What did you do to your TJ today? - Page 7666 - JeepForum.com
 3601Likes
post #114976 of 116667 Old 03-18-2018, 11:17 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
Finished the 6 middle body mount repairs today. Not pretty but they will work. Welded 3/16 underneath and 16 gauge on sides to replace 4 of the 6 that were rotted. I also needed a little lift to clear the Artec 3 link brackets so it worked out.
Welded the passenger artec lower control arm mount to the axle and just need to weld the frame bracket on to complete the 3 link front.
What’s left before I go wheeling in April:
Finish 3 link
Build track bar
Weld exhaust back together because I had to cut it out to clear the bracket
Rear shock mounts upper and lower
Genright tank
Other misc stuff.
97 TJ 37s custom long arm
Gen right stretch tank
03 TJ buggy project. Stretched tub to LJ, Goat Built chassis, tons 42” pit bulls
04 QCLB 4wd Cummins tow rig
24’ Gooseneck PJ trailer
JeepRocks86 is offline
post #114977 of 116667 Old 03-18-2018, 11:27 PM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
Originally Posted by Mattific View Post
Today marks 5 years and 40k miles with my tj
One year and 8,000 miles here.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4.25" combo lift/Rancho 9000XL shocks/5.13 gears-35" MTZs/BM brakes
99' XJ / 5" BDS lift/ 33" DC extreme country MTs. Jeep #18
TheBoogieman is offline
post #114978 of 116667 Old 03-19-2018, 07:35 AM
tweenerlj
Passed an emissions test. 14 years and less than 29,500 on the odometer. Gets the guy running the machine every time.
tweenerlj is offline
post #114979 of 116667 Old 03-19-2018, 10:32 AM
TheBoogieman
Distubed Jeepaholic
Is the RMS leaking? I've had bad experiences buying vehicles that were driven less than 2,000 miles a year. Things tend to leak more from lack of use. I sold my 03' on 35s with 26,000 miles on it to a car dealer for $12,000 in 2010.
gsindela likes this.
post #114980 of 116667 Old 03-19-2018, 11:56 AM
ThisJustin
Originally Posted by Bdajeep View Post
18 years and 279,000 miles.
I'm catching up with you! 18 years and 230,000 miles!
gsindela and Bdajeep like this.
1958 Willys Wagon, 1988 Jeep Wrangler YJ,
2000 Jeep Wrangler TJ
2014 Jeep Grand Cherokee WK2
ThisJustin is offline
post #114981 of 116667 Old 03-19-2018, 01:07 PM
cthusker174
Is the RMS leaking? I've had back experiences buying vehicles that were driven less than 2,000 miles a year. Things tend to leak more from lack of use. I sold my 03' on 35s with 26,000 miles on it to a car dealer for $12,000 in 2010.
I hardly drove my 99 for about 18 months after I purchased it. When I finally drove it I started seeing a little transmission fluid on the ground. Was a little concerned and took it down to local 4bye shop to get it looked at. He said it's most likely leaking because it hasn't been driven? The tranny wasn't down on fluid so he told me to drive it for awhile. Said to watch for any tranny fluid on the ground and check the dip stick more often.
To make a long story short after driving it for about week it completely stopped leaking and hasn't done it in the past 3 years. The 4bye shop saved me some money as they didn't try to take advantage of the situation.
cthusker174 is offline
post #114982 of 116667 Old 03-19-2018, 02:01 PM
gsindela
Changed the engine oil, transmission oil, and transfer case oil. Redline MTL for the transmission. Royal Purple for the transfer case. Whatever my mechanic uses for the engine. (I trust him.)
TheBoogieman likes this.
gsindela is offline
post #114983 of 116667 Old 03-20-2018, 08:53 AM
GS430
Replaced my lower control arms, both front and rear, with Rock Krawler adjustable arms and replaced sway bar disconnects with Rubicon express. Flushed the coolant, differential(front and rear) and transmission fluid flush.
GS430 is offline
post #114984 of 116667 Old 03-20-2018, 06:41 PM
Chuckbilly
Finished the np231c/j conversion. Waiting on transmission parts then throwing it all in.
Chuckbilly is offline
post #114985 of 116667 Old 03-20-2018, 08:03 PM
Ducman491
Dropped the shaft off at the welder to fix the pinch bolt problem. Changed the oil, flushed the coolant, tried to bleed the brakes and replace the brake fluid to find out 3 of the bleeder screws are seized so I’ll be replacing the calipers soon.
Every conversation should include at least 1 movie quote.
Ducman491 is offline
post #114986 of 116667 Old 03-20-2018, 08:44 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
Plasti-dipped the hood because it is oxidized, and I was bored. I need to repaint it eventually. And replaced my old lights with the newer model.
May TJ of the Month 2015
TexasTJ is offline
post #114987 of 116667 Old 03-20-2018, 11:09 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
Did you change all of the fluid or just the fluid in the pan?...
Knuckelhead is offline
post #114988 of 116667 Old 03-21-2018, 01:05 AM
TheBoogieman
Distubed Jeepaholic
Supposed to get 6"+ of snow and my clutch is screwed up, so I can't drive it. I hope it's just a master/slave cylinder problem. This is our first and only accumulating snow of the year.
post #114989 of 116667 Old 03-21-2018, 01:16 AM
tanner3327
i have a gap between my door and my soft top and i know that there is a piece that goes in there but i just cant figure out what its called. can someone who knows what I'm talking about post a link preferable from quadratec
tanner3327 is offline
post #114990 of 116667 Old 03-21-2018, 05:13 AM
TheBoogieman
Distubed Jeepaholic
Door surrounds.
modifications , tj
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Not a good day today. :( CHRRRIS TJ Wrangler Technical Forum 42 10-09-2018 04:27 AM
