Water Pump Failure - JeepForum.com
 1Likes
  • 1 Post By TheBoogieman
post #1 of 8 Old 08-11-2019, 10:41 AM Thread Starter
mickmeister
Water Pump Failure
My water pump froze 0.9 miles from my house last night. The engine overheated rapidly and I quickly pulled it into a friend's lot. Would it be too dangerous to drive it home to replace the water pump?
NRA Life Member
mickmeister is offline
post #2 of 8 Old 08-11-2019, 10:52 AM
RodKnock
RodKnock's Avatar
1974 CJ5
Once it's cooled, I doubt it would get hot enough in .9 miles to overheat unless there's stoplights along the way.
Whenever I run across a deal, I've no money. When I've money, I've no time. Can't catch a break!
RodKnock is offline
post #3 of 8 Old 08-11-2019, 10:53 AM
DesertRata
DesertRata's Avatar
Why take the chance of additional motor damage? Chances are you have towing coverage on your insurance policy. Have the rig towed home, pay the bill, turn in the receipt to your insurance agent and get reimbursed. Otherwise get one of your buddies to tow you home. Remember, the engine has overheated once. You might also consider changing the water pump while you have the Jeep sitting where it is at now.
Desert Rata
DesertRata is offline
post #4 of 8 Old 08-11-2019, 11:15 AM
oldRodney
Mick,
WAS the engine knocking or clattering or making weird noises?.. aside from the squeal.
hopefully not...
you say she is less than a mile away... as long as she is cold from sitting all night, and there is still coolant in her, here is what I would do...
1- take bottle of coolant with me,
2- top up radiator and return bottle
3 remove the drive belt,(so it wont squeal or get ruined) it won't charge the batt. with belt off...
4- jump in and (do not warm her up) quickly drive home...
this should work, but IT'S YOUR DECISION...
I WILL NOT BE RESPONSIBLE FOR ANY DAMAGE TO THE VEHICLE......
GOOD LUCK...
oldRodney is offline
post #5 of 8 Old 08-11-2019, 01:05 PM
Shark_13
If you have a tow strap and a buddy, that's what I'd do being so close. If the vehicle is cold, it likely could make it, but it's a bit risky.
Get out and explore.
Shark_13 is offline
post #6 of 8 Old 08-11-2019, 02:55 PM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
Open the door, grab onto the Jeep and push it home. Great exercise.
Kiwi_TJ likes this.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/BM brakes
99' XJ / 5.5" lift / Rancho shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is online now
post #7 of 8 Old 08-11-2019, 03:24 PM Thread Starter
mickmeister
Thanks for the responses. I decided to not drive it home. It is a steep climb that gains 140 feet of elevation up to my house from where it was.
Sent from my iPhone using Tapatalk
NRA Life Member
post #8 of 8 Old 08-11-2019, 03:36 PM
DougRz
Would have been fine, but that's assuming you did no damage in the overheating episode. Otherwise 3 to 4 miles is doable.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_) 03 auto, Ford 8.8, 4.88, Tru-tracs
DougRz is offline
