What did you do to your TJ today? - Page 1248 - JeepForum.com
 3548Likes
post #18706 of 116619 Old 04-20-2009, 08:42 PM
Grindahl
Grindahl's Avatar
2011
Got my new wheels and tires...
Now I need the lift so I can put them on
Grindahl is offline
post #18707 of 116619 Old 04-20-2009, 08:47 PM
Firedog13
Firedog13's Avatar
Drove it for the first time in 3 days. The Jeep was feeling neglected I'm sure. I will defend this neglect by mentioning that we were out of town.
Firefighters Jeep Club
All gave some, some gave all.
Firedog13 is offline
post #18708 of 116619 Old 04-20-2009, 08:51 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
Put my street tires on and took it for a drive. Drove 65 with no problem.
97 TJ 37s custom long arm
Gen right stretch tank
03 TJ buggy project. Stretched tub to LJ, Goat Built chassis, tons 42 pit bulls
04 QCLB 4wd Cummins tow rig
24 Gooseneck PJ trailer
JeepRocks86 is offline
post #18709 of 116619 Old 04-20-2009, 09:05 PM
default_user2
Originally Posted by UPSucks View Post
It was low on fluid and slipping a little bit. No more slipping after topping off.
How would that help eliminate slipping? The hydraulic clutch is just an assist to make pushing the clutch easier. How would this affect the gripping of the clutch itself because the throwout bearing and spring (don't know the technical word) is what provides the grip? The hydraulic assist only assists in pushing IN the clutch which takes the tension OFF the clutch...
Seems to me like saying "I changed the diff fluid and now my tires grip the road better"...
default_user2 is offline
post #18710 of 116619 Old 04-20-2009, 09:11 PM
UPSucks
GO BIG RED!
UPSucks's Avatar
Originally Posted by PumpkinHeep View Post
How would that help eliminate slipping? The hydraulic clutch is just an assist to make pushing the clutch easier. How would this affect the gripping of the clutch?
There wasn't enough fluid in the system to fully engage the clutch causing it to slip. Hydraulics.
UPSucks is offline
post #18711 of 116619 Old 04-20-2009, 09:35 PM
flatlander757
flatlander757's Avatar
Originally Posted by 69injun View Post
Thanks for the info. Seems like you will lose some flex but then again I think most of our flex comes from the front anyway. But all the buggies us 4 links so seem like it is better. Of course I guess they are also running coilovers or air shocks.
Yeah, flex isn't everything, I've got lockers F/R so I'm not terribly concerned about having an RTI ramp monster.
FWIW I bolted my axle up to the springs tonight so see where the Jeep sits, just straight up and straight down it's got about 9-11" of droop from ride I'm pretty sure flex will be more than enough
Leaf springs suck when they're not set up correctly Otherwise a great leaf suspension can easily outperform a poorly thought-out 4-link.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #18712 of 116619 Old 04-20-2009, 09:36 PM
default_user2
...well the clutch fork, clutch, throwout bearings and everything on the Jeep itself is identical to a manual clutch, the only difference being there's a master and slave cylinder going to the clutch fork, and not a cable. The slave cylinder doesn't do anything to engage the clutch, it just disengages the clutch when it puts pressure on the throwout bearing, which is spring loaded in order to engage the clutch. This is why the tranny turns in neutral with the clutch out...
I found this link. Shows you what I'm talking about...
Anyways, whatever... are you runnin 37's? Your Jeep looks sick!
post #18713 of 116619 Old 04-20-2009, 09:43 PM
ET48
ET48's Avatar
The hydraulic clutch slave cylinder only disengages the clutch, instead of having linkage. The spring pack on the clutch keeps the clutch engaged on the flywheel. If you are having slippage issues, your clutch disc or clutch spring pack is shot, or something is preventing the clutch from fully engaging, (like mud behind the clutch pack), or something like grease of oil got in on the flywheel or clutch.
ET48
1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs.
1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s.
ET48 is offline
post #18714 of 116619 Old 04-20-2009, 09:45 PM
UPSucks
GO BIG RED!
UPSucks's Avatar
OK,,,,,so after I filled the reservoir back up why is my clutch not slipping anymore? Coincidence? Any explanation for this?
And no,,,,I'm running 35's.
Either way it isn't slipping like it was before, and I still need to re-gear.
UPSucks is offline
post #18715 of 116619 Old 04-20-2009, 09:47 PM
default_user2
Exactly! I posted a few pictures two posts back that show the clutch.
Or maybe that wasn't the problem. Maybe coincidence, but fluid won't fix a slipping clutch. That's why I made the joke "changing the diff fluid makes my tires grip better"... They're not related...
Either way, glad it's fixed!
post #18716 of 116619 Old 04-20-2009, 09:47 PM
skipwheat
skipwheat's Avatar
I put on my mirror relocation brackets today after werk now I'm topless doorless and legal this is the first time on anyjeep I've ever owned I bothered with mirror brackets and I gotta say they make sense plus when I hit the trail 2 hex bolts per side and voila no more mirrors :-) yay
skipwheat is offline
post #18717 of 116619 Old 04-20-2009, 09:48 PM
ET48
ET48's Avatar
Did you wash you jeep and clean out whatever was in your clutch? I don't know. I just know that filling your clutch reservoir has nothing to do with clutch slipage.
ET48
ET48 is offline
post #18718 of 116619 Old 04-20-2009, 09:48 PM
Tufftoy
Made a tire bump so it will prevent the tire from shaking.
And looking straight down from the top.
2005 Silver TJ | 6 cyl | AirAid Intake | Throttle Body Spacer | 6 Speed Tranny | Super 35 Rear | Super 30 Front | 4.56 Front / Rear | ARB Lockers Front / Rear | 4" FabTech Lift | 33X12.5 | Black 15" Steel Rock Crawlers | Custom Bumper & Tire Carrier|
Tufftoy is offline
post #18719 of 116619 Old 04-20-2009, 09:50 PM
UPSucks
GO BIG RED!
UPSucks's Avatar
Nope,,,,didn't wash anything. It has been slipping and progressively getting worse over the last couple of months. The only thing that I did to the Jeep today besides put gas in it was top off the reservoir.
UPSucks is offline
post #18720 of 116619 Old 04-20-2009, 09:50 PM
flatlander757
There's gotta be another reason, you can rip off the clutch slave cylinder entirely and it won't slip. When there is a leak in the clutch system you won't be able to get it into gear because the clutch doesn't disengage.
Temperature, humidity, etc could have something to do with the slipping. I haven't even looked under my own Jeep, but if the clutch pedal is adjustable, perhaps the clutch master is already partially depressed taking some tension off the clutch leading to slipping?
edit: and UPSucks, check your PMs.
Currently Jeepless.
modifications , tj
Not a good day today. :( CHRRRIS TJ Wrangler Technical Forum 42 10-09-2018 03:27 AM
