What did you do to your TJ today? - Page 1249 - JeepForum.com
 3538Likes
post #18721 of 116612 Old 04-20-2009, 09:51 PM
default_user2
Originally Posted by UPSucks View Post
OK,,,,,so after I filled the reservoir back up why is my clutch not slipping anymore? Coincidence? Any explanation for this?
And no,,,,I'm running 35's.
Either way it isn't slipping like it was before, and I still need to re-gear.
Dang... This highline kit I have opens up the fender wells a lot, makes my 35's look like 33's! For the same look as your Jeep I'd have to go with 37's!
Tight Jeep either way!
Oh, and in order to stay on topic, I burnt half a tank enjoy the beautiful mid 70's day today! Tomorrow I'll probably polish off the tank
default_user2 is offline
post #18722 of 116612 Old 04-20-2009, 09:54 PM
ET48
ET48's Avatar
Originally Posted by flatlander757 View Post
I haven't even looked under my own Jeep, but if the clutch pedal is adjustable, perhaps the clutch master is already partially depressed taking some tension off the clutch leading to slipping?
Nope. Hydraulic clutch slaves are self adjusting.
To stay on topic like Pumpkin hehehehehehe, I drove my TJ in the rain all day today. Going back and forth from school and home.
ET48
1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs.
1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s.
ET48 is offline
post #18723 of 116612 Old 04-20-2009, 09:56 PM
default_user2
There's gotta be another reason, you can rip off the clutch slave cylinder entirely and it won't slip. When there is a leak in the clutch system you won't be able to get it into gear because the clutch doesn't disengage.
Temperature, humidity, etc could have something to do with the slipping. I haven't even looked under my own Jeep, but if the clutch pedal is adjustable, perhaps the clutch master is already partially depressed taking some tension off the clutch leading to slipping?
edit: and UPSucks, check your PMs.
Yes, I know exactly about this issue, and is why I know how a clutch works now!
In my '68 Commando I had about 6 years ago I had just replaced the clutch because I fried it trying to pull someone out (should have been in 4lo). Well I forgot to bolt the tranny to the crossmember, and when I went around a corner the tranny shifted to the right and the linkage popped out (had a manual clutch) at which point the clutch went to the floor and was stuck in gear. Stalled it and had to start the Jeep while in 1st gear because I couldn't control the clutch (with it bucking me) and rev the engine and shift to sync the gears up so I could push it into gear (was a *****!) Well because I couldn't shift into first again (no syncros for 1st or reverse) I did a 90* turn into the driveway going about 35, and fishtailing the Jeep on the gravel road Made it almost all the way home and had to have my dad tow me the rest of the way home in order to fix the linkage.
post #18724 of 116612 Old 04-20-2009, 09:57 PM
69injun
69injun's Avatar
oh and back on topic. I welded studs to a Ballistic flex joint housing. (control arm design change, or I would have ordered it with the stud) and to two poly bushing housings.
Kevin
97 TJ on 37's and 69 Firebird Convertable on blocks
69injun is offline
post #18725 of 116612 Old 04-20-2009, 09:58 PM
ET48
ET48's Avatar
Once in a while I will downshift without the clutch, just merely to save the clutch. Doesn't hurt anything.
ET48
ET48 is offline
post #18726 of 116612 Old 04-20-2009, 10:09 PM
UPSucks
GO BIG RED!
UPSucks's Avatar
Who knows,,,,,My Jeep kind of finds ways to fix itself. Except for the damn U-joint on the rear part of the driveshaft I had to replace a couple of weeks ago.
UPSucks is offline
post #18727 of 116612 Old 04-20-2009, 10:15 PM
seatmech32
seatmech32's Avatar
Vaccuumed the interior, applied my new registration sticker, and drove around town. Still have the soft top on but with tomorrow possibly hitting 80 degrees, it's goin' down and the doors are comin' off...permanently! Nice to see naked jeeps again after last week's snow storm.
Wave people!!
2006 Rubicon
Colorado Jeep Club #167
White Jeep Club #158
seatmech32 is offline
post #18728 of 116612 Old 04-20-2009, 10:15 PM
default_user2
Nope,,,,didn't wash anything. It has been slipping and progressively getting worse over the last couple of months. The only thing that I did to the Jeep today besides put gas in it was top off the reservoir.
Aha! Filling it up with gas probably fixed your clutch!
post #18729 of 116612 Old 04-20-2009, 10:17 PM
69injun
69injun's Avatar
Well I have a theory. When I drown my jeep the clutch went out. (among other things I am trying to forget) When I got the clutch out to replace it the clutch itself looked fine. Then I found the pressure plate was packed tight with silt from the water hole I was in. So my theory is you had something stuck in your pressure plate. Then when you toped off the Clutch the clutch was able to disengage further than it had been. This extra travel from a full clutch master cylinder freed up whatever was stuck in there and let it out.
Just an idea. "you make the call!!"
Kevin
69injun is offline
post #18730 of 116612 Old 04-20-2009, 10:29 PM
alex_c
changed my oil, painted the rust-spotted rim for the spare tire flat black (I have the stock steel wheels, and it looks sick...so I think I'm going to pain the other 4), power washed the mud off it, vacuumed the interior, but didn't give it a proper wash because I am going camping this weekend!
alex_c is offline
post #18731 of 116612 Old 04-20-2009, 10:32 PM
marylandjeeper
installed my new currie lcas on the front of the jeep. the bolts on the axle end were so rusted into the sleeve through the bushing on the stock arms i had to sawzall them out, it was a huge pain but its all done now.
marylandjeeper is offline
post #18732 of 116612 Old 04-20-2009, 10:53 PM
MisterO
MisterO's Avatar
Didn't drive my jeep much today, but before goin to bed I drove it in a really muddy area...
Guess tomorrow its gonna need some cleaning, I don't know how it looks since its dark but I'm sure not to clean
MisterO is offline
post #18733 of 116612 Old 04-20-2009, 11:11 PM
TikritJunkie
Finally got time to do a front end alignment and I'm glad I did cause the toe in was almost a whole inch. (Installed a JKS adjustable trackbar 2 weeks ago and was driving with an uncentered steering wheel which was annoying) I also adjusted the front pinion angle to match the front drive shaft and now all of my driveline vibes are completely gone. (I adjusted the rear pinion angle a few weeks ago). While I was crawling around under the front end I found out that my left axle seal is leaking so I cleaned it up and now I'm gonna monitor it for leaks. I'll be servicing the diffs next weekend probably and if the leak keeps up I've been looking for an excuse to regear them anyway. Don't tell my wife.
Silver Jeep Club Member #19
TikritJunkie is offline
post #18734 of 116612 Old 04-20-2009, 11:16 PM
mJUSTINm
1994 ZJ
took the hard top off for the summer. finally!
-Justin
mJUSTINm is offline
post #18735 of 116612 Old 04-20-2009, 11:35 PM
Onion22
raced mys sis's TJ, i won lmao it was to 30mph
-Sry bout my speling, i went too public school... an not dat offten.
- Member of "Kansas Mountain Rescue Patrol" if i see a mountain I'll rescue it.
White Rubi LJ, 6spd, 35" BFG KM2's
Onion22 is offline
modifications , tj
Not a good day today. :( CHRRRIS TJ Wrangler Technical Forum 42 10-09-2018 03:27 AM
