Wants to pop out of 2nd and 4th gear - JeepForum.com
post #1 of 3 Old 05-07-2021, 11:13 AM Thread Starter
Davwil
Davwil's Avatar
I recently installed a Zone combo lift (3.25" suspension lift and 1" body lift). It included the hardware for the shifter linkage, which I installed. However, now when i shift into 2nd or 4th, I have to put pressure on the shifter at first to keep it from jumping out of gear. Once it's engaged it's not a problem and it stays in gear. Is there an adjustment I can make to fix this?
Davwil is offline
post #2 of 3 Old 05-07-2021, 11:27 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Yes that's common and is caused by having increased the distance between where the shifter exits the transmission and where it passes through the rubber shift boot. That increased distances is restricting how far the shifter can be moved before the rubber boot wants to push against the shift back toward neutral.
The taller the body lift the worse it is. A 1" body lift can cause it too but if you also have a t-case drop that will add another inch to the restriction. A t-case drops the transmission an inch, the body lift raises the shift boot an inch, those two combine to really restrict the shifter but either by itself can do it too.
One fix, move the console slightly to more center the shifter boot over the top of the transmission. Then another possible help with your '97 TJ is there's a second rubber boot around the shift lever that is located underneath the shifter boot. That can be removed to remove some of the restriction. Doing that can also let more heat into the passenger compartment, though it's not a big deal. I didn't really notice it much in my own '97 TJ.
Jerry Bransford is offline
post #3 of 3 Old 05-07-2021, 12:00 PM Thread Starter
Davwil
Davwil's Avatar
Thanks Jerry. I'll do that. It's not a bad problem, just a little annoying.
Davwil is offline
