 PM
Mousejockey
Thx!
Check the heater hoses, if they are as old as the others wouldn't hurt, and back flush the core while the system is open.
Mousejockey is offline
post #115730 of 116664 Old 08-12-2018, 01:22 AM
plumber1
Originally Posted by Freeagent27 View Post
Any pics? Im curious to see how it turned out
It still needs a bit of work, but I used last weekend while on the Rubicon Trail. I mounted the 10 Plate Heat Exchanger under the Battery Tray and mounted the connections just in front of the air box. I used Red and Blue so I would remember which is which. I used 2 hand held shower hoses connected together to give me about 10' of hose. I did a trial run at home first, I used an ice chest full of water to simulate the lake with a garden hose flood to use to filter out anything large. I had the pump sitting on the bumper and used alligator clips to connect it to the battery. I was not sure how much height the pump could pull water so if I needed to I could place it on the ground to get it lower. As it turned out it would pull water up about 8' or more so now I can permanently mount it (just need to find a spot). As it turned out it heated the water to hot so I had to use the tempering valve set-up to get the water temp down a bit. The water at 6,000 + feet is very cold so this little exchanger worked like a champ. Then my son and nephews took the jeep down to the river with a trap and made a hot water spa.
I can quit drinking anytime I want, but hey I'm no quitter :)
White Jeep Club #224
plumber1 is offline
post #115731 of 116664 Old 08-12-2018, 01:08 PM
Mattific
Mattific's Avatar
Got some goodies to make it pretty again
Mattific is offline
post #115732 of 116664 Old 08-12-2018, 02:34 PM
Ghostrydr
Never thought of the heater hoses, thx!
post #115733 of 116664 Old 08-12-2018, 02:37 PM
rpapp1
rpapp1's Avatar
He said itís how they mix the plastic. Hopefully I wonít have the same issues with the new ones they are sending me.
rubicon27
rpapp1 is offline
post #115734 of 116664 Old 08-12-2018, 03:31 PM
mukluk
mukluk's Avatar
Not sure how much longer I can hold off on getting bifocals... saw the pic and thought to myself, "who in hell waxes their battery and why is there a product specifically for that purpose?"
2000 TJ SE
2005 LJ Rubicon
mukluk is online now
post #115735 of 116664 Old 08-13-2018, 09:19 AM
Shark_13
Thx!
New 18lb Stant rad cap probably wouldn't hurt.
Shark_13 is offline
post #115736 of 116664 Old 08-13-2018, 09:41 AM
ThisJustin
Decided I didn’t want to pay for a roof rack when all I wanted was an OEM style rack to haul very light cargo. Found one on a 2002 expedition and cut it down to fit, mounted it to the hard top. Only good for about 60lbs, but I won’t be hauling anything around that weight with it. Please ignore my junk pile behind me!
8A47203C-7241-4C8C-A3E6-898294C34F95_1534171263885.jpg   113D044C-8372-4F49-903F-F3C7271CEC38_1534171291939.jpg
1958 Willys Wagon, 1988 Jeep Wrangler YJ,
2000 Jeep Wrangler TJ
2014 Jeep Grand Cherokee WK2
ThisJustin is offline
post #115737 of 116664 Old 08-13-2018, 11:34 PM
Mud Machine
Jeep Addict
Mud Machine's Avatar
Originally Posted by Mud Machine View Post
Packed it up and ready to hit the Rubicon tomorrow.
Post some pics when you get back or it never happened.<img src="https://www.jeepforum.com/ubb/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
Here you go....
IMG_20180810_133111666_1534221142403.jpg   IMG_20180810_103620179_1534221222297.jpg
BDS Springs, MetalCloak Arms, Fox Shocks, Warn Winch, Savvy Ft Bumper, Antirock, GenRight Fenders, GR8 Top, 35" Pittbulls, 5.13's, Revolution Axle Shafts, LS/6.0, 4L80e
'76 CJ-7, 33" Swampers, 6-Point Cage, 4-Speed, Dana 300 Twin Stick
Mud Machine is offline
post #115738 of 116664 Old 08-14-2018, 01:37 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
Savvy GTS finished up.
Freeagent27 likes this.
May TJ of the Month 2015
TexasTJ is offline
post #115739 of 116664 Old 08-14-2018, 09:06 PM
Mattific
Mattific's Avatar
Picked up a set of rear poison spyder fenders (no armor) today. Those and my front bumper are going to powder coat tomorrow. Also gave it a wash
Mattific is offline
post #115740 of 116664 Old 08-14-2018, 10:25 PM
Mousejockey
Wish my "junkpile" had a flatfender in the middle of it
modifications , tj
Not a good day today. :( CHRRRIS TJ Wrangler Technical Forum 42 10-09-2018 04:27 AM
